查看: 768|回复: 2
工艺要求及辅料用法
发表于 2011-10-4 15:17:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
GENERAL INSTRUCTION:
1) Fabric content & weight:面料成份及重量
Outer :Knitted 65/35 Poly/Cotton Fleece. Fabric wt: 285g/M2面布:T/C拉绒布,285g/M2
Hood lining : knitted cotton jersey DTM 帽里:单面汗布同大身色
All fabrics must be soft hand feel. Shrinkage max. 5% 所有的面料必须手感柔软,最大缩率:5%
2) Hood /Neck 帽子/领
Self hood, with HALF seams at top. No topstitching. Hood tunnel 1” width, with single topstitching. With 3/8” (inner measured) embossed eyelets (V-14 Antique Silver color ) opening at front. With 5/8” flat drawcord. With tipped at end. With ¼” single topstitching at neck seam. 本布连帽,帽顶缝线没有压明线,领缝线压0.6cm单线,帽缝2.54cm宽。打金属刻字鸡眼,用1 .3CM扁拉绳,在带尾打结领里斜纹织带1CM宽。
3) Front zipper Full front zipper, DTM # 5 nylon zipper. With branded VI zipper puller (V15 Antique Silver). Concealed zipper closure. With ¼” edge topstitching. With 2” Inner zipper facing. 前中车拉链,面压0.6cm明线,做5cm挂面
4) Neck seam tape DTM cotton twill neck seam tape. 3/8” wide. With edge topstitching. 领里斜纹织带1CM宽,随大身色
5) Inner Neck Patch No. 领窝处无要求
6) Sleeves/cuffs Long sleeves, with 1x1DTM lycra rib cuff (2 ply), with flat lock topstitching at cuff seam. 长袖,用1*1莱卡罗纹袖口,袖口锁边压线
7) Sweep With 1x1 DTM lycra rib waistband. (2 ply), with flat lock topstitching at bottom hem. 下摆用1*1莱卡罗纹腰带,锁边压线
8) Armholes Raglan armholes, no topstitching. 连肩袖笼,无压线
9) Pouch Pocket
- Pouch pocket with extended flat lock topstitching at top edge and side seams. (Normal shape)
- Pocket opening 1” self-turn, with ¼” double topstitching 钱包口袋四周拷边,口袋口反折2.54cm,压0.6cm双针
With bar tack at stress points.
LABELLING INSTRUCTION:
Neck woven label:主标(针织) Center at inner neck 0.5” below neck seam,Stitched flat all edges.车于后领缝下1.3cm中间,四周拷边
Size woven labe 尺码标 Size label to be stitched at the base of main label at center, colors/text matching main label 尺码标车在主标中间
Hangtag- By 3” plastic pin with price ticket (Randy River) through size label 吊牌:用7.6cm塑料大头针穿过尺码标和价格牌上
Care label Updated 2005 洗唛:同2005年做法
‘Slim Fit’ Hangtag - Tagged with ‘VI’ hangtag and price ticket at size label VI吊卡,尺码唛带价格牌
请指正
另外:想问一下坎车、拷边、锁边是不是一样的说法?
 楼主| 发表于 2011-10-4 15:17:16 | 只看该作者
大家可否多发点相关工艺跟辅料用法这方面的资料上来,这样也可以多学学哦!
发表于 2011-10-4 15:18:02 | 只看该作者
原帖由 janice 于 2007-6-21 10:34 发表
最近超级忙啊
我手上也有一点类似的工艺单
等过了这段时间
我也会整理好发上来的
GMT+8, 2026-11-6 12:11 , Processed in 0.026932 second(s), 18 queries , Gzip On.
