查看: 1321|回复: 8
PSE关于A类B类产品划分
发表于 2011-9-4 20:08:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
List of Specified Electrical Appliances and Materials 115 items (Category A)
Appendix 1 (related to Article 1, Paragraph 2 and Article 2 of the Cabinet Order)
No.ItemsTerm of Validity
1Cables and Cords (limited to those having a rated voltage of not less than 100 V but not more than 600V) as noted below:
1) Non-sheathed rigid cables as noted below (limited to those having conductors of nominal cross sectional area of 100 mm2 or less.):
(1) Rubber-insulated non-sheathed cables (including those with synthetic rubber insulations) Seven (7) years
(2) Synthetic resin insulated non-sheathed cables (excluding the items noted in Appendix 2-1.1)) Seven (7) years
2) Rigid cables (limited to those having conductors of nominal cross-sectional areas of 22 mm2 or less, having cores composed of seven strands or less, and having sheaths of rubber [including synthetic rubber] or synthetic resin)Seven (7) years
3) CordsSeven (7) years
4) Sheathed flexible cables (limited to those having conductors of nominal cross-sectional areas of 100 mm2 or less and having cores composed of seven strands or less)Seven (7) years
2Fuses as noted below (limited to those with a rated voltage of not less than 100 V but not more than 300 V, for use in alternating current circuits):
1) Thermal linksSeven (7) years
2) Other fuses (limited to those with s rated current of not less than 1 A but not more than 200 A [fuses for electrical motors are limited to those used with motors rated 12 kW or less], and fuses specified in Appendix 2-3 and quick-acting fuses for semiconductor protection are excluded)Seven (7) years
3Wiring devices as noted below (limited to those with a rated voltage of not less than 100 V but not more than 300 V [in the case of lampholders for fluorescent lamps, a rated voltage is not less than 100 V but not more than 1,000 V], for use in alternating current circuit. Explosion proof and oil-filled types are excluded.):
1) Tumbler switches, cord switches, time switches and other switches (limited to those with a rated current of 30A or less. Switches specified in Appendix 2-4.1) and those specially designed switches incorporated in electrical appliances are excluded.)Seven (7) years
2) Switching devices as noted below (limited to those with a rated current of 100 A or less [switching devices for electric motors are limited to those for motors rated 12 kW or less], and those specially designed devices incorporated in appliances are excluded.):
(1) Box type switches (including covered switches) Seven (7) years
(2) Float switches Seven (7) years
(3) Pressure switches (limited to those with rated operating pressure of 294 kPa or less) Seven (7) years
(4) Controllers for a sewing machine Seven (7) years
(5) Breakers used for wiring Seven (7) years
(6) Earth leakage circuit breakers Seven (7) years
3) Cutouts (limited to those with a rated current of 100 A or less and which are equipped with link fuses or plug fuses)Seven (7) years
4) Connecting devices and their fittings as noted below (limited to those with a rated current of 50 A or less, having five or fewer terminals, and including devices having switching mechanisms other than a time switch mechanism):
(1) Push-in plugs and receptacles (excluding those specified in Appendix 2-4.3), and those specially designed to be incorporated in appliances) Seven (7) years
(2) Screw plugs and receptacles (excluding specially designed ones to be incorporated in appliances) Seven (7) years
(3) Sockets (excluding those specially designed to be incorporated in appliances other than lighting fixtures) Seven (7) years
(4) Rosettes Seven (7) years
(5) Joint boxes Seven (7) years
4Current limiters (limited to those having a rated voltage of not less than 100 V but not more than 300 V, and having a rated current of 100 A or less, and in any case to be used in alternating current circuits)Seven (7) years
5Single-phase small power transformers and discharge lamp ballasts as noted below (limited to those with a rated primary voltage [a rated voltage in the case of discharge lamp ballasts other than voltage transformers] of not less than 100 V but not more than 300 V, and with a rated frequency ratings [in the case of those with double frequency ratings, either one of these frequencies in appliances. Hereinafter the same] of 50 Hz or 60 Hz, and in any case to be used in alternating current circuits):
