查看: 720|回复: 1
Rustproof grease humidity test chamber
发表于 2011-6-27 13:55:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Purpose
This product is a kind of testing equipment simulating a humid environment and it is applied for the test and assessment of the labs of petroleum, chemical etc and universities and research institute etc on the performance of metals to persist to rust.
Chamber Structure
The inner bladder of the chamber is made of SUS304 stainless steel plate while the outer housing is made of A3 steel plate sprayed with plastic(linpin).
The temperature maint
aining system adopts super-thin glass fiber filled temperature maintaining zone(linpin).
The chamber door adopts refined silicone rubber seal.
Adopts the water adding function a
ctivated in case of water shortage.
Control System
Adopts temperature and humidity controller with digital display and touch keys and PID high-precision control function(linpin);
Temperature sensor: Pl
atinum resistor PT100.
Standards Applied
GB/T2361-92 Rust Preventing Oils and Greases -Test Method of Wet Heat
Technical Parameters:
Model (CM)
HUS-100
HUS-250
HUS-400
Workroom Dimensions
45*45*55
58*58*68
68*68*80
Exterior Dimensions
69*64*127
82*77*140
92*87*152
Power
3.0(KW)
4.0(KW)
6.0(KW)
Temperature Range
RT+5℃~65℃
Temperature Evenness
≤±2.0℃
Temperature Fluctuation
≤±0.5℃
Humidity Range
≥95% RH
Sample Rack Rotate Speed
1~3r/min±10%
Air Admission Volume
0.5m3/h (0.1~1m3/h adjustable)
发表于 2011-6-27 15:13:24 | 只看该作者
BU GJ X; QU ...。。。。。。。。。。。。。
GMT+8, 2026-11-30 16:10 , Processed in 0.039284 second(s), 18 queries , Gzip On.
