查看: 1703|回复: 15
免费分享 DIN EN ISO GB 对照表
发表于 2011-7-20 16:30:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
新德标
旧德标
英文名
中文名
国标
DIN EN ISO 4014
DIN 931-1
Hexagon head bolts - Product grades A and B(ISO 4014:1999)
六角头螺栓
GB/T 5782-2000
DIN EN ISO 4016
DIN 601
Hexagon head bolts - Product grade C(ISO 4016:1999)
六角头螺栓 C级
GB/T 5780-2000
DIN EN ISO 4017
DIN 933
Hexagon head screws - Product grade A and B (ISO 4017:1999)
六角头螺栓 全螺纹
GB/T 5783-2000
DIN EN ISO 4018
DIN 558
Hexagon head screws - Product grade C (ISO 4018:1999)
六角头螺栓 全螺纹 C级
GB/T 5781-2000
DIN EN ISO 8676
DIN 961
Hexagon head screws with metric fine pitch thread - Product grade A and B(ISO 8676:1999)
六角头螺栓 细牙 全螺纹
GB/T 5786-2000
DIN EN ISO 8765
DIN 960
Hexagon head bolts with fine pitch thread - Product grades A and B(ISO 8765:1999)
六角头螺栓 细牙
GB/T 5785-2000
DIN EN ISO 4032
DIN 934
Hexagon nuts,style 1-Product grades A and B(ISO: 4032:1999)
1型六角螺母
GB/T 6170-2000
DIN EN ISO 4033
Hexagon nuts,style 2-Product grades A and B(ISO: 4033:1999)
2型六角螺母
GB/T 6175-2000
DIN EN ISO 4034
DIN 555
Hexagon nuts - Product grade C (ISO 4034:1999)
六角螺母 C级
GB/T 41-2000
DIN EN ISO 4035
DIN 439-2
Hexagon thin nuts(chamfered)-Product grade A and B (ISO 4035:1999)
六角薄螺母
GB/T 6172.1-2000
DIN
EN ISO 4036
DIN 439-1
Hexagon thin nuts - Product grade B(unchamfered)(ISO 4036:1999)
六角薄螺母 无倒角
GB/T 6174-2000
DIN EN ISO 8673
DIN 934| DIN 971-1
Hexagon nuts,style 1,with metric fine pitch thread - Product grades A and B (ISO 8673:1999)
1型六角螺母 细牙
GB/T 6171-2000
参与人数 1金币 +5 威望 +5 收起 理由
MS168 + 5 + 5 原创内容
 楼主| 发表于 2011-7-20 16:33:05 | 只看该作者
DIN EN ISO 8674
DIN 971-2
Hexagon nuts,style 2,with metric fine pitch thread - Product grades A and B (ISO 8674:1999)
2型六角螺母 细牙
GB/T 6176-2000
DIN EN ISO 8675
DIN 439-2
Hexagon thin nuts with metric fine pitch thread - Product grades A and B (ISO 8675:1999)
六角薄螺母 细牙
GB/T 6173-2000
DIN EN ISO 4762
DIN 912
Hexagon socket head cap screws(ISO 4762:1997)
内六角圆柱头螺钉
GB/T 70.1-2000
DIN EN ISO 7380
Hexagon socket button head sxrews (ISO 7380:1997)
内六角平圆头螺钉
GB/T 70.2-2000
DIN EN ISO 10642
DIN 7991
Hexagon socket countersunk head screws (ISO 10642:1997)
内六角沉头螺钉
GB/T 70.3-2000
DIN EN ISO 1207
DIN 84
Slotted cheese head screws-Product grade A(ISO 1207:1992)
开槽圆柱头螺钉
GB/T 65-2000
MS168 + 5 + 5 我很赞同
 楼主| 发表于 2011-7-20 16:35:22 | 只看该作者
DIN EN ISO 1580
DIN 85
Slotted pan head screws-Product grade A(ISO 1580:1994)
开槽盘头螺钉
GB/T 67-2000
DIN EN ISO 2009
DIN 963
Slotted countersunk flat head screws(common head style)(ISO 2009:1994)
开槽沉头螺钉
GB/T 68-2000
DIN EN ISO 2010
DIN 964
Countersunk slotted raised head screws(common head style)-Produce grade A(ISO 2010:1994)
开槽半沉头螺钉
GB/T 69-2000
DIN EN ISO 7045
DIN 7985
Pan head screws with type H or type Z cross recess-Product grade A(ISO 7054:1994)
