查看: 981|回复: 5
Precise drying test chamber
发表于 2011-6-23 15:57:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Purpose
This product is applicable for the drying, baking and sterilizing of nonvolatile articles conducted by industrial and mining enterprises,(linpin) schools, medical and scientific research institutions.
Chamber Structure
The inner bladder of the chamber is made of stainless steel mirror finish plate while the outer bladder is made of high-quality steel plate sprayed with plastic(linpin).
A steel glass observatio
n window is available.
Sample ra
cklinpin) 2 pcs (standard)
Specs of Desk DHG Drying Oven
Model
9023A
9035A
9053A
9055A
9070A
9075A
9140A
9
145A
9240A
9245A
9620A
9626A
Working Dimensions (CM)
34*32.5*30
42*39.5*35
45*40*45
55*45*55
60*50*75
80*60*130
Exterior Dimensions (CM)
62*54*49
70*61*52
74*61.8*63
84*67*73
88*72*93
97*76*175
Power
870(W)
1120(W)
1570(W)
2070(W)
2470(W)
3970(W)
Temperature Range
RT+ 10℃~250℃
RT+10℃~300℃
Control Accuracy
±1%(Full range)
Constant Temperature Fluctuation
±1℃
Temperature Resolution
0.1℃
Specs of Vertical DGG Drying Oven
Model
9030A
9036A
9070A
9076A
9140A
9146A
9240A
9246A
9420A
9426A
9620A
9626
A
Working Dimensions (cm)
30*30*35
40*40*45
45*55*55
50*60*75
60*55*130
80*60*130
Exterior Dimensions (cm)
44*45*71
55*55*80
64*70*90
69*73*110
77*71*175
97*76*175
Power (W)
550
940
1390
1890
3370
3970
发表于 2011-6-23 16:52:31 | 只看该作者
路过,再发要扣分了,,,,,,,,,,
发表于 2011-6-23 20:26:14 | 只看该作者
这种垃圾连发有意思吗?
发表于 2011-6-23 21:00:43 | 只看该作者
过`................`过。。。。。。。。。真正路过
发表于 2011-6-23 21:54:32 | 只看该作者
发表于 2011-6-24 08:38:28 | 只看该作者
倒着路过。。。。。。。。。。
GMT+8, 2026-11-30 16:09 , Processed in 0.058071 second(s), 18 queries , Gzip On.