1) Single-phase small power transformers as noted below (limited to those with rated capacities of 500 VA or less)
(1) Transformers for household appliances (excluding those specified in (2) below, those specified in Appendix 2-5.1) (1) and (5), and those specially designed to be incorporated in appliances) Seven (7) years
(2) Transformers for use in electronic appliances (limited to power voltage transformers with rated capacity exceeding 10 VA, but excluding those specially designed to be incorporated in appliances) Seven (7) years
2) Discharge lamp ballasts as noted below (limited to those used with discharge lamps having a total rated power consumption of 500 W or less):
(1) Fluorescent lamp ballasts (excluding those specially designed to be incorporated in appliances other than electrical lighting fixtures) Seven (7) years
(2) Mercury vapor lamp ballasts and other high voltage discharge lamp ballasts (excluding those specially designed to be incorporated in appliances other than electrical lighting fixtures) Seven (7) years
(3) Transformers for ozone generators Seven (7) years
6Heating appliances as noted below (limited to those with a rated voltage of not less than 100 V but not more than 300 V and a rated power consumption of 10 kW or less for use in alternating current circuits):
1) Electric heated toilet seats.Five (5) years
2) Electric heating hot cupboardsFive (5) years
3) Electric water pipe freeze-prevention heaters, glass dew-prevention heaters and other electric heating appliances for prevention of freezing or condensationSeven (7) years
4) Electric storage water heatersFive (5) years
5) Electric inhalators and other household electric heating therapeutic appliances (excluding those noted Appendix 2-7.57)Five (5) years
6) Electric steam baths and electric heaters for steam bathsFive (5) years
7) Electric sauna baths and electric heaters for sauna bathsFive (5) years
8) Electric aquarium heatersFive (5) years
9) Electric terrarium heatersFive (5) years
10) Electric heated toysFive (5) years
7Electric motor-operated appliances as noted below (limited to those with a rated voltage of not less than 100 V but not more than 300 V and rated frequency of 50 Hz or 60 Hz, for use in alternating current circuits):
 楼主| 发表于 2011-9-4 20:08:39 | 只看该作者
1) Electric pumps (limited to those with rated power consumption of 1.5 kW or less, but excluding the item noted in Appendix 2-8. 65), vacuum pumps, oil pumps, sand pumps or other pumps specially designed to be incorporated in appliances)Five (5) years
2) Electric refrigerating or freezing showcases (limited to those incorporating cooling units with a rated power consumption of 300 W or less)Five (5) years
3) Ice-cream freezers (limited to those using electric motors with a rated power consumption of 500 kW or less)Five (5) years
4) Electric food waste disposers (limited to those with a rated power consumption of 1 kW or less)Five (5) years
5) Electric massagersFive (5) years
6) Electric washing and drying toiletsFive (5) years
7) Vending machines (limited to those incorporating heating units, cooling units, discharge lamps, or liquid containers, but excluding those used for dispensing tickets)Five (5) years
8) Electric bubble-generating machines (limited to those with a rated power consumption of 100 W or less if used outside bathtubs)Three (3) years
9) Electric motor-operated toys and other electric motor-operated recreational apparatus (excluding those noted in Appendix 2-8.69))Five (5) years
8High-frequency depilators (limited to those having a rated voltage of not less than 100 V but not more than 300 V, a rated high-frequency output of 50 W or less and a rated frequency of 50 Hz or 60Hz, for use in alternating current circuits)Three (3) years
9Electric appliances using AC power supply other than those listed in the foregoing items 2 through 8 inclusive as noted below (limited to those having a rated voltage of not less than 100 V but not more than 300 V and a rated frequency of 50 Hz or 60 Hz)
