查看: 1044|回复: 6
EARTH CONTINUITY TEST (ROUTINE TEST) FOR EN60335
发表于 2007-9-4 20:25:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
A.1 Earth continuity test
A current of at least 10 A, derived from a source having a no-load voltage not exceeding 12 V
(a.c. or d.c.), is passed between each of the accessible earthed metal parts and
– for class 0I appliances, and for class I appliances intended to be permanently
connected to fixed wiring, the earthing terminal;
– for other class I appliances,
• the earthing pin or earthing contact of the plug;
• the earthing pin of the appliance inlet.
The voltage drop is measured and the resistance is calculated and shall not exceed
– for appliances having a supply cord, 0,2 Ω, or 0,1 Ω plus the resistance of the supply
cord,
– for other appliances, 0,1 Ω.
NOTE 1 The test is only carried out for the duration necessary to enable the voltage drop to be measured.
NOTE 2 Care is to be taken to ensure that the contact resistance between the tip of the measuring probe and the
metal part under test does not influence the test results.
发表于 2007-11-20 04:17:43 | 只看该作者
Very useful ,thanks
发表于 2007-11-21 14:51:25 | 只看该作者
great
very good
thanks
发表于 2008-1-1 14:41:56 | 只看该作者
Good and thanks for sharing
发表于 2008-3-25 21:21:25 | 只看该作者
Thank you for your sharing!!
发表于 2008-9-5 15:56:55 | 只看该作者
thank you very much !
发表于 2008-9-6 14:57:27 | 只看该作者
thank you very much
GMT+8, 2026-11-30 16:55 , Processed in 0.043398 second(s), 18 queries , Gzip On.
