查看: 568|回复: 3
请教高手翻译
发表于 2011-9-25 00:26:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Method of dyeing: reactive + AZO-free
Colour fastness allowance
Nickelfree
Max shrinkage 3%
Pantone numbers mentioned are TCX
For packing: no handwriting is allowed & cartons should be filled to capacity
but without undue compression.
It is extremely important that the carton should not bulge.
Polybags only P/E accepted with ventilation holes closed with 2 cellotapes.
It's not allowed to ship broken assortments.
Use plastic 'reinforcement' ring behind all onmetal press-and jeansbuttons on all woven fabrics from which the weight is less than 10 oz (or 339gsm).
发表于 2011-9-25 00:28:18 | 只看该作者
好吧,只能翻译一部分.剩余的请再补充.
Method of dyeing: reactive + AZO-free 染色方式: 活性染料染色.
Colour fastness allowance 色牢度没有很苛刻的要求
Nickelfree
Max shrinkage 3% 缩率3%以内.应该指的面料吧
Pantone numbers mentioned are TCX 潘通色卡用的是TCX卡.
For packing: no handwriting is allowed & cartons should be filled to capacity 关于包装: 不允许手写,不允许亏箱
but without undue compression. (似是关于承重的,不太清楚)
It is extremely important that the carton should not bulge. 尤其重要的是,纸箱不能变型,胀出
Polybags only P/E accepted with ventilation holes closed with 2 cello tapes. 塑料袋只接受PE的. 且有两个透气孔.(位置就不清楚了)
It's not allowed to ship broken assortments. 不允许分批出货?
发表于 2011-9-25 10:26:40 | 只看该作者
支持。。。。。。。。。
发表于 2011-9-25 10:32:24 | 只看该作者
顶一下。。。。
GMT+8, 2026-11-6 08:15 , Processed in 0.312783 second(s), 19 queries , Gzip On.