1) Magnetic therapeutic apparatusThree (3) years
2) Electric insect killersFive (5) years
3) Electric therapeutic bath controllersFive (5) years
4) DC power supplies (including those for concurrent use with AC power and limited to those with rated capacity of 1 kVA or less, but excluding those for test use with wireless transmitters or having other special construction)Five (5) years
10Portable generators having a rated voltage of not less than 30 V but not more than 300 V Five (5) years
http://www.meti.go.jp/english/policy/economy/consumer/pse/index.html
http://www.meti.go.jp/english/policy/economy/consumer/pse/02.htm
 楼主| 发表于 2011-9-4 20:08:49 | 只看该作者
Appendix 2 (related to Article 1)
No.Items
1Cables, cords and heating cables as noted below:
1) Non-sheathed rigid cables as noted below (limited to those having conductors of nominal cross-sectional area of 100 mm2 or less):
(1) Fluorescent lamp cables
(2) Neon tube cables
2) Rigid cables (limited to those with a rated voltage of not less than 100 V but not more than 600V, having conductors of nominal cross-sectional area of exceeding 22 mm2 but not more than 100 mm2 or less, having cores composed of seven strands or less, and having sheaths of rubber [including synthetic rubber], or of synthetic resin)
3) Floor heating cables
2Wireways, fittings, and cable wiring switch boxes as noted below (excluding those constructed of copper or bronze, or explosion-proof types):
1) Conduits (limited to those with inner diameter of 120 mm or less including flexible conduits)
2) Underfloor ducts (limid to those with a width of 100 mm or less)
3) Raceways (limited to those with a width of 50 mm or less)
4) Fittings of conduits (limited to those connected to the conduits noted in 1) above, the underfloor ducts noted in 2) above, and the raceways noted in 3) above, or those connected to the ends of said conduits, underfloor ducts, or raceways, but excluding reducers)
5) Cable wiring switch boxes
3Fuses as noted below (limited to those having a rated voltage of not less than 100 V but not more than 300 V and those having a rated current of not less than 1 A but not more than 200 A [in the case of fuses for electrical motors, limited to those used with motors rated 12 kW or less], for use in alternating current circuits)
1) Cartridge fuses
2) End contact plug fuses
4Wiring devices as noted below (limited to those having a rated voltage of not less than 100 V but not more than 300 V for use in alternating current circuits, but excluding explosion proof and oil-filled types):
1) Remote control relays (limited to those having a rated current of 30 A or less, and excluding those specially designed to be incorporated in appliances)
2) Switching devices as noted below (limited to those having a rated current of 100 A or less [in the case of switches for electrical motors, limited to those used with motors rated 12 kW], but excluding those specially designed to be incorporated in appliances):
(1) Cutout switches
(2) Covered knife switches
(3) Panelboard unit switches
(4) Electromagnetic switches (limited to those contained in enclosures which either have overcurrent disconnection mechanisms, or include fuses)
3) Lighting tracks and their fittings (limited to those used for connecting said lighting tracks, or connected to their terminal ends), and lighting track connectors (limited to those having a rated current of 50 A or less, having 5 or fewer terminals, and including a switching mechanism other than a time switch mechanism)
5Single-phase small power transformer voltage regulators, and discharge lamp ballasts as noted below (limited to those with a rated primary voltage [or in the case of discharge lamp ballasts other than voltage transformers, a rated voltage] of not less than 100 V but not more than 300 V and a rated frequency of 50 Hz or 60 Hz, and intended for use in alternating current circuits):
1) Single-phase small power transformers, as noted below (limited to those with rated capacities of 500 VA or less):
(1) Transformers for bells (excluding those specially designed to be incorporated in appliances)
(2) Transformers for indicators (excluding those specially designed to be incorporated in appliances)
