查看: 469|回复: 4
接地标志
发表于 2011-11-10 18:31:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
电机的接地标志可否用不干胶。
发表于 2011-11-10 18:31:24 | 只看该作者
These symbols shall not be located on screws, or other parts that might be removed when
conductors are being connected.
只要不容易掉 应该是可以的
发表于 2011-11-10 18:31:34 | 只看该作者
按标准意义,电机接地处不需要接地标识.
发表于 2011-11-10 18:31:47 | 只看该作者
只要有标识,能识别就可以了
发表于 2011-11-10 18:32:14 | 只看该作者
Normally, marking is for traceability, warning and reminding, so if it's used, make sure that why you wanna use it, of course, if all the markings should not be removed so easily...
GMT+8, 2026-11-30 17:45 , Processed in 0.035681 second(s), 18 queries , Gzip On.
