查看: 484|回复: 1
不理解1
发表于 2011-9-28 20:48:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
carton perforations
all cartons must have perforations. These perforations are in a rectangle pattern,4mm*2mm.
However, at certain positions around the rectangle, there should be 35mm unperforated gaps.
The postioning of these 35mm gaps are at the 12,3,6 and 9 positions of the rectangle.
发表于 2011-9-28 22:07:08 | 只看该作者
纸箱穿孔所有纸箱必须都有穿孔。矩形图案,4 * 2 毫米的小孔。然而,在某些位置到矩形周围,应该有 35 毫米 unperforated 的差距。这些 35 毫米的间隙的铸锭是 12,3,6 和矩形的 9 个职位。
(可能不完全对,仅作参考)
GMT+8, 2026-11-6 07:24 , Processed in 0.194491 second(s), 18 queries , Gzip On.
