查看: 821|回复: 6
求教:2011版EN71检测报告中标识怎么处理?
发表于 2011-9-11 09:28:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
EN 71-1:2011版中,CE标识、制造商名称地址等已经不是EN 71-1标准的强制要求,但这些标识仍应符合2009/48/EC。那么,当客户要求出具2011版的EN 71检测报告时,是不是应该加入对2009/48/EC的标识判定才能算是完整报告呢?还是直接无视标识,仅按照EN 71标准判定即可?
大家都是怎么处理的呢?多谢啦~
发表于 2011-9-11 09:29:17 | 只看该作者
看客人申请的是什么
发表于 2011-9-11 09:29:52 | 只看该作者
回覆
7 Warnings, markings and instructions for use (see A.33)
NOTE The text of this note is for information only and the indents do not constitute requirements of this standard. The
information is not exhaustive and Directive 2009/48/EC and the associated guidance documents should be consulted for
further details.
? Toys made available on the market shall bear the CE marking. The CE marking shall be subject to the general
principles set out in Article 30 of Regulation (EC) No 765/2008. The CE marking shall be affixed visibly, legibly and
indelibly to the toy, to an affixed label or to the packaging. In the case of small toys and toys consisting of small parts,
the CE marking may alternatively be affixed to a label or an accompanying leaflet. Where, in the case of toys sold in
counter displays, that is not technically possible, and on condition that the counter display was originally used as
packaging for the toy, the CE marking may be affixed to the counter display. Where the CE marking is not visible
from outside the packaging, if any, it shall as a minimum be affixed to the packaging. Where specific legislation does
not impose specific dimensions, the CE marking shall be at least 5 mm high.
? The manufacturer’s 1 name, registered trade name or registered trade mark and the address at which the
manufacturer can be contacted shall be indicated on the toy or, where that is not possible, on its packaging or in a
document accompanying the toy. This requirement applies also to the name and address etc. of any importer2.
? Manufacturers shall ensure that their toys bear a type, batch, serial or model number or other element allowing their
identification, or where the size or nature of the toy does not allow it, that the required information is provided on the
packaging or in a document accompanying the toy.
? Manufacturers and importers shall ensure that the toy is accompanied by instructions and safety information in a
language or languages easily understood by consumers, as determined by the Member State concerned.
? A Member State may, within its territory, stipulate that warnings and safety instructions shall be written in a language
or languages easily understood by consumers, as determined by that Member State.
 楼主| 发表于 2011-9-11 09:30:30 | 只看该作者
只好这样了,现在好多没有标识的产品,只判EN 71合格总觉得不甘心啊,呵呵
发表于 2011-9-11 09:31:06 | 只看该作者
呵呵
但是你可以给客人建议
发表于 2011-9-11 09:31:28 | 只看该作者
不是强制性要求如果没有这些标识可以不测吧?
发表于 2011-9-11 09:32:06 | 只看该作者
直接做一个*号,然后在最后面把那段内容打进去。
GMT+8, 2026-10-17 11:54 , Processed in 0.059357 second(s), 19 queries , Gzip On.