十字槽盘头螺钉
GB/T 818-2000
DIN EN ISO 7046-1
DIN 965
Countersunk flat head screws (common head style)with type H or type Z cross recess,product grade A-Part 1:Steel of property class 4.8(ISO 7046-1:1994)
十字槽盘头螺钉 第1部分:钢4.8级
GB/T 819.1-2000
DIN EN ISO 7046-2
DIN 965
Cross recessed countersunk flat head screws (common head style),product grade A-Part2:Steel of property class 8.8,stainless steel and nonferous metals(ISO 7046-2:1990)
十字槽沉头螺钉 第2部分:钢8.8、不锈钢A2-70和有色金属CU2或CU3
GB/T 819.2-1997
MS168 + 5 + 5 精品文章
 楼主| 发表于 2011-7-20 16:37:19 | 只看该作者
DIN EN ISO 7047
DIN 966
Countersunk raised head screws (common head style) with type H or type Z cross recess-Product grade A(ISO 7047:1994)
十字槽半沉头螺钉
GB/T 820-2000
DIN EN ISO 7048
Cross recessed cheese head screws (ISO 7048:1998)
十字槽圆柱头螺钉
GB/T 822-2000
DIN EN ISO 10644
Screw and washer assemblies with plain washers-Washer hardness classes 200HV and 300HV(ISO 10644:1998)
螺栓或螺钉和平垫圈组合件
GB/T 9074.1-2002
DIN EN ISO 10510
Tapping screw and washer assemblies with plain washers(ISO 10510l:1999)
自攻螺钉和平垫圈组合件
GB/T 9074.18-2002
IDN EN ISO 15480
Hexagon washer head drilling screws with tapping screws thread (ISO 15480:1999)
六角凸缘自钻自攻螺钉
GB/T 15856.5-2002
IDN EN ISO 15481
Cross recessed pan head drilling screws with tapping screw thread(ISO 15481:1999)
十字槽盘头自钻自攻螺钉
GB/T 15856.1-2002
IDN EN ISO 15482
Cross recessed countersunk head drilling screws with tapping screw thread (ISO 15482:1999)
十字槽沉头自钻自攻螺钉
GB/T 15856.2-2002
IDN EN ISO 15483
Cross recessed raised countersunk head drilling screws with tapping screw thread(ISO 15483:1999)
十字槽半沉头自钻自攻螺钉
GB/T 15856.3-2002
MS168 + 5 + 5 你很热情
 楼主| 发表于 2011-7-20 16:40:44 | 只看该作者
DIN EN ISO 10669
Plain washers for tapping screw and washer assemblies - Normal and large series - Product grade A (ISO 10669:1999)
平垫圈 用于自攻螺钉和垫圈组合件
GB/T 97.5-2002
DIN EN ISO 10673
Plain washers for screw and washer assemblies - Small,normal and large series - Product grade A (ISO 10673:1998)
平垫圈 用于螺钉和垫圈组合件
GB/T 97.4-2002
DIN EN ISO 2338
DIN 7
Parallel pins,of unhardened steel and austenitic stainless steel(ISO 2338:1997)
圆柱销 不淬硬钢和奥氏体不锈钢
GB/T 119.1-2000
DIN EN ISO 8733
DIN 7979
Parallel pins whit internal thread,of unhardened steel and austenitic stainless steel(ISO 8733:1997)
内螺纹圆柱销 不淬硬钢和奥氏体不锈钢
GB/T 120.1-2000
DIN EN ISO 8734
DIN 6325
Parallel pins,of hardened steel or martensitic stainless steel(Dowel pins)(ISO 8734:1997)
圆柱销
淬硬钢和马氏体不锈钢
GB/T 119.2-2000
DIN EN ISO 8735
DIN 7979
Parallel pins with internal thread,of hardened steel and martensitic stainless steel(ISO 8735:1997)
内螺纹圆柱销 淬硬钢和马氏体不锈钢
GB/T 120.2-2000
DIN EN ISO 8748
DIN 7344
Spring-type straight pins,coiled,heavy duty (ISO 8748:1997)
弹性圆柱销 卷制 重型
GB/T 879.3-2000
参与人数 1威望 +5 收起 理由