(3) Transformers for remote control relays (excluding those specially designed to be incorporated in appliances)
(4) Transformers for neon tubes (excluding those specially designed to be incorporated in appliances)
(5) Transformers for lighters (limited to those for use in lighters, and excluding pulse types)
2) Voltage regulators (limited to those having a rated capacity of 500 VA or less, but excluding those specially constructed as part of a machine or other tool)
3) Discharge lamp ballasts as noted below (limited to those for use with applicable discharge tubes having a total rated power consumption of 500 W or less):
(1) Sodium vapor lamp ballasts (excluding those specially designed to be incorporated in appliances other than electrical lighting fixtures)
(2) Germicidal lamp ballasts
6Small A.C. motors as noted below (limited to those with a rated frequency of 50 Hz or 60 Hz, but excluding those of pole-transforming type or explosion-proof type, those of special construction for use in spinning machines, in metal rolling machines, or in medical therapeutic apparatuses, and those specially designed to be incorporated in appliances other than sewing machines)
1) Single-phase A.C. motors (limited to those with a rated voltage of not less than 100 V but not more than 300 V)
2) Squirrel-cage three-phase induction motors (limited to those with a rated voltage of not less than 150 V but not more than 300 V and with a rated output of 3 kW or less, but excluding those with short-time ratings)
7Heating appliances as noted below (limited to those with a rated voltage of not less than 100 V but not more than 300 V, and a rated power consumption of 10 kW or less, for use in alternating-current circuits):
1) Electric footwarmers and electric slippers
2) Electric knee rugs
3) Electric floor cushions
4) Electric carpets
5) Electric underblankets, electric blankets and electric comforters (Futon)
6) Electric ‘anka’
7) Electric seat chair covers and electric heated chairs
8) Electric ‘kotatsu’
9) Electric room heaters
10) Japanese electric heaters (Hibachi) and other electric heating appliances for body heating purposes (excluding the items noted in Appendix 1-6.1) and incubating appliances with electric heating apparatuses)
11) Electric toasters
12) Electric ovens
13) Electric fish roasters
14) Electric roasters
15) Electric ranges
16) Electric buffet ranges
17) Electric sausage roasters
18) Electric waffle irons
19) Electric ‘takoyaki’ griddles
20) Electric cooking hot plates and electric frying pans
21) Electric rice cookers and electric jars
22) Electric deep frying pans
23) Electric fryers
24) Electric boiled egg makers
25) Electric warming boards
26) Electric warm serving trays
27) Electric milk warmers, electric kettles, electric coffee makers and electric tea servers
28) Electric ‘sake’ warmers
29) Electric bains marie
30) Electric steamers
31) Induction cooking appliances and other electric heating appliances for cooking purpose (Excluding the items noted in Appendix 1-6.2))
32) Electric hot water heaters for shaving
33) Electric curling irons and electric hair curlers
34) Electric hair steamers and other electric heating appliances for skin or hair care
35) Electric heated knives
36) Electric melters
37) Electric pottery kilns
38) Electric soldering irons, electric heaters for irons and other electric heating tools for handwork or handicraft
39) Electric hot hand towel steamers
40) Electric sterilizers (limited to those with electric heating elements)
41) Electric humidifiers
42) Electric clothes steamers
43) Electric immersion heaters
44) Electric instantaneous water heaters
45) Thermostatic developing trays
46) Electric heating boards, electric heating floor sheets and electric heating floor mats
47) Electric dryers
48) Electric clothes pressers (limited to those used for textile products)
49) Electric plant nurseries
50) Electric egg incubators
51) Electric brooders
52) Electric irons
53) Electric flatirons
54) Electric plastic welders (excluding high-frequency welders)
55) Electric incense burners
56) Electric insecticide vaporizers
57) Electric moxibustion appliances
 楼主| 发表于 2011-9-4 20:08:59 | 只看该作者
No.Items
