查看: 2494|回复: 10
免费共享 数码相机专业词汇英语
发表于 2011-6-27 15:47:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Accessories (附/配件)
Anti-shake (防抖)
Aperture (光圈)
Aperture priority (光圈优先)
Auto bracketing (自动包围)
Auto focus (自动对焦)
Auto rotation  (自动旋转)
Background (背景)
Backlit (背光的)
背光的主体(backlit subject)
Battery grip (电池手托)
Built-in flash (内置闪光灯)
Composition (构图)
Depth of field (DOF) (景深)
Digital zoom (数码变焦)
SLR (单反相机)
DSLR (数码单反相机)
Effective pixels (有效像素)
Exposure (曝光)
Exposure compensation (曝光补偿)
Electromagnetic diaphragm (EMD) 电磁光圈
External speedlite (外置闪光灯)
Film  (胶卷,菲林)
Filter (滤光镜)
Focus (对焦)
对焦环(focusing ring)
自动对焦 (auto-focusing)
Foreground (前景)
Full frame (全幅/全片幅)
Full pressing (全按)
Halfway pressing (半按)
High key (高调/亮调)
Histogram (光暗分布图)
Hood (遮光罩)
Image stabilization (成像稳定)
Image stabilizer (IS) (成像稳定系统/器)
LCD monitor (液晶显示器)
Lens (镜片/头)
自动对焦镜头 (auto-focusing lens)
标准镜头 (standard lens)
标准变焦镜头 (standard zoom lens)
超广角变焦镜头 (ultra wide lens)
中距远摄镜头 (medium telephoto lens)
远摄变焦镜头 (telephoto zoom lens)
远摄镜头 (telephoto lens)
超远摄镜头 (super telephoto lens)
微距镜头 (macro lens)
移轴镜头 (tilt and shift lens)
Light(光)
低光/暗光(low light)
Lighting (用光)
Low key(低调/暗调)
Macro (微距)
Manual (手动)
Metering (测光)
矩阵/评估测光(matrix / evaluative metering)
中央权重平均测光(center-weighted average metering)
点测光(spot (partial) metering)
Noise reduction (减噪)
Optical zoom (光学变焦)
Photographer(摄影者/家)
Photography (摄影)
文献摄影(documentary photography)
艺术摄影(fine art photography)
风光摄影(landscape photography)
裸体摄影(nude photography)
扫街摄影(street photography)
肖像摄影 (portrait photography)
Picture angle (图像对角)
Playback (回放显示)
Red-eye reduction (红眼消除)
Remote switch (遥控开关)
Sensitivity (ISO) (感光度)
Sensor (感光器/芯片)
Setting (设置)
Shape (形状)
Sharpening (锐度)
Shutter (快门)
快门按钮(shutter button)
Shutter priority (快门优先)
Shutterspeed (快门速度)
Subject (拍摄主体)
Subject distance (主体距离)
Texture (质地,质感)
Tripod (三脚架)
Viewfinder  (取景器)
Ultrasonic Motor (USM) (超声波马达)
White balance (白平衡)
Wide (广角)
Zoom (变焦)
变焦环 (zoom ring)
相机英文词汇大全(字母序)
A
Aberration 像差
Accessory 附件
Accessory Shoes 附件插座、热靴
Achromatic 消色差的
Active 主动的、有源的
Acutance 锐度
Acute-matte 磨砂毛玻璃
Adapter 适配器
Advance system 输片系统
AE Lock(AEL) 自动曝光锁定
AF(Autofocus) 自动聚焦
AF Illuminator AF照明器
AF spotbeam projector AF照明器
Alkaline 碱性
Ambient light 环境光
Amplification factor 放大倍率
Angle finder 弯角取景器
Angle of view 视角
Anti-Red-eye 防红眼
Aperture 光圈
Aperture priority 光圈优先
APO(APOchromat) 复消色差
APZ(Advanced Program zoom) 高级程序变焦
Arc 弧形
ASA(American Standards Association) 美国标准协会
Astigmatism 像散
Auto bracket 自动包围
Auto composition 自动构图
Auto exposure 自动曝光
