查看: 814|回复: 8
摇铃测试
发表于 2011-10-22 19:07:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
0+的塑胶动物公仔需要做摇铃测试吗?
高手帮手解答下。
发表于 2011-10-22 19:08:18 | 只看该作者
你最好能说清楚点,做哪份标准
 楼主| 发表于 2011-10-22 19:11:31 | 只看该作者
是否完全通过及不合格,还是不能有部分通过。
 楼主| 发表于 2011-10-22 19:11:48 | 只看该作者
有高手发个摇铃测试指引上来
谢谢
发表于 2011-10-22 19:11:57 | 只看该作者
有圖片吗? 應該要做EN 71 Part 1 -5.8 template A .
不能有部分通过template A .
发表于 2011-10-22 19:12:18 | 只看该作者
请教!EN 71 Part 1 -5.8 如何理解,预防哪些对儿童产生危害的行为?先多谢各位
发表于 2011-10-22 19:12:28 | 只看该作者
主要是对一定形状的玩具(重量小过0.5kg,尺寸大过30mm)对0-10M小孩子choking 危险。
1、rattle
2、teether
3、hand-held activity toys
4、books and building blocks covered by textile or vinyl
5、removable components of toys intended to be strung across a crib, playpen or perambulator
6、removable components of baby gyms
7、legs of gyms
发表于 2011-10-22 19:12:38 | 只看该作者
HI JASON, thanks for prompt reply
A.31 Shape and size of certain toys (see 5.8 and A.43)
These requirements address potential impaction hazards associated with toys intended for children who are too young to sit up unaided.
The intention of the requirement that toys need to be tested "as supplied" is that prior to being tested according to 8.16 (geometric shape of certain toys), the toy will not be subjected to any other test.
In determining which toys are intended for such children, the following factors are relevant: the manufacturer’s stated intent (such as on a label) if it is reasonable, the advertising, the promotion, the marketing and whether the toys are generally considered as suitable for the age group in question.
It is recognised that children normally sit up unaided between five and ten months of age.
标准注解说的是IMPACTION hazard for children, 但我不明白,
1) 何为IMPACTION hazard?
2) EN71 8.16 中图的TEMPLATE A and B 模拟儿童哪部分?
发表于 2011-10-22 19:12:51 | 只看该作者
通常我们所做的rattle gauge and supplemental gauge 测试主要包括两个方面的危险,一是对喉咙的冲击伤害(impact), 二是哽塞窒息的危险.
可能说法上有点不统一吧,
EN71 8.16 中图的TEMPLATE A and B 模拟儿童哪部分?---就是指儿童的喉咙200){print
GMT+8, 2026-10-17 03:13 , Processed in 0.051493 second(s), 18 queries , Gzip On.