8Electric motor-operated appliances as noted below (limited to those with a rated voltage of not less than 100 V but not more than 300 V and a rated frequency of 50 Hz or 60 Hz, for use in alternating current circuits):
1) Belt conveyors (limited to portable types)
2) Electric refrigerators and electric freezers (limited to those incorporating cooling units with a rated power consumption of 500 W or less)
3) Electric ice makers (limited to those incorporating cooling units with a rated power consumption of 500 W or less)
4) Electric water coolers (limited to those incorporating cooling units with a rated power consumption of 500 W or less)
5) Electric air compressors (limited to those with a rated power consumption of 500 W or less, but excluding those specially designed to be incorporated in appliances)
6) Electric sewing machines
7) Electric pottery wheels
8) Electric pencil sharpeners
9) Electric stirring machines (limited to those with a rated power consumption of 500 W or less)
10) Electric scissors
11) Electric insect traps
12) Electric grass shears and electric hedge trimmers
13) Electric lawn mowers
14) Agricultural apparatuses as noted below:
(1) Electric decorticators, electric rice hulling machines, electric straw dampers, and electric straw-rope making machines
(2) Electric egg selectors and egg washers
15) Electric garden cultivators
16) Electric sea-tangle (Konbu) processors and dried squid processors (limited to those with a rated power consumption of 500 W or less)
17) Electric juice squeezers, juice blenders, and food processors (limited to those using electric motors with a rated power consumption of 500 W or less)
18) Electric noodle makers (limited to those using electric motors with a rated power consumption of 500 W or less)
19) Electric rice cake (Mochi) makers (limited to those using electric motors with a rated power consumption of 500 watts or less)
20) Electric coffee mills (limited to those with a rated power consumption of 500 W or less)
21) Electric can openers
22) Electric mincers, electric meat choppers and electric bread slicers (limited to those with a rated power consumption of 1 kW or less)
23) Electric dried bonito planers (limited to those with a rated power consumption of 500 W or less)
24) Electric ice flakers (limited to those with a rated power consumption of 500 W or less)
25) Electric rice washers (limited to those with a rated power consumption of 1 kW or less)
26) Electric vegetable washers (limited to those with a rated power consumption of 1 kW or less)
27) Electric dishwashers (limited to those using electric motors with a rated power consumption of 500 W or less)
28) Electric rice polishers (limited to those with a rated power consumption of 500 W or less)
29) Electric tea leaf roasters (limited to those using electric motors with a rated power consumption of 500 W or less)
30) Electric wrapping machines and electric packaging machines (limited to those with a rated power consumption of 500 W or less)
31) Electric table clocks and electric wall clocks
32) Automatic print fixing baths and automatic print washers (limited to those with a rated power consumption of 500 W or less)
33) Electric office machines as noted below:
(1) Electric mimeograph machines, office printing machines (limited to those for printing materials of not more than 515 mm in width, and of not more than 364 mm in width), and addressing machines
(2) Time recorders and time stamps
(3) Electric typewriters
(4) Electric account selectors
(5) Electric shredders and paper cutters
(6) Electric collators
(7) Electric staplers, paper punchers, and numbering machines
(8) Electric check writers, coin counters and bill counters
(9) Electric label-tagging machines
34) Laminators
35) Electric laundry finishing machines and laundry folding machines
36) Electric hand towel rolling machines (limited to those using electric motors with a rated power consumption of 500 W or less)
37) Vending machines (excluding those noted in Appendix 1-7.7) and those for issuing tickets) and money changers
38) Electric barber chairs
39) Electric toothbrushes and electric brushes
40) Electric hair dryers, electric shavers, electric hair clippers, electric nail polishers, and other electric motor-operated appliances for skin or hair care
