查看: 636|回复: 2
Evenflo Expands Recall of Majestic? High Chairs Due to Fall
发表于 2011-10-25 20:49:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Hazard: Plastic caps and metal screws on both sides of the high chair can loosen and fall out, allowing the seatback to suddenly fall back or detach from the high chair. Children can fall backwards or fall out of the high chair and suffer bumps and bruises to the head, broken bones, abrasions, cuts and bruises. Detached hardware also poses a choking hazard to children.
Incidents/Injuries: For the models added by this expanded recall, Evenflo has received 16 reports of seatbacks reclining, falling back and/or detaching unexpectedly, resulting in five reports of bumps and bruises to the head and five reports of other injuries including bruises and abrasions. For the models added by this expanded recall, Evenflo has received 145 reports of plastic caps and screws falling out of the high chairs, including one incident in which a cap and/or screws were found in a child抯 hand or mouth but were removed before choking occurred.
Description: The expanded recall involves Evenflo Majestic? high chairs, model numbers: 3001395, 3001395A, 3001604, 3001700, 3001713, 3001713A, 3001730A, 3001732, 3001733, 3001742, 3001742A, 3001756, 3001821A, 3001840A, 3001845, 30011848, 3001852, 3001932, 3002719 and 3003845 manufactured between January 23, 2007 and December 31, 2008. The model number and date of manufacture are located on a white label/sticker on the seatback. 揈venflo?is printed on the label and on the front of the tray. Models showing a year of manufacture of 2009 in red ink are not included in the recall.
发表于 2011-10-25 21:02:25 | 只看该作者
支持。。。。。。。。。
发表于 2011-10-25 21:10:08 | 只看该作者
支持,,,,,,
GMT+8, 2026-10-16 22:31 , Processed in 0.034890 second(s), 21 queries , Gzip On.