MS168 + 5 全球验货员感谢你
 楼主| 发表于 2011-7-20 16:45:51 | 只看该作者
DIN EN ISO 8750
DIN 7343
Spring-type straight pins,coiled,standard duty (ISO 8750:1997)
弹性圆柱销 卷制 标准型
GB/T 879.4-2000
DIN EN ISO 8751
Spring-type straight pins,coiled,light duty (ISO 8751:1997)
弹性圆柱销 卷制 轻型
GB/T 879.5-2000
DIN EN ISO 8752
DIN 1481
Spring-type straight pins,slotted,heavy duty (ISO 8752:1997)
弹性圆柱销 直槽 重型
GB/T 879.1-2000
DIN EN ISO 13337
DIN 7346
Spring-type straight pins,slotted,light duty (ISO 13337:1997)
弹性圆柱销 直槽 轻型
GB/T 879.2-2000
DIN EN ISO 1234
DIN 94
Split pins (ISO1234:1997)
开口销
GB/T 91-2000
DIN EN ISO 7089
Plain washers-Normal series-Product grade A
平垫圈 A级
GB/T 97.1-2002
DIN EN ISO 7090
Plain washers,chamfered-Normal series-Product grade A(ISO 7090:2000)
平垫圈
倒角型 A级
GB/T 97.2-2002
DIN EN ISO 7091
Plain washers-Normal series-Product grade C(ISO 7091:2000)
平垫圈 C级
GB/T 95-2002
DIN EN ISO 7092
Plain washers-Small series-Product grade A(ISO 7092:2000)
小垫圈 A级
GB/T 848-2002
DIN EN ISO 7093-1
Plain washers-Large series-Part 1: Product grade A(ISO 70931-1:2000)
大垫圈 A级
GB/T 96.1-2002
 楼主| 发表于 2011-7-20 16:48:19 | 只看该作者
DIN EN ISO 7093-2
Plain washers-Normal series-Part 3: Product grade C(ISO 70936-2:2000)
大垫圈 C级
GB/T 96.2-2002
DIN EN ISO 7094
Plain washers-Extra large series -Product grade C(ISO 7094:2000)
特大垫圈 C级
GB/T 5287-2002
DIN EN ISO 7040
DIN 982| DIN 6924
Prevailing torque type hexagon nuts (with non-metallic insert),style 1 - Property classes 5,8 and 10(ISO 7040:1997)
1型非金属嵌件六角锁紧螺母
GB/T 889.1-2000
DIN EN ISO 7042
DIN 980| DIN 6925
Prevailing torque type all-metal hexagon nuts,style 2 - Property classes 5,8, 10 and 12(ISO 7042:1997)
2型全金属六角锁紧螺母
GB/T 6185.1-2000
DIN EN ISO 7719
Prevailing torque type all-metal hexagon nuts,style 1- Property classes 5,8 and 10(ISO 7719:1997)
1型全金属六角锁紧螺母
GB/T 6184-2000
DIN EN ISO 10511
DIN 985
Prevailing torque type hexagon thin nuts (with non-metallic insert )(ISO 10511:1997)
非金属嵌件六角锁紧薄螺母
GB/T 6072.2-2000
DIN EN ISO 10512
DIN 982| DIN 6924
Prevailing torque type hexagon nuts (with non-metallic insert),style 1,with metric fine pitch thread-Property classes 6,8 and 10(ISO 10512:1997)
1型非金属嵌件六角锁紧螺母 细牙
GB/T 889.2-2000
DIN EN ISO 10513
DIN 980| DIN 6925
Prevailing torque type all-metal hexagon nuts,style 2,with metric fine pitch thread - Property classes 8,10 and 12(ISO 10513:1997)
2型全金属六角锁紧螺母 细牙
GB/T 6185.2-2000
             全部续完   有需要的同行朋友可以参考学习。。
参与人数 1威望 +5 收起 理由
MS168 + 5 你太有才了
发表于 2011-7-20 17:50:28 | 只看该作者
谢谢分享~~
发表于 2011-7-21 00:01:20 | 只看该作者
这个太专业了吧
发表于 2011-7-29 01:15:00 | 只看该作者
.....看过
......踩过
.......会过
......走过
.....路过
....飘过
...游过
..想过
.瞄过
.经过
..梦过
〃瞟过′`)
    孤独独孤拿分,•′ ¸,•′`)
         (¸,•′ (¸孤独独孤走人*♥
GMT+8, 2026-9-18 14:41 , Processed in 0.053410 second(s), 19 queries , Gzip On.
