查看: 1147|回复: 3
求助. 长条型箱 和 非6面型箱 的摔箱方法
发表于 2007-9-3 11:29:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
怎么摔啊, 比如 500x20x20cm或者是梯型,多边型箱.
谢谢
发表于 2007-9-3 13:08:25 | 只看该作者
Perform the drop test, in according with height prescribed on point 5, in the following sequence;
1
Test the corner of most fragile face that is near to the manufacture’s joint.
2
The shortest edge radiating from the corner tested.
3
The next Longest edge from the corner tested.
4
The Longest edge from the corner tested
5
Flat on one of the smallest face.
6
Flat on the opposite small face.
7
Flat on one of the medium faces.
8
Flat on the opposite medium face.
9
Flat on one of the largest faces.
10.
Flat on the opposite large face.
发表于 2007-9-3 17:05:42 | 只看该作者
附件对外箱的形状不同有作不同有要求,这个非常标准的,仔细学习下就可以知道如何作的了,它分为不同的类型,也有你说的这种,所以要看你的外箱情况决定你的摔箱方式!http://bbs.wtoqc.net/forum.php?mod=viewthread&tid=1252
参与人数 1金币 +8 威望 +6 收起 理由
gcitony + 8 + 6 你很热情
 楼主| 发表于 2007-9-3 17:10:16 | 只看该作者
回复 #3 micah 的帖子
基于现场验货,我们能做到哪些呢?
GMT+8, 2026-7-31 09:38 , Processed in 0.059207 second(s), 19 queries , Gzip On.
