查看: 705|回复: 0
Sulfur dioxide test chamber
发表于 2011-7-9 11:32:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Purpose
This product is applicable for the corrosive gas test for the protection layer of components, parts,(linpin) electronic and electrical parts and metal materials and industrial products.
Chamber Structure
A waterproof structure is adopted between the chamber cover and chamber body and thus there is no gas overflow(linpin).
The chamber cover is made of
transparent materials so that the operator can see the situation of the tested sample in the chamber.
Double gas filters are eq
uipped in order to ensure the air exhausted outdoor will not pollute the environment(linpin).
Control System
Adopts P, I, D+S, S or R. microprocessor integrated controller with LED digital display.
Adopts multi-system protection,(
linpin) ensuring reliable and safe use.
Gas is produced with gas cylinder method or titration m
ethod.
Standards Applied
GB/T2423.19-81, GB/T10125-97, GB/T9789, IEC, 60068-2-42/43
Technical Parameters:
Model (CM)
S02 -250
S02 -750
Workroom Dimensions
60*90*50
75*110*50
Exterior Dimensions
77*144*125
92*164*145
Power
1.5(KW)
2.5(KW)
Temperature Range
RT+10℃~50℃
Humidity Range
85~95% R.H
Test Time
0.1~999.9 (S, M, H) adjustable
Gas Density
0.1~1% adjustable
GMT+8, 2026-11-30 16:09 , Processed in 0.028032 second(s), 18 queries , Gzip On.