Auto exposure bracketing 自动包围曝光
Auto film advance 自动进片
Auto flash 自动闪光
Auto loading 自动装片
Auto multi-program 自动多程序
Auto rewind 自动退片
Auto wind 自动卷片
Auto zoom 自动变焦
Automatic exposure(AE) 自动曝光
Automation 自动化
Auxiliary 辅助的
参与人数 1金币 +5 威望 +5 收起 理由
WHG168 + 5 + 5 精品文章
 楼主| 发表于 2011-6-27 15:49:31 | 只看该作者
B
Back 机背
Back light 逆光、背光
Back light compensation 逆光补偿
Background 背景
Balance contrast 反差平衡
Bar code system 条形码系统
Barrel distortion 桶形畸变
BAse-Stored Image Sensor (BASIS) 基存储影像传感器
Battery check 电池检测
Battery holder 电池手柄
Bayonet 卡口
Bellows 皮腔
Blue filter 蓝色滤光镜
Body-integral 机身一体化
Bridge camera 桥梁相机
Brightness control 亮度控制
Built in 内置
Bulb B 门
Button 按钮
C
Cable release 快门线
Camera 照相机
Camera shake 相机抖动
Cap 盖子
Caption 贺辞、祝辞、字幕
Card 卡
Cartridges 暗盒
Case 机套
CCD(Charge Coupled Device) 电荷耦合器件
CdS cell 硫化镉元件
Center spot 中空滤光镜
Center weighted averaging 中央重点加权平均
Chromatic Aberration 色差
Circle of confusion 弥散圆
Close-up 近摄
Coated 镀膜
Compact camera 袖珍相机
Composition 构图
Compound lens 复合透镜
Computer 计算机
Contact 触点
Continuous advance 连续进片
Continuous autofocus 连续自动聚焦
Contrast 反差、对比
Convetor 转换器
Coreless 无线圈
Correction 校正
Coupler 耦合器
Coverage 覆盖范围
CPU(Central Processing Unit) 中央处理器
Creative expansion card 艺术创作软件卡
Cross 交叉
Curtain 帘幕
Customized function 用户自选功能
参与人数 1金币 +5 收起 理由
WHG168 + 5 精品文章
 楼主| 发表于 2011-6-27 15:51:39 | 只看该作者
D
Data back 数据机背
Data panel 数据面板
Dedicated flash 专用闪光灯
Definition 清晰度
Delay 延迟、延时
Depth of field 景深
Depth of field preview 景深预测
Detection 检测
Diaphragm 光阑
Diffuse 柔光
Diffusers 柔光镜
DIN (Deutsche Industrische Normen) 德国工业标准
Diopter 屈光度
Dispersion 色散
Display 显示
Distortion 畸变
Double exposure 双重曝光
Double ring zoom 双环式变焦镜头
Dreams filter 梦幻滤光镜
Drive mode 驱动方式
Duration of flash 闪光持续时间
DX-code DX编码
E
ED(Extra low Dispersion)
超低色散
Electro selective pattern(ESP)
电子选择模式
EOS(Electronic Optical System)
电子光学系统
Ergonomic
人体工程学
EV(Exposure value)
曝光值
Evaluative metering
综合评价测光
Expert
专家、专业
Exposure
曝光
Exposure adjustment
曝光调整
曝光补偿
Exposure memory
曝光记忆
Exposure mode
曝光方式
Exposure value(EV)
曝光值
Extension tube
近摄接圈
Extension ring
近摄接圈
External metering
外测光
Extra wide angle lens
超广角镜头
Eye-level fixed
眼平固定
Eye-start
眼启动
Eyepiece
目镜
Eyesight correction lenses
视力校正镜
WHG168 + 5 + 5 绝对的精品,辛苦了。
 楼主| 发表于 2011-6-27 15:53:08 | 只看该作者
F
Field curvature 像场弯曲
Fill in 填充(式)
Film 胶卷(片)
Film speed 胶卷感光度
Film transport 输片、过片
Filter 滤光镜
Finder 取景器
First curtain 前帘、第一帘幕
Fish eye lens 鱼眼镜头
Flare 耀斑、眩光
Flash 闪光灯、闪光
Flash range 闪光范围
Flash ready 闪光灯充电完毕
Flexible program 柔性程序
Focal length 焦距
Focal plane 焦点平面
Focus 焦点
Focus area 聚焦区域
Focus hold 焦点锁定
Focus lock 焦点锁定
