查看: 653|回复: 0
Temperature shock test chamber
发表于 2011-7-1 14:37:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Purpose This product is applicable for the safe performance test of electronic components and parts and provides the reliable test and product selection test etc; through the chamber test,(linpin) the product reliability can be improved and the quality control can be conducted. Chamber Structure All functions adopt the computer control with good operation interface so as to ensure the user’s operation and monitoring is more simple and straightforward(linpin). The cold chamber and hot chamber are controlled independently and the chamber doors are independent of each other so as to enlarge the use range of the test chamber (1 chamber for 3 purposes)(linpin). A standard lead hole pipe is installed on the top of the chamber in order to facilitate users to lead sensor cable,(linpin) inspection cable etc into the chamber. Control System The switching time between low temperature zone and high temperature zone is not more than 15sec. The temperature recovery time is not more than 5min. Standards Applied GB/T2423.1.2, GB10592-89, GJB150 Specs & Technical Parameters Model (CM) WDCJ-162 WDCJ-340 WDCJ-500 WDCJ-010 Workroom Dimensions 45*45*45 60*60*60 80*80*80 100*100*100 Exterior Dimensions 156*87*154.5 171*102*184.5 191*122*226.5 211*142*266.5 Sample Zone Dimensions 30*30*25 45*45*36 65*65*50 85*85*70 Power 6.5(KW) 8.6(KW) 13.5(KW) 15.5KW Performance Index Temperature Range A:-20℃~200℃ B:-40℃~200℃ C:-60℃~200℃ Temperature Fluctuation ≤±2℃ for high temperature and low temperature Temperature Fluctuation ≤±0.5℃(Under constant temperauture) Sample Zone Load 20kg 30kg 50kg 60kg
GMT+8, 2026-11-30 16:09 , Processed in 0.024454 second(s), 18 queries , Gzip On.
