查看: 633|回复: 2
求教 现行BS EN71-1和NF EN71-1的区别?
发表于 2011-10-17 16:13:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请大侠指教:
是不是出口到法国的玩具必须要做NF EN71?
NF EN71和BS EN71的区别?
谢谢!
发表于 2011-10-17 16:13:53 | 只看该作者
EN本来就是欧盟的标准要求,法国属欧盟国家。
发表于 2011-10-17 16:14:02 | 只看该作者
In fact, both the UK and Franch are the members of EU. Hence, French should accept the EN standard because the EN standard is published by the European Union. Normally, the EN version is printed in English. BSEN standard is printed by the UK government. And, NFEN standard is printed by French government.
No matter the BSEN standard or NFEN standard, they are based on the EN standard. Perhaps, you may take BSEN, NFEN and EN are more or less the same. However, the EU also allows his member country to add his own national deviations onto the EN standard. Be safe, it is worth to check whether there are national deviations in BSEN / NFEN standards although it rarely happens.
GMT+8, 2026-10-17 10:26 , Processed in 0.120886 second(s), 18 queries , Gzip On.
