查看: 2388|回复: 20
常见中英文对照表
发表于 2011-8-12 10:52:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
contamination杂色/混点
cracking爆裂
corner raised up角位翘起
blister cover surface scratched吸塑面花
blister edge warped吸塑边曲
blister lift up at edge position吸塑边翘起
“volume” control button not workable音量按键无功能
earphone with rustling sound (sound distorted) and working intermittently耳塞沙沙声及间断
earphone sound obvious not balance between two side when being played耳塞大细声
ear buds sound not balance between 2 sides when being played耳塞轻微大细声
earphone sound not workable of one side耳塞一边无声
one ear bud not workable (no sound)耳塞一边无声
“music” and “voice” button not workable
收音及播音无功能
“music” and “beats” button not workable收音及播音无功能 - Microphone
“music” and “beats” with sound distorted when being played播放音乐及收音时有杂音
sound weak when being played声弱
“music” and “voice” sound undertone细声
rattling (something inside loosened)内响
projecting light not work投灯不着
projected image could not be clearly shown影像矇
focus lens inside dirty
镜内污
focus lens inside with waste substance镜内有杂物
projected image with shadow
影像有阴影
focusing image with shading镜头不能聚焦
switch too tight to operate开关紧
“on” and “off” switch loosened开关制松
plastic casing found with rift机壳离嚹
plastic casing hinge slightly loosened机壳较位松
battery insulate plastic strap tight to pull out
绝缘片紧
 楼主| 发表于 2011-8-12 10:55:28 | 只看该作者
paintion over sprayed
飞油
paiting smudged油污
painting - drop积油
clasp not workable and loosened扣无功能自动弹开
clasp not workable and deformed无功能及变形
base warped手柄座弯
wooden block with color nuance木仔色差 / 深浅色
wooden block cannot turn and play木仔不能转动
wooden block not smooth to turn and play木仔转动不顺畅
wooden block painting smudged
木块油污
wooden painting rubbed off
木块掉色
wooden block assemblem in wrong sequence木仔次序装错
wooden block painting misregistration木仔图案套印不准
surface slightly chipped表面崩
plastic shaft / plastic rail胶支架
slightly chipped at edge position边轻微崩
song play speed abnormal(3 seconds faster)歌曲稍快
excessive flash retained披锋未清
“guitar” with flash not trimmed披锋未清
frog’s mouth cannot be closed normally (malfunctioning)开合时青蛙头不会自动弹回
frog ratchet with 2 ratchet sound when being triggered青蛙发声两声(样办发四声)
ratchet sound weak青蛙发声哑
surface painting sprayed not to the position喷油不到边
no ratchet sound emitted when being triggered青蛙嘴合上时无卡卡声
joint found with rift (screw not firmly fixed)离嚹(镙丝未收紧)
pitted spots沙眼.起粒
painting light in color
喷油不够,溥, 少
发表于 2011-8-12 11:04:42 | 只看该作者
thanx ^^^66
发表于 2011-8-12 12:36:24 | 只看该作者
路过看看。
发表于 2011-8-12 12:50:19 | 只看该作者
支持无私奉献精神。。
发表于 2011-8-12 13:07:28 | 只看该作者
非常感谢楼主的分享!
发表于 2011-8-12 15:18:41 | 只看该作者
谢谢分享。。。。
发表于 2011-8-12 15:33:16 | 只看该作者
谢谢!!!!!!!!!!!!!!!!!!!!!!!
发表于 2011-8-12 17:02:37 | 只看该作者
路过看看···
发表于 2011-8-12 19:25:17 | 只看该作者
有用,,记下,
GMT+8, 2026-11-30 15:18 , Processed in 0.031294 second(s), 18 queries , Gzip On.
