查看: 826|回复: 4
High and low temperature alternating temperature humidity test chamber
发表于 2011-6-13 15:03:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Purpose
This series is applicable for the testing of the indices of the spaceflight and aviation products,(linpin) information electronic instruments and meters, materials, electrical and electronic products,(linpin)and electronic and electrical components and parts in high-temperature, low-temperature, humid and heat environment.
Chamber Structure
The inner bladder of the chamber is made of SUS304 stainless steel plate while the outer bladder is made of A3 steel plate sprayed with plastic.
A large observation window is set on the chamber door.
Double-layer high-temperature resistant and high-intensity seal is adopted between the chamber door and the chamber bo
dy in order to ensure the obturation of the testing area.
A test hole with 25mm,(
linpin)or 50mm or 100mm diameter is set on the left of the chamber body.
A high-q
uality fixable PU moving wheel is adopted on the bottom of the test chamber.
Control System
The temperature and humidity control instrument adopts imported South Korean TEM1800 meter with Chinese and English operation interface(linpin).
The capacity of 100 sets of progra
mmable 1,000-section 999-circular steps is available, and the set maximal time every section is 99h 59min(linpin).
There is RS-232or RS-485 commun
ication interface and can connect to PC for corresponding operation.
Standards Applied
GB/T2423.1-2001
GB/T2423.2-2001
GB/T2423.3-1993
GB/T2423.4-1993
Technical Parameters:
Model(cm)
GDJS-100
GDJS-225
GDJS-500
GDJS-800
GDJS-010
Workroom Dimensions
45*45*50
50*60*75
70*80*90
80*100*100
100*100*100
Exterior Dimensions
105*97*176.5
105*102*200
132*132*217
147*152*231.5
167*152*231.5
Power(@-40℃)
6.0(KW)
7.0(KW)
13.5(KW)
15.0(KW)
16.5(KW)
Temperature Range
A:-20℃~150℃ B:-40℃~150℃ C:-60℃~150℃ D:-70℃~150℃
Humidity Range
30~98% R.H
Fluctuation/Evenness
≤±0.5℃/≤±2℃
Humidity Deviation
+2, -3% R.H
Temperature Rise Speed
1.0~3.0℃/min
Temperature Fall Speed
0.7~1.0℃/min
发表于 2011-6-13 15:40:57 | 只看该作者
广告吗。。。。。。。。
发表于 2011-6-13 20:57:24 | 只看该作者
过。。。。。。。。
发表于 2011-6-13 22:46:07 | 只看该作者
过。。。。。。。。
发表于 2011-6-13 23:27:00 | 只看该作者
卖高低温箱的
GMT+8, 2026-11-30 16:10 , Processed in 0.027885 second(s), 18 queries , Gzip On.