41) Electric room fans and circulation fans (limited to those with a rated power consumption of 300 W or less)
42) Ventilation fans (limited to those with a rated power consumption of 300 W or less)
43) Blowers (limited to those with a power consumption of 500 W or less, and excluding those specially designed to be incorporated in appliances)
44) Electric air conditioners (limited to those whose motors have a total rated power consumption of 7 kW or less, and in the case of the items having a heating device, limited to those whose heating elements have a rated power consumption of 5 kW or less)
45) Electric cooled air fans (limited to those with a rated power consumption of 300 W or less)
46) Electric dehumidifiers (limited to those incorporating cooling units having a rated power consumption of 500 W or less)
47) Electric fan coil units and fan convectors (limited to those with a rated power consumption of 30 W or less)
48) Electric hot-air heaters (limited to those with a rated power consumption of 500 W or less, and using gas or oil as a heat source)
49) Electric fan-forced air heaters (limited to those incorporating heating elements with a rated power consumption of 5 kW or less)
50) Electric humidifiers (limited to those incorporating motors with a rated power consumption of 500 W or less)
51) Electric air cleaners (limited to those with a rated power consumption of 500 W or less)
52) Electric deodorizers
53) Electric fragrance diffusers
54) Electric vacuum cleaners, electric record cleaners, electric blackboard eraser cleaners and other electric dust absorbers (limited to those with a rated power consumption of 1 kW or less)
55) Electric floor polishers (limited to those with a rated power consumption of 1 kW or less)
56) Electric shoe polishers
57) Electric washing machines for sports goods or recreational goods (limited to those using electric motors or electromagnetic vibrators with a rated power consumption of 1 kW or less)
58) Electric washing machines (limited to those using electric motors or electromagnetic vibrators with a rated power consumption of 1 kW or less)
59) Electric spin extractors (limited to centrifugal types using electric motors with a rated power consumption of 1 kW or less, and used for extracting water from textile products)
60) Electric tumbler dryers (limited to those with a rated power consumption of 10 kW or less, but excluding hair dryers)
61) Electric musical instruments
62) Electric music boxes
63) Electric bells, buzzers, chimes and sirens (excluding explosion-proof types and those specially designed to be incorporated in appliances)
64) Electric grinders, electric drills, electric planes, electric saws, electric screwdrivers and other electric power tools (limited to those with a rated power consumption of 1 kW or less)
65) Electric fountains
66) Electric mist sprayers (limited to those with a rated power consumption of 1 kW or less)
67) Electric inhalators
68) Household electric motor-operated therapeutic apparatuses (excluding those noted in Appendix 1-7.5))
69) Electric game machines
70) Electric warm-water circulating/cleaning equipment for a bath (so called 24-hour operation whirlpool bath, limited to those incorporating heating elements with a rated power consumption of 1.2 kW or less)
 楼主| 发表于 2011-9-4 20:09:22 | 只看该作者
No.Items
9Luminaires and optical appliances and machines as noted below (limited to those with a rated voltage of not less than 100 V but not more than 300 V, and a rated frequency of 50 Hz or 60 Hz, for use in alternating current circuits):
1) Photographic printers
2) Microfilm readers (limited to those with a screen of 500 mm or less in length, and excluding those equipped with automatic search devices, or automatic continuous printing devices)
3) Slide projectors and overhead projectors (excluding those for use with television or those using a xenon-arc lamphouse as the light source)
4) Episcopes (limited to those with a rated power consumption of 2 kW or less, but excluding those for use with television, or those using a xenon-arc lamphouse as the light source)
5) Viewers
