查看: 669|回复: 0
压脚的中英文对照
发表于 2011-9-28 19:38:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
来源:http://bbs.51fashion.com.cn/dispbbs.asp?boardid=2&Id=122521
1. 高低压脚(compensating feet):用于锁边,上贴袋,可选择两用的,左边高的,或右边高的。
Used for edge stitching, setting patch pockets. Can come in with double side, left side, right side.
2. 隐形拉链压脚(invisible zipper feet):用于车缝隐形拉链,可调整宽窄。
Used for setting invisible zippers. Can come in wide and narrow
3. 底边龙头,可折叠两次(hemmer feet double fold):口是开的,所以较厚处与缝处可以轻易通过,宽度可调整。
Open mouth to allow thickness and seams to pass through freely. Can come in wide and narrow
4. 止口压脚(right Hinge feet):单针缉明线时使用,有不同宽度的型号。例如:1/4",3/8",1/2"。
Used for single needle top stitching. Comes in with a variety of widths. 1/4", 3/8", 1/2" are examples.
5. 可旋转的底边龙头(swing hemmer):用于衬衫下摆卷边。在特殊弹力的作用下,面料可以轻易通过卷边器。
Used to hem a shirt tail type bottom. Fabric can pass through with ease due to special spring.
6. 单边压脚(piping/cording feet):用来上绳子与嵌条。弧形底边将可固定嵌条的位置,有不同宽度的型号。
Used to set piping and cording. Groove bottom holds piping in place. Comes in an adjustable foot and widths, bottom groove widths.
7. 拉链压脚(zipper feet regular hinge):用于上闭尾拉链,开尾拉链。间距很窄时也可以使用此类压脚。
Used for setting fly front zippers, kissing zippers. Also can be used when need a narrow space.
8. 其余压脚还有:
滚轮压脚(roller feet)
滚边压脚(binding feet)
折边压脚(hemming and folding feet)
导带压脚(tube feet)
GMT+8, 2026-11-6 06:20 , Processed in 0.128334 second(s), 19 queries , Gzip On.
