查看: 948|回复: 5
Vacuum oven
发表于 2011-6-20 10:36:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Purpose The vacuum drying chamber is specially designed for dry,(linpin) heat sensitive, labile and easily oxidized substances,(linpin) which can be filled inwards with inert gases; especially some substances with complex ingredients can be rapidly dried(linpin). Specs & Technical Parameters Model (cm) DZF-6020 DZF-6050 Workroom Dimensions 30*30*27 41*37*34 Exterior Dimensions 60*49*45 73*56*55 Power 0.4(KW) 0.6(KW) Tempereature Range RT+10℃~250℃ Tempereature Resolution ±0.1℃ Constant Temperature Fluctuation ±1℃ Reaching Vacuumed Degree 133Pa Ambient Temperature +5℃~35℃ Power Supply 220V 50Hz Object Bracket (standard) 1pcs 2pcs Wookroom Material Stainless steel plate Timing Range 1-9999 minutes
发表于 2011-6-20 11:57:52 | 只看该作者
逛庙会。。。。。。。。。。
发表于 2011-6-20 11:59:32 | 只看该作者
逛庙会。。。。。。。。。。
发表于 2011-6-20 12:19:33 | 只看该作者
有意义吗?
发表于 2011-6-20 12:32:10 | 只看该作者
madman!那位大哥英文18级的翻译下
发表于 2011-6-20 19:29:40 | 只看该作者
没有半点意义。。。。。。。
GMT+8, 2026-11-30 16:13 , Processed in 0.039301 second(s), 18 queries , Gzip On.
