查看: 711|回复: 2
Mould test chamber
发表于 2011-7-8 14:15:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Purpose
This product is applicable for the testing of the indices of the spaceflight and aviation products, materials, electronic products,(linpin) and electronic and electrical components and parts in humid and heat environment.
Chamber Structure
The inner bladder of the chamber is made of imported SUS304 stainless steel plate while the outer bladder is made of A3 steel plate sprayed with plastic.
A large observation window is set on the c
hamber door(linpin).
Double-layer high-te
mperature resistant and high-intensity seal is adopted between the chamber door and the chamber body in order to ensure the obturation of the testing area.
A test hole with
25mm,(linpin) or 50mm or 100mm diameter is set on the left of the chamber body.
A high-quality fixable PU m
oving wheel is adopted on the bottom of the test chamber.
Cooling and Air Duct System
The cooler adopts original French Tecumseh fully-closed compressor.
The cooling system a
dopts single or dual low-temperature loop system design.
Air speed
≤0.2 m/sec (linpin)
Standards Applied
GB/T10588-2002
Specs & Technical Parameters
Model (CM)
(J)MS-100
(J)MS-225
(J)MS-500
(J)MS-010
Workroom Dimensions
45*45*50
50*60*75
70*80*90
100*100*100
Exterior Dimensions
105*97*176.5
105*102*200
132*132*217
167*152*231.5
Power
4.5(KW)
5.5(KW)
8.0(KW)
13.5(KW)
Temperature Range
20℃~80℃
Humidity Range
45~98%R.H
Fluctuation/Evenness
≤±0.5℃/≤±2℃
Humidity Deviation
+ 2, 3%R.H
发表于 2011-7-8 23:03:45 | 只看该作者
顶一个人了。。。。
发表于 2011-7-9 07:01:43 | 只看该作者
这是神马东东
GMT+8, 2026-9-15 08:06 , Processed in 0.131304 second(s), 19 queries , Gzip On.
