查看: 745|回复: 3
第三方检测报告OK,但客户自己测试样品失败
发表于 2011-9-5 22:18:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有一产品英国插座做CE认证,第三方检测OK,也拿到了CE证书,但客户自己拿样品做测试失败,不知道为何.下面为具体测试事项,请大家帮忙看下.
测试项目绝缘测试.测试标准如下.
BS7288 的第8.7章节的第A项 between all incoming terminals of poles in turn with the s,r.c,d contacts closed. if an auxiliary source or electronic control curcuit is required to closed the contacts this maybe disconnected .
客户的报告是这样的:
when measured between the incoming live and neutral terminals,and with the s.r.c.d contacts closed.the insulstion resistance was found to be only 0.13 M, while the standard requires a mininum of 0.5M ,this is considered to be due to the electronic components within the circuit and therefore not a safity issue.
发表于 2011-9-5 22:20:02 | 只看该作者
英式插座怎么会做CE?是不是标没清晰
发表于 2011-9-5 22:20:26 | 只看该作者
不好意思,是不是标准没清晰
发表于 2011-9-5 22:21:00 | 只看该作者
你查看一下第三方的测试报告,看上面怎么描述,结果是多少
GMT+8, 2026-11-30 13:57 , Processed in 0.026756 second(s), 18 queries , Gzip On.
