查看: 835|回复: 5
钢管求购信息
发表于 2011-5-9 08:15:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我又一客户是阿联酋的,现在国内采购建材,现在让我帮他找建筑用的钢管,希望论坛的朋友们给我提供信息,谢谢。坐等:
“ 60 pipe  each one 6 meter thickness 2.5 mm or 3mm diameter 2 inch
using for roof support not heavy the roof per meter only 4 kilo  shipping from guanzhou
regards,
目前他还在广州采购一些,墙砖,谁能提供信息给我啊,他说现在工厂给她的价格太高了:
ok give me thickess 8 mm and 10 mm and wall ceramic 4 to 5mm
发表于 2011-5-9 08:53:08 | 只看该作者
可以联系我。QQ:1720002412
发表于 2011-5-9 09:12:00 | 只看该作者
地区有限制吗?
发表于 2011-5-9 11:44:21 | 只看该作者
大家好。。。。。。。。。。。。
 楼主| 发表于 2011-5-10 08:11:32 | 只看该作者
hi  bruce ,
as i see your INVOICE  i think your price good but the design and the flat of ceramic from
base due some of china ceramic come curve and broken when installing
please send me some photo of design i can take sample around 320 meter squre of ceramic
thickness 8 mm for floor and for wall around 100 meter
i need some pipe fitting  this is the quantity and size ipe of drain:
¢160×4.0 = 32 meter 8 pieces
¢110×3.2= 66 meter 16 pieces
Trap(S)= 12 pieces
Tee¢160×110 =16 pieces
Cross¢110×110×110 14 pieces
Pipe  25mm I inch =110 meter
Pipe hot water line 40 meter PN2.0MPa hot water pipes outdiameter*thickness 20*3.4mm
i can give you some price which it high from some supplier you can see in attachment
more things i can give you some other order
like i need window for test 8 pieces size 120cm h x 110 cm width
slide open
you can give me
i will send you other items i need we see if you can arrage good price for it you can found it in other file
regards,
fahed
发表于 2011-5-10 09:48:23 | 只看该作者
管子肯定可以做,但是........
GMT+8, 2026-11-30 15:48 , Processed in 0.027257 second(s), 19 queries , Gzip On.
