查看: 1223|回复: 6
Precise drying test chamber
发表于 2011-6-23 13:38:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Purpose This product is applicable for the drying, baking and sterilizing of nonvolatile articles conducted by industrial and mining enterprises,(linpin) schools, medical and scientific research institutions. Chamber Structure The inner bladder of the chamber is made of stainless steel mirror finish plate while the outer bladder is made of high-quality steel plate sprayed with plastic(linpin). A steel glass observation window is available. Sample rack:(linpin) 2 pcs (standard) Specs of Desk DHG Drying Oven Model 9023A 9035A 9053A 9055A 9070A 9075A 9140A 9145A 9240A 9245A 9620A 9626A Working Dimensions (CM) 34*32.5*30 42*39.5*35 45*40*45 55*45*55 60*50*75 80*60*130 Exterior Dimensions (CM) 62*54*49 70*61*52 74*61.8*63 84*67*73 88*72*93 97*76*175 Power 870(W) 1120(W) 1570(W) 2070(W) 2470(W) 3970(W) Temperature Range RT+ 10℃~250℃ RT+10℃~300℃ Control Accuracy ±1%(Full range) Constant Temperature Fluctuation ±1℃ Temperature Resolution 0.1℃ Specs of Vertical DGG Drying Oven Model 9030A 9036A 9070A 9076A 9140A 9146A 9240A 9246A 9420A 9426A 9620A 9626A Working Dimensions (cm) 30*30*35 40*40*45 45*55*55 50*60*75 60*55*130 80*60*130 Exterior Dimensions (cm) 44*45*71 55*55*80 64*70*90 69*73*110 77*71*175 97*76*175 Power (W) 550 940 1390 1890 3370 3970
发表于 2011-6-23 15:06:53 | 只看该作者
我觉得没意义。。。。。。。。。。。。。。。。
发表于 2011-6-23 15:12:48 | 只看该作者
没意义。。。。。。。。。。。。。。。。
发表于 2011-6-23 15:19:35 | 只看该作者
强烈打酱油回家做饭了,
发表于 2011-6-23 15:49:19 | 只看该作者
毫无意义。。。。。。。。。。。
发表于 2011-6-23 16:14:32 | 只看该作者
回家打酱油。
发表于 2011-6-26 09:30:34 | 只看该作者
回家打酱油。
GMT+8, 2026-10-26 08:21 , Processed in 0.027720 second(s), 18 queries , Gzip On.
