查看: 587|回复: 4
多国认证问题疑问
发表于 2011-10-6 13:08:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位前辈们,一个或几个系列的电源要想同时拥有CE UL/CUL CCC TUV MARK 等认证,如何操作最快最省钱?其他大的电源公司是如何做的能介绍下吗?晚生先谢谢了!
发表于 2011-10-6 13:08:55 | 只看该作者
这是个比较难的问题,我也很想知道
发表于 2011-10-6 13:26:27 | 只看该作者
我咨询我们公司的安规人员,他们讲有多个安规认证,最好同时向相关的认证机构提出申请会快一些.
因为不同的安规,认证机构也不相同,所以没有什么最省钱的方法.
发表于 2011-10-6 13:26:38 | 只看该作者
Normally, if at the total beginning, then you must know the related requirements of all above approval agency. and forget to find an easy way, do it step by step, and try to be familiar with their requirements. and try to creat good relationship with those agencies, after that, you can try to push those agencies to help you deal with your case as soon as possible cause you have good relationship with those agencies. But if finally, you don't wanna do it by yourself, you can find a third party which can help you to do the above certifications for you, but that means much more money will be spared, and you can not learn more and have no improvement, furthermore, you can not control the certification progress sometimes, so make a conclusion that, you should try to do it by yourself, maybe at the beginning, it's a little difficult, but after you know it, it will be easy, and money can be saved , as well you also can be improved quickly....
 楼主| 发表于 2011-10-6 13:26:51 | 只看该作者
谢谢楼上的介绍,虽然英语看的很累:)
GMT+8, 2026-11-30 16:10 , Processed in 0.027716 second(s), 18 queries , Gzip On.
