查看: 932|回复: 5
求咖啡豆粉碎机的测试检验标准
发表于 2011-10-8 15:03:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求咖啡豆粉碎机的测试检验标准,谢谢各位了(或者类似的也可以)
发表于 2011-10-8 15:41:52 | 只看该作者
这个到处都是,
发表于 2011-10-8 15:48:39 | 只看该作者
在论坛里面搜索一下,,,,,,
 楼主| 发表于 2011-10-8 16:19:41 | 只看该作者
要是能找到,就不发帖了,能给个衔接不,谢谢了
发表于 2011-10-9 06:57:22 | 只看该作者
5. 主要元件檢查
Item(項目)        Description(描述)
Power cord(電源線)
Plug(插頭)
Thermostat
溫控器
Switch開關摯
Heater發熱管
Thermal fuse
溫度灰士
Lead wire引線
Motor摩打
relay繼電器
Capacitor電容
6. Testing測試
Test item
測試項目        Samplingplan
抽樣        Criteria標准        Passed Qty合格 數量        Failed Qty失敗數量
Hi-Pot test
高壓測試        LII        Class I: 1500Vac,1S.   Class II: 4250Vac,1S.( cut-off current setting on Hi-pot tester should less than 100mA,initial setting 0.5~5mA was recommended)
(Class I: 1500Vac,1S.  1MA  Class II: 4250Vac,1S 1MA)
Polarity test
极性檢查         (5PCS)         Live wire connect to switch ,thermostat, Thermal fuse,(火線接到開關﹐溫控器)
Grounding continuity test接地測試        LII        12V, 1.5times of rated current or 25A( whichever is greater),not exceed 0.1Ω(12V,  25A,不大于0.1Ω)
Power input test
功率檢查        LII        Less than +5% of rated power and more than -10% of rated power(功率值的90% 与105% 之間)
Switch operation test開關摯檢查        LII        Shall operate smoothly 20 times consecutively
(操作20次無阻滯)
Function test功能檢查        LII        Case by case(按說明書)
Brewing water  test釀水測試        LII        Must be average 1 minute per 150ml of water brewed until which was completed, then power should shut off automatically(平均1分鐘釀出150ml 的水﹐直到完成為止。然后功率自動切斷)
Brewing water temperature釀水溫度測試        5 PCS        Measured water temp. must 93℃(200F)  at end of water outlet在出水口測得的水溫不低于93℃(200F)
Coffee temperature test釀咖啡溫度測試        5 PCS        Must be 85℃(185F) to 96℃(205F) in carafe once brewing completed每次釀完在玻璃杯測得溫度在 85℃(185F) ~ 96℃(205F)
keep warm  test保溫測試        5 PCS        Not less than 80℃ within 1 hour 1小時內不低于80℃
Boil test with water filled in (if appliance contain a kettle)煲水測試(如有水壺)        LII        No sudden jets or hot water spouts, lid does not fall, no large water drops forming on handle or down onto base. Must shut off after reaching the boiling pointwithin 8 seconds. Must reset (power stays on) within 25 seconds沒有熱水突然濺出﹐倒水時不能沖開壺蓋﹐手柄上不能形成水滴或落到底座上﹐在8分鐘內煮開并斷電﹐在25秒內應复位
Grinder function
磨豆功能(如有)        LII        Ground 60g coffee bean full cycle (about 30s) then unit goes to brew mode automatically磨 60g 咖啡豆在整個周期 (約 30s) ﹐然后自動轉換到釀造模式
Dry boil test干煲測試        LII        Thermostat should work without melting or burning, or other safety issues Must restart after reset device is sufficiently溫控器必須動作且沒有熔化﹑燃燒或其他安全問題且可充分复位。
Pause pour test暫停流出測試        LII        Without overflowing from filter basket within 1 minute when  carafe was removed當移走玻璃杯后﹐在1分鐘內從濾网無溢出水滴。
Strain relief test電線拉力測試        5 PCS        60N, 1Sec. for 25 times, power cord displacement less than 2mm (60N, 1S. 25 次﹐位移小于2mm
Handle pull test
手柄拉力測試        5 PCS        Apply an axial pull 30N for 1minute, no loosen out
施加軸向力 30N ﹐ 1分鐘﹐無松動
Screw strength torque test螺絲扭力測試        5 PCS        Not less than 5kgfcm不小于 5kgfcm
Stability test
穩定性測試        5 PCS        Shall not tip over when tilted to a 10 degree angle in any direction( for electric heat appliance increase to 15)在 10斜面不能翻倒﹐電熱類為 15
Noise test (if with grind function)噪音測試(如有磨豆功能)        LII        No excessive noise or vibration. Shall not exceed
90dBA measured at 1 meter.
距樣机1米﹐不超過90dB
Blade stop time test停刀時間測試        5 PCS        Not more than 3.5s when power shut off斷電后不大于3.5S
Screen printing test絲印測試        5 PCS        No peel off using 3M Tape用 3M 貼紙測試無脫落
Paint coating test
澮層測試        1 PCS        Cut 1.0mm cross hatch on surface, No peel off using 3M Tape切 1.0mm 方格100個 ﹐用 3M 貼紙測試無脫落
Plating test
電鍍測試        1 PCS        Cut 1.0mm cross hatch on surface, No peel off using 3M Tape切 1.0mm 方格100個 ﹐用 3M 貼紙測試無脫落
Endurance test
耐久性測試        1 PCS        Operate product in normal condition with max setting for2-3 hours, then hi-pot test and function test shall be conducted, all results shall be acceptable正常條件下﹐最高擋工作 2-3 小時, 然后高壓測試﹐功能測試應合格
Carton drop test跌箱測試        1 PC        As  ISTA  TEST  PROCEDURES 2B&2A按照ISTA 2B&2A
Internal construction test內部檢查        5 PCS        Adequate clearance and  creepage distance, correct components, no foreign object inside, no loose足夠的電气距离和爬電距离﹐正确的元件﹐無异物和松動
Plug check (for BS)插頭檢查 (BS)        5 PCS        Approved BS 1363 plug, correct wiring, no loose strands& wire ,no solders, terminal screws, plug screw and fuse holder were secure 認証﹐正确排線﹐無散線絲﹐無焊接﹐端子螺絲可靠緊固。
Fuse inside plug (for BS)保險管檢查        5 PCS        Approved BS 1362 fuse, filled with damping sands (BS 1362 認証﹐內部裝帶防爆沙
UPC Barcode scannable  test (UPC 條碼掃描測試)        LII        All UPC barcode  in  sample are  scannable , UPC  scanned number  match UPC  label (UPC 條碼可掃描﹐且數字与標貼相符)
7. Data Measurement ( only  record  5  pcs sample)數据測量 ( 只記錄5個樣品):
        Description描述
Sample
no        keep warm  test保溫測試        Brewing water temperature釀水溫度   測試        Coffee temperature test釀咖啡溫度測試        Noise test (if with grind function)噪音測試(如有磨豆功能)        Blade stop time test停刀時間測試(如有磨豆功能)        Time(from 98℃ water temp. to power shut off)水壺98℃到煮沸的時間
1
2
3
4
5
 楼主| 发表于 2011-10-9 10:48:46 | 只看该作者
谢谢了
GMT+8, 2026-10-18 01:01 , Processed in 0.030808 second(s), 18 queries , Gzip On.
