查看: 1110|回复: 2
常用20组英语报价 新免
发表于 2011-3-18 18:54:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1)
A: Do you offer any quantity discounts ?
B: No, we don‘t.
A: Then give us three cases of this .
A:大量购买有折扣吗?
B:不,没有。
A:那么这种的就买三箱好了。
2)
A: How many different models of this do you offer?
B: We have five different ones .
A: Is there much of a price difference .
B: Yes, so we had better look over your specifications.
A:这个你们有多少种不同的型式。
B:五种
A:价钱有很大的差别吗?
B:是的,所以我们最好先把您的规格说明细看一遍。
3)
A: You‘re asking too much for this part .
B: we have some cheaper ones .
A: What is the price difference ?
B: The basic model will cost about 10% less .
A:这零件你们要价太高了。
B:我们有便宜一点的。
A:价钱差多少?
B:基本型的便宜约10%左右。
4)
A: Is this going to satisfy your requirements ?
B: Actually , it is more than we need .
A: We can give you a little cheaper model .
B: Let me see the specifications for that .
A:这种的合你的要求吗?
B:事实上,已超出我们所需要的。
A:我们可以提供你便宜一点的型式。
B:让我看看它的规格说明书吧。
5)
A: The last order didn‘t work out too well for us
B: What was wrong?
A: We were developing too much waste .
B: I suggest you go up to our next higher price level.
A:上回订的货用起来不怎么顺。
B:有什么问题吗?
A:生产出来的废品太多了。
B:我建议您采用我们价格再高一级的货
6)
A: Did the material work out well for you ?
B: Not really .
A: What was wrong?
B: We felt that the price was too high for the quality .
A:那些材料进行的顺利吗
B::不怎么好。
A:怎么啦?
B:我们觉得以这样的品质价钱太高了。
7)
A: Has our material been all right ?
B: I‘m afraid not .
A: Maybe you should order a little better quality
B: Yes, we might have to do that .
A:我们的原材料没问题吧?
B:有问题呢。
A:也许您应该买品质好一点的
B:是呀,恐怕只有这么做了。
8)
A: I think you had better come out to the factory .
B: Is there something wrong .
A: Yes ,your last shipment wasn‘t up to par .
B: Let ‘s go out and have a look at it .
A:我看你最好走一趟工厂,
B:出了什么事吗。
A:嗯,你上次送去的货没有达到标准。
B:走,我们去看看?
9)
A: I want you to look at this material .
B: Is this from our last shipment ?
A: Yes ,it is .
B: I can see why you are having some problems with it .
A:我要你看看这材料!
B:这是上次叫的货吗?
A:是啊。
B:我明白为什么你用起来会有问题了。
10)
A: How many would you like to order ?
B: Is there a minimum order ?
A: No ,we can ship in lots of any size .
B: We‘ll try one case of this .
A:您要订多少?
B:有最低订购量的限制吗?
A:没有,任何数量都可以出货。
B:那么,这种的就试一箱吧
11)
A: Our manufacturing costs have gone up too much .
B: You might try one of our cheaper components .
A: Let‘s take a look at your price list again
B: Sure . I‘ll bring it in next week .
A:我们的制造成本增加太多了。
B:你试试这种较便宜的组件怎样?
A:我再看一次你们的价目表吧。
B:好哇 ,我下个礼拜带过来。
12)
A: This is the best material we have to offer .
B: Actually ,I don‘t think we need it to be this good .
A: I can let you have this kind cheaper .
B: Let‘s do that .
A:这是本公司所供应的最好的原料。
B:说实在的,我并不认为我们用得着这么好的,
A:我可以算你便宜一点。
B:那就这么说定吧?
13)
A: How is the new material working out for you ?
B: Fine .we‘re saving a lot of money with it .
A: I‘m glad to hear that .
B: It was a good suggestion .thanks .
A:新原料用得如何?
B:不错,节省了不少的钱,
A:听你这么说真高兴。
B:你建议得不错,谢谢。
14)
A: I would suggest that you use this material instead of that .
B: But that costs more .
A: But you will get less waste from this .
B: We‘ll try it once .
A:我建议你改用这种替代那种。
B:可是那样成本较高。
A:但可以减少浪费。
B:那么就试一次看看吧。
15)
A: We‘re ready to take your order now.
B: We want to try this component as a sample.
A: I can send one for you to try .
B: Yes , please do that .
A:你们现在可以下订单了。
B:这种组件我们想试个样品看看。
A:我们可以寄个给你试用。
B:好,那就麻烦你了。
16)
B: How do they come packaged ?
A: In cases of 100.
B: We‘ll take 500.
A: 您要订多少?
B:货是怎样装的呢?
A:一箱装100个。
B:我们要500个
17)
A: We need seven of these .
B: They come in cases of five .
A: Then ,send two cases please .
B: Good . thank you for the order .
A:我们要七个这种的。
B:它们是五个一箱。
A:这样的话,就送两箱吧。
B:好的,谢谢你的订货。
18)
A: We can‘t handle an order that small .
B: What is the minimum we would have to order .
A: 300 pieces .
B: I see ,send those ,then .
A:这么少的数量,我们不能接受。
B:那么我们至少得订多少呢。
A:300个
B:哦,那就300个吧。
19)
A: We have a problem with your order .
B: What is it ?
A: We can‘t split open a case to fill your order .
B: I‘ll see if we can take the whole case .
A:你订的货有点问题。
B:什么问题。
A:因为我们不能拆箱来凑足你的订量。
B:那我考虑看看是不是可以买整箱。
20)
A: We can offer you this in different levels of quality.
B: Is there much of a difference in price ?
A: Yes ,the economy model is about 30% less.
B: We‘ll take that one .
A:这产品我们有三种不同等级的品质。
B:价钱也有很大的分别吧?
A:是的,经济型的大约便宜30%。
B:我们就买那种。
参与人数 1金币 +5 威望 +5 收起 理由
WHG168 + 5 + 5 你很热情
发表于 2011-3-18 21:40:01 | 只看该作者
你太伟大了,值得我们学习。。。。
发表于 2011-3-19 09:57:13 | 只看该作者
顶。。。。。。。。。。
GMT+8, 2026-11-30 13:40 , Processed in 0.096184 second(s), 19 queries , Gzip On.
