查看: 927|回复: 5
TJX DROP TEST
发表于 2011-8-31 09:40:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
跟大家分享一下。A. ISTA-1A modified for TJX
This procedure covers testing of ALL individual packaged-products. It needs to be tested at inner level if store ready packed, if not, then at master carton level.
The drop test consists of a ‘10 free fall drop sequence test’ from heights that vary with weight as follows:
Imperial System[size=10.0000pt]
[size=10.0000pt]
Metric System[size=10.0000pt]
Packaged-Product Weight[size=10.0000pt]
Drop Height[size=10.0000pt]
[size=10.0000pt]
Equal or greater than[size=10.0000pt]
But Less Than[size=10.0000pt]
Free Fall[size=10.0000pt]
[size=10.0000pt]
lb[size=10.0000pt]
lb[size=10.0000pt]
in.[size=10.0000pt]
[size=10.0000pt]
kg[size=10.0000pt]
kg[size=10.0000pt]
cm[size=10.0000pt]
[size=10.0000pt]0[size=10.0000pt]
61[size=10.0000pt]
18[size=10.0000pt]
[size=10.0000pt]
28[size=10.0000pt]
46[size=10.0000pt]
61[size=10.0000pt]
100[size=10.0000pt]
12[size=10.0000pt]
[size=10.0000pt]
28[size=10.0000pt]
45[size=10.0000pt]
31[size=10.0000pt]
100[size=10.0000pt]
[size=10.0000pt]-[size=10.0000pt]
[size=10.0000pt]8[size=10.0000pt]
[size=10.0000pt]
45[size=10.0000pt]
20[size=10.0000pt]
file:///C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ksohtml\wps_clip_image-8885.png
The test must be performed in following order:
a. Most fragile corner, if not known, at the carton manufacturer's joint
b. Shortest edge radiating from that corner
c. Medium edge radiating from that corner
d. Longest edge radiating from that corner
e. Flat on one of the smallest faces
f. Flat on the opposite small face
g. Flat on one of the medium faces
h. Flat on the opposite medium face
i. Flat on one of the largest faces
j. Flat on the opposite largest face
发表于 2011-8-31 10:15:45 | 只看该作者
谢谢分享。。。。。。。。
发表于 2011-8-31 10:39:20 | 只看该作者
谢谢分享。。。
发表于 2011-8-31 10:44:30 | 只看该作者
谢谢分享。。。
发表于 2011-8-31 11:37:16 | 只看该作者
摔箱测试。
发表于 2011-9-4 21:44:21 | 只看该作者
很多家都在做TJX啊
GMT+8, 2026-10-17 11:54 , Processed in 0.030185 second(s), 19 queries , Gzip On.
