查看: 484|回复: 2
关于接点的机械固定
发表于 2011-11-2 23:12:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
刚才看UL1727的关于焊接的要求是:
18.3.3 With reference to 18.3.2, a lead is considered mechanically secure when one or more of the
following conditions are met:
a) The lead has at least one full wrap around a terminal.
b) The lead has at least one right-angle bend when the lead is passed through an eyelet or
opening.
Exception: On a printed-wiring board that is soldered by a machine process in which the
soldering time and solder temperature are automatically controlled, bending over of a lead after it
has been passed through a hole in the board is not required.
c) The lead is twisted with one or more conductors.
d) The lead is strapped in place, or the equivalent, adjacent to the soldered connection to hold
the lead end in place.
欧洲的要求是类似的吗?
发表于 2011-11-2 23:33:22 | 只看该作者
知情的请回复分享一下。
发表于 2011-11-2 23:34:42 | 只看该作者
不知道,学习学习。
GMT+8, 2026-11-30 16:35 , Processed in 0.026320 second(s), 18 queries , Gzip On.
