查看: 5021|回复: 6
面料:T400是什么东西?
发表于 2011-9-24 23:35:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
棉/T400
T400是什么东西?
发表于 2011-9-24 23:36:34 | 只看该作者
梭织布种类,好像是纱类的。。
 楼主| 发表于 2011-9-24 23:37:37 | 只看该作者
不知是不是某种技术?
发表于 2011-9-24 23:39:13 | 只看该作者
不是.是400根.
thread 400的缩写.
发表于 2011-9-24 23:39:48 | 只看该作者
哦,准确的说,应该是不是100%确定的一种纱支结构.织物组织不确定,确定的是经纬纱加起来是400.
发表于 2011-9-26 22:50:01 | 只看该作者
是一种涤纶纤维,具有一定的弹性!
Elasterell (officially "elasterell-p") is an alternative to the generic name "polyester" for a specific subclass of inherently elastic, multicomponent textile fibers.
The Federal Trade Commission (FTC) has issued a final rule which establishes the name. Elasterell was originally manufactured by E.I. du Pont de Nemours and Company and previously referred to as "T400". The FTC states that because this material is arguably comparable to other multicomponent polyester fibers, other companies that manufacture fibers satisfying the definition of "elasterell-p" may use that name in making required fiber content disclosures on labels.
The FTC is defining "elasterell-p" as fiber formed by the interaction of two or more chemically distinct polymers (of which none exceeds 85% by weight) which contains ester groups as the dominant functional unit (at least 85% by weight of the total polymer content of the fiber) and which, if stretched at least 100%, durably and rapidly reverts substantially to its unstretched length when the tension is removed.
发表于 2011-9-26 22:50:56 | 只看该作者
AATCC 标准 可以出“elasterell-p”
GB、ISO 出 “elastomultiester”对应中文“新型合成纤维(聚酯弹力纤维)”
欧盟指令:2007/3/EC 指令:针对96/74/EC附录1及2中的纤维名称作修正,并将“elastomultiester”列为纤维名称。
GMT+8, 2026-11-6 07:25 , Processed in 0.103589 second(s), 19 queries , Gzip On.