Focus prediction 焦点预测
Focus priority 焦点优先
Focus screen 聚焦屏
Focus tracking 焦点跟踪
Focusing 聚焦、对焦、调焦
Focusing stages 聚焦级数
Fog filter 雾化滤光镜
Foreground 前景
Frame 张数、帧
Freeze 冻结、凝固
Fresnel lens 菲涅尔透镜、环状透镜
Frontground 前景
Fuzzy logic 模糊逻辑
G
Glare 眩光
GN(Guide Number) 闪光指数
GPD(Gallium Photo Diode) 稼光电二极管
Graduated 渐变
H
Half frame 半幅
Halfway 半程
Hand grip 手柄
High eye point 远视点、高眼点
High key 高调
Highlight 高光、高亮
Highlight control 高光控制
High speed 高速
Honeycomb metering 蜂巢式测光
Horizontal 水平
Hot shoe 热靴、附件插座
Hybrid camera 混合相机
Hyper manual 超手动
Hyper program 超程序
Hyperfocal 超焦距
I
IC(Integrated Circuit) 集成电路
Illumination angle 照明角度
Illuminator 照明器
Image control 影像控制
Image size lock 影像放大倍率锁定
Infinity 无限远、无穷远
Infra-red(IR) 红外线
Instant return 瞬回式
Integrated 集成
Intelligence 智能化
Intelligent power zoom 智能化电动变焦
Interactive function 交互式功能
Interchangeable 可更换
Internal focusing 内调焦
Interval shooting 间隔拍摄
ISO(International Standard Association) 国际标准化组织
WHG168 + 5 + 5 原创内容
 楼主| 发表于 2011-6-27 15:55:09 | 只看该作者
J
JIS(Japanese Industrial Standards)
日本工业标准
L
Landscape 风景
Latitude 宽容度
LCD data panel LCD数据面板
LCD(Liquid Crystal Display) 液晶显示
LED(Light Emitting Diode) 发光二极管
Lens 镜头、透镜
Lens cap 镜头盖
Lens hood 镜头遮光罩
Lens release 镜头释放钮
Lithium battery 锂电池
Lock 闭锁、锁定
Low key 低调
Low light 低亮度、低光
LSI(Large Scale Integrated) 大规模集成
M
Macro
微距、巨像
Magnification
放大倍率
Main switch
主开关
Manual
手动
Manual exposure
手动曝光
Manual focusing
手动聚焦
Matrix metering
矩阵式测光
Maximum
最大
Metered manual
测光手动
Metering
测光
Micro prism
微棱
Minimum
最小
Mirage
倒影镜
Mirror
反光镜
Mirror box
反光镜箱
Mirror lens
折反射镜头
Module
模块
Monitor
监视、监视器
Monopod
独脚架
Motor
电动机、马达
Mount
卡口
MTF (Modulation Transfer Function
调制传递函数
Multi beam
多束
Multi control
多重控制
Multi-dimensional
多维
Multi-exposure
多重曝光
Multi-image
多重影
Multi-mode
多模式
Multi-pattern
多区、多分区、多模式
Multi-program
多程序
Multi sensor
多传感器、多感光元件
Multi spot metering
多点测光
Multi task
多任务
N
Negative 负片
Neutral 中性
Neutral density filter 中灰密度滤光镜
Ni-Cd battery 镍铬(可充电)电池
O
Off camera 离机
Off center 偏离中心
OTF(Off The Film) 偏离胶卷平面
One ring zoom 单环式变焦镜头
One touch 单环式
Orange filter 橙色滤光镜
Over exposure 曝光过度
WHG168 + 5 + 5 无私奉献,值得学习。
 楼主| 发表于 2011-6-27 15:57:22 | 只看该作者
P
Panning 摇拍
Panorama 全景
Parallel 平行
Parallax 平行视差
Partial metering 局部测光
Passive 被动的、无源的
Pastels filter 水粉滤光镜
PC(Perspective Control) 透视控制
Pentaprism 五棱镜
Perspective 透视的
Phase detection 相位检测
Photography 摄影
Pincushion distortion 枕形畸变
Plane of focus 焦点平面
Point of view 视点
Polarizing 偏振、偏光
Polarizer 偏振镜
Portrait 人像、肖像
Power 电源、功率、电动
Power focus 电动聚焦
Power zoom 电动变焦
Predictive 预测
Predictive focus control 预测焦点控制