6) Electronic flash apparatuses (limited to portable types with a rated accumulated power capacity of 1.5 kWs or less, and excluding those for use in microscopes or medical equipment, or those having other special construction)
7) Photographic enlargers and photographic enlarger lamphouses (limited to those having openings for negative holders of 125 mm or less in length and 100 mm or less in width, and in the case of photographic enlargers, excluding those equipped with automatic exposure devices or automatic photographic paper feeders)
8) Incandescent lamps (limited to those for general illumination use, with outer receptacle diameters of not less than 26.03 mm but not more than 26.34 mm)
9) Fluorescent lamps (limited to those with a rated power consumption of 40 W or less)
10) Pedestal lighting fixtures, household pendant fluorescent lamp lighting fixtures, hand lamps, garden lighting fixtures, decorative lighting fixtures (limited to those using capless lamps or having sockets with inner receptacle diameter of 15.5 mm or less) or other incandescent lamp lighting fixtures and discharge lamp lighting fixtures (excluding explosion-proof type)
11) Advertisement lamps
12) Egg testers
13) Electric sterilizers (limited to those equipped with sterilizing lamps)
14) Household therapeutic ray apparatuses
15) Rechargeable flashlights
16) Copying machines (limited to those whose light source has a rated output of 1.2 kW or less)
10Electronic appliances, as noted below (limited to those having a rated voltage of not less than 100 V but not more than 300 V and a rated frequency of 50 Hz or 60 Hz for use in alternating current circuits):
1) Electronic clocks
2) Electronic tabletop calculators and electronic cash registers
3) Electronic refrigerators
4) Interphones
5) Electronic musical instruments
6) Radio receivers, tape recorders, record players, juke boxes and other audio equipment
7) Video tape recorders
8) Demagnetizers
9) Television receivers (excluding industrial-use television receivers)
10) Television receiver boosters
11) High frequency welders (limited to those with a rated high-frequency output of 2.5 kW or less)
12) Microwave ovens
13) Ultrasonic rat exterminators
14) Ultrasonic humidifiers (limited to those with a rated high frequency output of 50 W or less)
15) Ultrasonic cleaners (limited to those with a rated high frequency output of 50 W or less)
16) Electronic recreational apparatuses (limited to those used by connection to a television receiver, or those equipped with a cathode ray tube)
17) Household low frequency therapeutic apparatuses
18) Household ultrasonic therapeutic apparatuses and household ultrashort wave therapeutic apparatuses (limited to those with a rated high-frequency output of 50 W or less)
11A.C. appliances and machines other than those listed in the foregoing items 3 to 10, inclusive, and using alternating current, as noted below (limited to those having a rated voltage of not less than 100 V but not more than 300 V, and a rated frequency of 50 Hz or 60 Hz):
1) Furniture with lamps, furniture with socket outlets, and furniture equipped with other electrical appliances
2) Electric light dimmers (limited to those with a rated capacity of 1 kVA or less)
3) Electric pencils
4) Leakage current detectors
5) Burglar alarms
6) Arc welding machines (limited to those having a rated secondary current of 130 A or less if the rated voltage exceeds 150 V)
7) Radio interference suppression devices (limited to those which prevent the transmission of a highfrequency current that causes noise in television receivers or radio receivers and consisting of capacitors or a combination of capacitors and coils as main components and excluding those with a rated current exceeding 5 A, and those specially designed to be incorporated in appliances)
8) Producers of medical materials
9) Household electric-potential therapeutic apparatuses
10) Electric refrigerators (limited to absorption types)
11) Electric fence energizers
发表于 2011-9-4 20:09:36 | 只看该作者
甲类产品(Category A Product)改为特定电气用品(Specified Electrical Appliance and Material),贴于产品三角形T-mark改为菱形PSE mark,并需标示认可实验室之名称(如JET、JQA等)。原电取法规定之产品种类,由165项再减为113项。而乙类产品(Category B Product)则改为非特定用品,需贴圆形PSE mark(性质类似CE mark)。原电取法规定之产品种类,由333项再增为343项。此类立产品亦需向日本经济产业省 (Ministry of Economy, Trade and Industry简称METI)取得注册ID。特定与非特定产品在PSE系统 中的主要差异,特定与非特定产品在PSE系统中的主要差异,在于强制性认证产品需由指定之实验室发“适合性同等检查合格书”即PSE证书,而自愿认证产品只需持有一般实验室之测试报告,便可向METI申请注册。
