查看: 791|回复: 1
Salt spray test chamber
发表于 2011-7-4 14:11:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Purpose
This product is applicable for the salt spray corrosive test for the protection layer of components,(linpin)parts, electronic and electrical parts and metal materials and industrial products.
Chamber Structure
The chamber cover is made of transparent materials so that the operator can see the tested sample in the chamber and the spraying situation of the tested sample.
A waterproof structure is adopted between the ch
amber cover and chamber body and thus there is no salt spray overflow(linpin).
Adopts the tower spraying system and equipped with the salt s
olution filter system and non-crystal nozzle so as to realize even salt spray distribution and freely adjustable settlement(linpin).
Control System
High precision P.I.D.(linpin) temperature control meter with its error ±0.1℃.
Standards Applied
GB/T2423.17; GB/T10125-1997; GB10587; GB6460; GB1771; ASTM-B117; GJB150; DIN50021-75; ISO3768, 3769, 3770; CNS 3627, 3885, 4159, 7669 etc.
Specs & Technical Parameters
Model (CM)
YWX/Q-150
YWX/Q-250
YWX/Q-750
YWX/Q-010
YWX/Q-020
Workroom Dimensions
45*60*40
60*90*50
75*110*50
85*130*60
90*200*60
Exterior Dimensions
56*114*100
77*144*125
92*164*145
109*196*160
116*271*161
Power
1.3(kw)
1.5(kw)
1.8(kw)
4.5(kw)
6.5(kw)
Temperature Range
RT:+5℃~55℃
Temperature Evenness
≤±2℃
Temperature Fluctuation
≤±0.5℃
Salt Spray Settlement
1~2ml/80cm2.h
发表于 2011-7-5 14:05:41 | 只看该作者
上街买菜。。。。。。。
GMT+8, 2026-11-30 16:10 , Processed in 0.040021 second(s), 18 queries , Gzip On.
