查看: 768|回复: 6
客人评语
发表于 2011-10-4 17:27:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
General comments:
1、lace cord is missing on all styles
2、the bottom band & cuffs are not in the same color of body -pls make sure you do them in exact color as body
3、pls make sure that prints color will be as colors on color pallet
Girl style 39
1 pls add lurex to the front print -add lurex also on star
2 pants print is too big -pls do 20% smaller
Boy style 31
1 the melange of the bottom band is not the same as melange of body
2 the RACING should be 15% bigger and also should not be cut on the letter C -see attached photo
Boy style 41
1 the print should be 20% bigger
2 the ball is not cut nicely on zipper - see attached photo
3 the lable on kangaroo pocket is too big!! pls do 3CM
大家看看哦
发表于 2011-10-4 17:27:45 | 只看该作者
General comments:
1、lace cord is missing on all styles所有款式的花边绳无
2、the bottom band & cuffs are not in the same color of body -pls make sure you do them in exact color as body下摆带以及克夫与大身面料的颜色不同。请确保与正确的大身面料颜色一致。
请确保印花颜色与色样中颜色中一致
Girl style 39女款39
1 pls add lurex to the front print -add lurex also on star 卢勒克斯加于大身印花以及星形处
2 pants print is too big -pls do 20% smaller裤子印花过大,缩小20%
Boy style 31男款31
1 the melange of the bottom band is not the same as melange of body 裤带混色与大身的混色不一致
RACING应增大15%,不应在字母处裁剪(见附件照片)
Boy style 41男款41
1 the print should be 20% bigger印花应增大20%
2 the ball is not cut nicely on zipper - see attached photo拉链球形处裁剪的线条不完美(见附件照片)
3 the lable on kangaroo pocket is too big!! pls do 3CM袋鼠袋处商标太大,只要3cm。
以上仅供参考
发表于 2011-10-4 17:28:44 | 只看该作者
General comments:(一般评语:)
1、lace cord is missing on all styles所有款式的花边绳无(所有款漏花边绳)
2、the bottom band & cuffs are not in the same color of body -pls make sure you do them in exact color as body 下摆带以及克夫与大身面料的颜色不同。请确保与正确的大身面料颜色一致。(下摆和克夫的颜色与大身颜色不同,请确保他们的颜色与大身颜色一致)
3、pls make sure that prints color will be as colors on color pallet 请确保印花颜色与色样中颜色中一致
Girl style 39 女款39
1 pls add lurex to the front print -add lurex also on star 卢勒克斯加于大身印花以及星形处(前身印花和星形处加卢勒克斯线)
2 pants print is too big -pls do 20% smaller 裤子印花过大,缩小20%
Boy style 31 男款31
1 the melange of the bottom band is not the same as melange of body 裤带混色与大身的混色不一致(脚边混色与大身混色不一致)
RACING应增大15%,不应在字母处裁剪(见附件照片)——RACING应该放大15%,同时不要在字母C处裁切(见附件照片)
Boy style 41 男款41
1 the print should be 20% bigger 印花应增大20%(印花应放大20%)
2 the ball is not cut nicely on zipper - see attached photo 拉链球形处裁剪的线条不完美(见附件照片)——拉链球形处裁切得不好(见附件照片)
3 the lable on kangaroo pocket is too big!! pls do 3CM 袋鼠袋处商标太大,只要3cm。
以上仅供参考
发表于 2011-10-17 11:51:33 | 只看该作者
牛啊!
发表于 2011-10-17 12:06:04 | 只看该作者
跟样衣的人猪啊
发表于 2011-11-1 16:28:19 | 只看该作者
原帖由 cpsha 于 2011-10-17 12:06 发表
跟样衣的人猪啊
说的好!
发表于 2011-11-2 15:57:40 | 只看该作者
真的是牛人啊
GMT+8, 2026-11-6 14:47 , Processed in 0.322025 second(s), 19 queries , Gzip On.