发表于 2011-9-4 20:09:59 | 只看该作者
想再請問樓主, 對日本的那麼熟悉的話, 那麼現在燈具及電源供應器的規範是以何為依, 我們申請時需注意那些項目, 或是尚需申請CB來轉換報告呢, 請樓主賜教, 感謝
发表于 2011-9-4 20:10:30 | 只看该作者
A类电气用品目录
特定电气用品目录(120种)
电气用品名称 电气用品名称 电气用品名称
[电线]
[橡胶绝缘电线类]
●橡胶绝缘线
●电缆(导体的公称横截面面积在22mm2以下者)
●单心橡胶电线
●绞合橡胶电线
●袋状编织橡胶电线
●圆形编织橡胶电线
●其他橡胶电线
●橡皮绝缘软线
●橡胶绝缘软性电缆
●乙烯绝缘软性电缆
[合成树脂类绝缘电线]
●合成树脂类绝缘电线
●单心乙烯电线
●单心聚氯乙烯电线(新追加项目)
●绞合乙烯电线
●袋状编织乙烯电线
●圆形编织乙烯电线
●其他乙烯电线
●其他的聚氯乙烯电线(新追加项目)
●软电线
●丝包铜线
●乙烯绝缘软性电缆
[保险丝]
●温度保险丝
●带接线片保险丝
●管状保险丝
●其他封闭式保险丝
[配线器材]
●翻转开关
●中间开关
●定时开关
●旋转式开关
●按纽式开关
●拉线式开关
●悬吊式开关
●路灯开关
●光电式自动切换开关
●其他切换开关
●闸式开关
●浮动开关
●压力开关
●缝纫机用控制器
●配线用断路器
●漏电断路器
●切断开关
●插入式插头
●固定插座
●带两对插口以上的插座
●拖板插座
●熨斗插座
●电器用插入式插头
●转接器
●电线卷筒
●其他插入式连接器
●管座
●连接插头体
●其他螺口式连接器
●荧光灯用灯口
●荧光灯用灰色启动器插座
●分路灯口
●无开关灯口
●防水灯口
●开关灯口
●拉线灯口
●按钮灯口
●其他灯口
●螺口接线盒
●卡口接头接线盒
●其他接线盒
●接线箱
[限流器]
●安培计量制限流器
●定额计量制限流器
[变压器、镇流器]
●玩具用变压器
●其他家用电器用变压器
●荧光灯用镇流器
●水银灯用镇流器及其他高压放电灯用镇流
●臭氧发生器用镇流器
●电子应用机械器具用变压器
[电热器具]
●电热便座
●电热保温箱
●水管冻结器
●其他冻结及凝固防止用的电热器具
●玻璃结露防止器
●电热水器
●电热式吸入器
●家庭用温热治疗器
●电蒸汽浴缸
●蒸汽浴用电热器
●观赏鱼用加热器
●观赏植物用加热器
●电热式玩具
[电动应用机械器具]
●电泵
●电动井泵
●冷藏用陈列橱
●冷冻用陈列柜
●冰激凌冷冻机
●垃圾处理器
●电动按摩器
●自动冲洗干燥式便器
●自动售货机
●浴槽用电动气泡发生器电动式玩具
●电动车
●其他电动应用游戏器具
[电子应用机械器具]
●高频脱毛器
[其他交流电用电机械器具]
●磁疗器
●电击杀虫器
●电舆洗器具用电源装置
●直流电源适配器
[便携式发电机]
●便携式发电机
B类电气用品目录
非特定电气用品目录(340种)
电线
[橡胶绝缘电线类]
●电缆(导体的公称横截面面积在22mm2以上者)
●电焊电缆
●电热地板用导热电线
●[合成树脂类绝缘电线]
●荧光灯电线
●霓虹灯电线
●电焊电缆
●电热地板用导热电线
电线管
[金属材料电线管类]
●金属材料电线管
●一级金属材料可弯折性电线管
●二级金属材料可弯折性电线管
●金属制地面延长线槽
●一级金属制导线管
●二级金属制导线管
●金属制器具与电线管间的连接器
●金属器具与电线管间连接用直角弯管
●金属肘形弯管
●金属直角支管
●金属十字管
●大型金属管的套管
●金属制电线管间连接器
●金属接线箱
●小型金属套管
●其他电线管类或可弯折性电线管
●合成树脂制电线管
●合成树脂制可弯折性电线管
●CD管
●合成树脂等材料的器具与电线管间的连接器
●合成树脂等材料的直角弯管
●合成树脂等材料的肘形弯管
●合成树脂等材料的连接器
●合成树脂等材料的接线箱
●合成树脂等材料的小型套管
●合成树脂等材料的大型套管
●其他电线管类或可弯折性电线管的合成树脂等材料的附件
●电缆配线用开关箱
保险丝
●筒形保险丝
●插头式保险丝(旧称:栓形插头式保险丝)
配线器具
●遥控继电器
●断路开关
●带盖闸刀开关
●配电盘组合开关
●电磁开关
●电源母线用延长线槽
●电源母线用延长线槽用器具与电线间的连接器
●电源母线用延长线槽用肘形弯管
●电源母线用延长线槽用直角枝管
●电源母线用延长线槽用十字管
●电源母线与延长线槽的导电部间的连接器
●电源母线用延长线槽终端镇定套
●电源母线用延长线槽用插头
●电源母线用延长线槽用转接器
变压器、镇流器
●电铃用变压器
●显示器用变压器
●遥控继电器用变压器
●霓虹灯变压器
●燃烧器具用变压器
●稳压器
●钠蒸气灯用镇流器
●杀菌灯用镇流器
小型交流电动机
●推斥起动感应电动机
●分相起动感应电动机
●电容起动感应电动机
●电容感应电动机
●整流子电动机
●短路环感应电动机
●其他单相电动机
电热器具
●脚踏电暖器
●电热拖鞋
●膝盖电热盖毯
●电热坐毯
●电热地毯
●电热床垫
●电热毛毯
●电热褥子
●点燃???脚炉
●电热椅子套
●电热椅子
●电热???被炉
●电炉
●电火盆
●其他采暖用电热器具
●烤面包电炉
●电烤炉
●电热烤鱼器
●电烘烤器
●电微波炉
●电炉灶
●电热香肠烧烤器
●压模式电热烤饼器
●电热章鱼丸子圆饼烧烤器
●???电热烧烤饭
●电平底锅
●电饭煲
●电保温锅
●电锅
●电油炸锅
●煮蛋器
●电保温盆
●电加热台
●电奶锅
●电热水器电热咖啡壶
●电热茶壶
●电热温酒壶
●低温热水保温煲
●电蒸锅
●电磁感应加热式烹调器
●其他烹调用电热器具
●剃须用热水器
●电烫发钳
●卷发器
●头发加湿器
●其他理发美容用电热器具
●电热刀
●电溶解器
●小型电烤炉
●电烙铁
●烙铁加热器
●其他做工用或工艺用电热器具(旧称其他做工、工艺用电热器具)
●毛巾蒸锅
●电消毒器(电热装置)
●湿润器
●电气热水熨斗
●简易式热水用电热铁
●瞬时电热水器
●显象恒温器
●电热板
●电热踏板
●电热脚垫
●电干燥器
●电缝纫用小型熨斗
●电热压模器
●电香炉
●电熏蒸杀虫器
●电温炙器
电动应用机械器具
●传送带
●电冰箱
●电冰柜
●电制冰器
●电冷水机
●空气压缩机
●电动缝纫机
●电动粘土转盘
●电动转笔刀
●电动搅拌机
●电剪
●电捕虫机
●电动割草机
●电动剪枝机
●电动剪草机
●电动打谷机
●电磨
●电动打麦机
●电动搓绳机
●选蛋机
●洗蛋机
●园艺用电动耕地机
●海带加工机
●榨汁器
●乌贼干加工机
●水果切碎机
●食物切碎机
●电动面条机
●年糕制作机
●咖啡豆研磨机
●电动罐头起子
●电动绞肉机
●电动切肉机
●电动切面包机
●电动刨冰机
●电动淘米机
●蔬菜清洗机
●电动洗碗机
●碾米机
●包装机
●手巾把包装机
●捆包机
●电动座钟
●电动挂钟
●照片自动定影机
●照片自动冲洗机
●油印机
●业务用印刷机
●信封印刷机
●计时器
●计时打卡机
●电动打字机
●帐票分类机
●文件切碎机
●电动裁纸机
●订书机
●打孔机
●号码机
●支票印字器
●硬币计数机
●纸币记数机
●标签张贴机
●电动压模机
●洗净后衣物装袋机
●手巾板卷包机
●自动售货机(除特定电气用品外)
●钱币兑换机
●电动理发椅子
●电动牙刷
●电动刷子
●电吹风
●电动剃须刀
●电推子
电子应用机械器具
●电子钟
●电指甲磨光机
●其他理发美容用电动应用机械器具
●电扇
●环流风机
●换气机
●鼓风机
●电冷气机
●电冷风机
●电除湿机
●空调装置
●风扇式环流机
●热风暖气机
●电热风机
●电加湿机
●空气清洁机
●电动除臭机
●电动防扩散机
●电动吸尘器
●电动唱片吸尘器
●电动擦黑板器
●其他电动吸尘器
●电动地板磨光机
●电动鞋刷
●运动器材或娱乐用具的清洗机
●电动洗衣机
●电动甩干机
●电动干燥器
●电动乐器
●电动八音盒
●电铃
●蜂鸣器
●门铃
●警报器
●电动打磨器
●电钻
●电刨
●电锯
●电动螺丝起子
●电动砂轮机
●电动磨光机
●电动去锈机
●电动攻丝机
●电动螺母紧固机
●电动磨刀机
●其他电动工具
●电喷水机
●电喷雾机
●电动式吸入器
●指压按摩代用器
●其他家用电动应用治疗器
●电动游戏盘
●浴槽用电热温水循环净化器(新追加项目)
(通称:24小时浴缸)
光源应用机械器具
●照片洗印机
●缩微胶卷读片器
●幻灯机
●字幕片放映机
●反射投影机
●读片器
●电子闪光灯
●照片放大机
●照片放大机用光源
●白炽灯泡
●荧光灯泡
●台灯
●家庭用悬吊式荧光灯灯具
●提灯
●庭院灯具
●圣诞节灯串
●其他白炽灯灯具
●其他放电灯灯具
●广告灯
●照蛋器
●电消毒器(杀菌灯)
●家庭用光疗仪
●充电式手提灯
●复印机
●台式电子计算器
●电子金钱出纳机
●电子式冰箱
●带门铃的对讲机
●电子乐器
●无线电收音机
●录音机
●电唱机
●投币式自动电唱机
●其他音响机器
●录象机
●退磁装置
●电视接收机
●电视接收用增幅器
●高频焊机
●电子微波炉
●超声波驱鼠器
●超声波加湿机
●超声波洗净器
●电子应用游戏器具
●家庭用低频治疗仪
●家庭用超声波治疗仪
●家庭用超短波治疗仪
其他交流电用电气机械器具
●带电灯的???家具
●带插座的家具
●带其他电气机械器具当然家具
●调光器
●电动铅笔
●漏电探测器
●防盗警报器
●电弧焊接机
●防噪声干扰机
●医疗用微生物、细胞等的培养器
●家庭用电位治疗仪
●电冰箱(吸收式)
●通电栅栏用电源装置
发表于 2011-9-5 09:38:05 | 只看该作者
还是中文的给力,收藏了,谢谢分享。
GMT+8, 2026-11-30 13:57 , Processed in 0.032125 second(s), 18 queries , Gzip On.
