查看: 587|回复: 1
UL778中的绝缘材料厚度要求?
发表于 2011-9-6 21:38:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
17.3.3 An insulated lining or barrier of vulcanized fiber or similar material used where a spacing would
otherwise be less than the minimum shall not be less than 1/32 inch (0.8 mm) thick and shall be so located
or of such material that it will not be adversely affected by arcing.
Exception No. 1: Vulcanized fiber not less than 1/64 inch (0.4 mm) thick may be used in conjunction with
an air-spacing of not less than 50 percent of the minimum through-air spacing.
Exception No. 2: Insulating material thinner than that specified may be used if investigated and found to
be acceptable for the application.
UL778,17.3.3章节有提到绝缘材料厚度为0.8mm。是否相反极性间的绝缘材料厚度也按此要求,还是没有要求?
谢谢哦!
发表于 2011-9-7 08:18:41 | 只看该作者
知道的回复一下。。。。。。。。。。
GMT+8, 2026-11-30 13:57 , Processed in 0.035730 second(s), 18 queries , Gzip On.