Preflash 预闪
Professional 专业的
Program 程序
Program back 程序机背
Program flash 程序闪光
Program reset 程序复位
Program shift 程序偏移
Programmed Image Control (PIC) 程序化影像控制
Q
Quartz data back 石英数据机背
R
Rainbows filter 彩虹滤光镜
Range finder 测距取景器
Release priority 释放优先
Rear curtain 后帘
Reciprocity failure 倒易律失效
Reciprocity Law 倒易律
Recompose 重新构图
Red eye 红眼
Red eye reduction 红眼减少
Reflector 反射器、反光板
Reflex 反光
Remote control terminal 快门线插孔
Remote cord 遥控线、快门线
Resolution 分辨率
Reversal films 反转胶片
Rewind 退卷
Ring flash 环形闪光灯
ROM(Read Only Memory) 只读存储器
Rotating zoom 旋转式变焦镜头
RTF(Retractable TTL Flash) 可收缩TTL闪光灯
S
Second curtain 后帘、第二帘幕
Secondary Imaged Registration(SIR) 辅助影像重合
Segment 段、区
Selection 选择
Self-timer 自拍机
Sensitivity 灵敏度
Sensitivity range 灵敏度范围
Sensor 传感器
Separator lens 分离镜片
Sepia filter 褐色滤光镜
Sequence zoom shooting 顺序变焦拍摄
Sequential shoot 顺序拍摄
Servo autofocus 伺服自动聚焦
Setting 设置
Shadow 阴影、暗位
Shadow control 阴影控制
Sharpness 清晰度
Shift 偏移、移动
Shutter 快门
Shutter curtain 快门帘幕
Shutter priority 快门优先
Shutter release 快门释放
Shutter speed 快门速度
Shutter speed priority 快门速度优先
Silhouette 剪影
Single frame advance 单张进片
Single shot autofocus 单次自动聚焦
Skylight filter 天光滤光镜
Slide film 幻灯胶片
Slow speed synchronization 慢速同步
SLD(Super Lower Dispersion) 超低色散
SLR(Single Lens Reflex) 单镜头反光照相机
SMC(Super Multi Coated) 超级多层镀膜
Soft focus 柔焦、柔光
SP(Super Performance) 超级性能
SPC(Silicon Photo Cell) 硅光电池
SPD(Silicon Photo Dioxide) 硅光电二极管
Speedlight 闪光灯、闪光管
Split image 裂像
Sport 体育、运动
Spot metering 点测光
Standard 标准
Standard lens 标准镜头
Starburst 星光镜
Stop 档
Synchronization 同步
WHG168 + 5 + 5 精品文章
 楼主| 发表于 2011-6-27 16:00:09 | 只看该作者
T
Tele converter
增距镜、望远变换器
Telephoto lens
长焦距镜头
Trailing-shutter curtain
后帘同步
Trap focus
陷阱聚焦
Tripod
三脚架
TS(Tilt and Shift)
倾斜及偏移
TTL flash
TTL闪光
TTL flash metering
TTL闪光测光
TTL(Through The Lens)
通过镜头、镜后
Two touch
双环
U
UD(Ultra-low Dispersion) 超低色散
Ultra wide 超阔、超广
Ultrasonic 超声波
UV(Ultra-Violet) 紫外线
Under exposure 曝光不足
V
Vari-colour 变色
Var-program 变程序
Variable speed 变速
Vertical 垂直
Vertical traverse 纵走式
View finder 取景器
W
Warm tone 暖色调
Wide angle lens 广角镜头
Wide view 广角预视、宽区预视
Wildlife 野生动物
Wireless remote 无线遥控
World time 世界时间
X
X-sync X-同步
Z
Zoom 变焦
Zoom lens 变焦镜头
Zoom clip 变焦剪裁
Zoom effect 变焦效果
其他:
TTL 镜后测光
NTTL 非镜后测光
UM 无机内测光,手动 测光
MM 机内测光,但需手动设定
AP 光圈优先
SP 快门优先
PR 程序暴光
WHG168 + 5 + 5 无私奉献,超级精品!
发表于 2011-6-27 19:45:24 | 只看该作者
楼主太强大了,谢谢楼主辛苦了,你一个月又1.2w吧
发表于 2011-6-27 21:14:35 | 只看该作者
谢谢楼主,超级精品,辛苦了。。
发表于 2011-6-27 22:29:09 | 只看该作者
百度的文档吗,,,,,,,,,,,,,,,,,,,,,,,,,
GMT+8, 2026-11-30 13:40 , Processed in 0.171912 second(s), 20 queries , Gzip On.
