查看: 892|回复: 5
验货用语资料
发表于 2011-9-1 11:08:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
成品检验Checking of finished products
  检验,检查inspection, check
  商检commodity inspection
  领面松wrinkles at top collar
  领面紧top collar appears tight
  领面起泡crumples at top collar
  领外口松collar edge appears loose
  领外口紧collar edge appears tight
  底领伸出collar band is longer than collar
  底领缩进collar band is shorter than collar
  底领里起皱wrinkles at collar band facing
  底领外露collar band lean out of collar
  倘领偏斜collar deviates from front center line
  领窝不平creases below neckline
  后领窝起涌bunches below back neckline
  驳头起皱wrinkles at top lapel
  驳头反翘top lapel appears tight
  驳头外口松lapel edge appears loose
  驳头外口紧lapel edge appears tight
  驳口不直lapel roll line is uneven
  串口不直gorge line is uneven
  领卡脖tight neckline
  领离脖collar stand away from neck
  小肩起皱puckers at shoulders
  塌肩wrinkles at shoulder
  袖隆起皱creases at underarm
  袖隆缝起皱puckers at underarm seam
  塌胸lack of fullness at chest
  省尖起泡crumples at dart point
  拉链起皱wrinkles at zip fly
  止口不直front edge is uneven
  止口缩角front edge is out of square
  止口反翘front edge is upturned
  止口反吐facing leans out of front edge
  止口豁split at front edge
  止口下部搭叠过多crossing at front edge
  底边起皱wrinkles at hem
  后身起吊back of coat rides up
  背衩豁开split at back vent
  背衩搭叠过多crossing at back vent
  绗棉起皱puckers at quilting
  絮棉不均padded cotton is uneven
  边缘缺棉empty hem
  绱袖不圆顺diagonal wrinkles at sleeve cap
  袖子偏前sleeve leans to front
  袖子偏后sleeve leans to back
  前袖缝外翻inseam leans to front
  袖口起皱wrinkles at sleeve opening
  袖里拧diagonal wrinkles at sleeve lining
  袋盖反翘top flap appears tight
  袋盖反吐flap lining leans out of edge
  袋盖不直flap edge is uneven
  袋口角起皱creases on two ends of pocket mouth
  袋口裂split at pocket mouth
  腰头探出end of waistband is uneven
  腰缝起皱wrinkles at waistband facing
  里襟里起皱creases at right fly
  夹裆tight crotch
  短裆short seat
  后裆下垂slack seat
  前浪不平wrinkles at front rise
  裆缝断线bursting of crotch seam
  裤脚前后two legs are uneven
  脚口不齐leg opening is uneven
  吊脚pulling at outseam or inseam
  烫迹线外撇crease line leans to outside
  烫迹线内撇crease line leans to inside
  腰缝下口涌bunches below waistline seam
  裙裥豁开split at lower part of skirt
  裙身吊split hem line rides up
  裙浪不匀skirt flare is uneven
  线路偏移stitch seam leans out line
  双轨接线stitch seam is uneven
  跳针skipping
  尺码不符off size
  缝制不良stitching quality is not good
  洗水不良washing quality is not good
  熨烫不良pressing quality is not good
  极光iron-shine
  水渍water stain
  锈迹rust
  污渍spot
  色差color shade, off shade, color deviation
  褪色fading, fugitive color
  线头thread residue
  毛头raw edge leans out of seam
  绣花不良embroidery design out line is uncovered
发表于 2011-9-1 13:19:07 | 只看该作者
这个已经发过了。论坛里面已经有了。
发表于 2011-9-1 14:09:57 | 只看该作者
支持一下。。。
发表于 2011-9-4 08:16:42 | 只看该作者
论坛里面已经有了。
; 谢谢你的热情。。
发表于 2011-9-7 15:06:45 | 只看该作者
good
hehe
good
发表于 2011-9-7 15:58:31 | 只看该作者
楼主辛苦了,学习了
GMT+8, 2026-11-5 17:49 , Processed in 0.169451 second(s), 18 queries , Gzip On.
