查看: 680|回复: 6
QC MANUAL的social compliance &safety requirements请大家帮忙
发表于 2011-10-3 17:36:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1.1 SOCIAL COMPLIANCE
**source all of its product on a world wide basis. with an international spread of supply it is important that our business strives to ensure fair and responsible employment and environmental practices are followed wherever in the world it is purchasing from
Our business is committed to ensuring that this policy is implemented and adhered to in all its sourced manufacturing operations. The policy is seen as setting a minimum standard and will be used as a platform from which to increase standards and conditions wherever possible.
The policy has been drawn up in line with the ethical trading initiative code and will be applied along with the local country law (the laws being the minimum standard for purchase).
The policy is as follows:
Workforce rights
? to have no employees below the legal age for employment in the country in which the unit is operating, and, as a means to improvement, work towards no employees under 15 years of age.
? All employees will have the right to collective representation within the legal framework of the country in which they work.
? There will be equality of opportunity, with no discrimination on the basis of sex, race, religion or age.
? There will be no use made of forced, bonded or involuntary labour.
? All employees will be treated with respect and their health, safety and basic human rights will be protected and promoted.
? Adequate and timely training will be provided for everyone for the job for which they are employed.
? A fair days wage for a fair days work. Work rates will reflect the rates in the sector in the country in which it is operating.
? Working hours will comply with national regulations, including overtime. All overtime worked will be voluntary and paid at a premium rate.
Environment
Operations will comply with all relevant legislation
Implementation of the **social compliance policy
All sites are monitored on an ongoing basis and action plans agreed for those units that need improvement. All units that do not comply with the e.t.i. base code will have a plan of action to work towards it.
Safety requirements
*Ensure no obstacles are blocking passageways or exits and areas in between production lines.
*fire exits clearly marked. Fire escape route must be posted on a wall in an obvious place where all employees can see it.
*ensure all work stations are well lit.
*all potentially dangerous objects must be controlled within the factory environment.
*it is advisable that scissors and clippers are secured to the work benchex.
All suppliers must have a documented needle control system in place in all factories.listed below are the key requirements of the needle control procedure:
*all new needles to be kept in a secure place with only nominated employees being given responsibility to issue them.
Spare needles are not allowed anywhere else in the factory e.g. on machines.
When a new needle is issued, to replace a damaged one, a document must be completed by the person responsible showing:
Date
Operator
Style number of garments being stitched
Confirmation the original needle, whether whole or in parts, is found(if the whole needle is not found, the bundle of work being sewn should be removed from the working area, and examined thoroughly for broken needle parts).
The document will confirm the action taken and must be signed accordingly.
All broken needle parts to be collected together and disposed of safely.
发表于 2011-10-3 17:37:06 | 只看该作者
不会吧,这么长,哪有这么长时间给你翻译呀,这里面的内容其实就是客人天书里面有关社会责任与产品安全方面的条文,不是很复杂的,特别是对于QA职位(验厂评厂)是小菜一碟,他们天天打交道,你随便找QA验厂的文件,找其中的社会责任与产品安全方面的部分,差不多就是它的中文版了。
发表于 2011-10-3 17:37:12 | 只看该作者
~好久没有做过这作业了,来一次
QC MANUAL的
social compliance &safety requirements社会责任与安全要求
1.1 SOCIAL COMPLIANCE社会责任
**source all of its product on a world wide basis. with an international spread of supply, it is important that our business strives to ensure fair and responsible employment and environmental practices are followed wherever in the world it is purchasing from
~由于产品及供应的全球化,对我们的事业来说,非常重要的是.明确要求当地企业保证公平的就业环境及对社会负责任的雇工环境,保证符合有环保要求;
在所有的业务相关方面,我们始终执行并坚持这一政策
~该政策可以作为一个最低标准,并以此为基准在可以的地方(时候)加以提升标准和条件
~该政策已被编入e.t.i.code(???),并与当地法律同时适用(法律将作为交易原则的基准)
相关内容如下:
Workforce rights
工人权益:
运作中的公司(工厂)不使用当地法规规定的未适龄员工,进一步说,就是没有15岁以下之员工(童工)
在该地法律允许的情况下,所有员工有权表达他们的集体请求.
保证平等的就业机会,没有任何基于性别,种族,宗教或年龄等方面的歧视.
不存在强迫劳动,押扣工钱和非自愿劳工等
所有雇员一应平等对待,并且他们的健康和安全能够得到保障和加强,他们的基本人权应得到保护和提升.
相关职位的员工能够得到足够和及时的培训和技能提升.
每个人都应答得到公平的劳动报酬,并且他们的收入可以反映该地的基本收入情况.
工作时间应遵循当地法规,包括加班时间;加班必须是自愿加班并且应得到额外的收入补偿.
Environment 工作环境
公司需遵守相关法律法规
执行当地的相关社会责任政策
所有的工作场所都必须得当监控(有些不恰当???)对于提出要做响相应改进的必须有相关的实际计划.
所有不合e.t.i。。.base code的都必须有确实的改进行动计划
Safety requirements安全方面要求
确保生产线内过道及太平门和逃生区域民没有任何障碍阻挡
~火场逃生指示清楚标识,火灾逃生线路需张贴于所有人可以见到的明显位置上.
~确保各岗位照明足够
~工作场合内所有具潜在危险的物品需按要求严格保障
~建议刀剪等可以在工作椅上安全安置以保安全
厂内需有文字档案说明的车针存放及使用操作系统,以下为一些关键要求
~新的车针必须存放在安全的地方并由专人发放使用
多余的车针不允许乱放,如放在机器上
当车针损坏要更换的时候,必须由专人发放并作好包含以下内容的记录:
Date 时间
Operator操作人
Style number of garments being stitched所有于的款号
确保原车针,完整与否,都被找出(否则的话该员工所在车的货需整堆搬出车间,然后仔细查找到把破坏的针找出来)
该档案需有相关人员的签名以证实交接完整
所有破损的车针需收集在一起并得到安全的处置
~大致如上,供参考,
~好久没作这样长的了,有点累(:-
发表于 2011-10-3 17:37:38 | 只看该作者
好像是验厂用的,有的大客户在确定供应商之前要验厂的。
发表于 2011-10-3 17:37:56 | 只看该作者
呵呵,感谢3楼DJ~
真难为你这么用心的翻译
这种长篇,其实大部分可以自己解决,剩下的零散的解决不掉的可以拿上来..建议而已
这样节约大家都时间..
发表于 2011-10-3 17:38:02 | 只看该作者
你好厉害,我看到这么多都有点晕。努力!!!!!!!!!
发表于 2011-10-3 17:38:08 | 只看该作者
佩服,简直五体投地!
GMT+8, 2026-11-6 11:15 , Processed in 0.345049 second(s), 18 queries , Gzip On.
