查看: 750|回复: 4
低碳鋼 (STEEL) 材質螺絲扭力規格
发表于 2011-2-9 12:33:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
螺紋規格 (英制螺紋)組裝時起子扭力 ( in-lb )IQC檢驗扭力 ( in-lb )
0-800.70.9
2-562.12.6
2-642.22.8
3-483.24
3-563.44.3
4-404.86
4-484.96.1
5-406.68.2
5-446.98.6
6-328.310.4
6-409.211.6
8-3215.218.9
8-361620
10-2421.927.4
10-3225.131.4
1/4-205966
1/4-286775
5/16-18122135
5/16-24135150
3/8-16216240
3/8-24244272
7/16-14345385
7/16-20385428
1/2-13525585
1/2-20595660
附註 : 當螺絲及被鎖物件均為鐵件時,以上規格才成立
螺紋規格 (公制螺紋)組裝時起子扭力 ( in-lb )IQC檢驗扭力 ( in-lb )
M1.60.81
M2.0 2.0 ~ 2.2
M2.53.24
M2.6 4.5 ~ 5.0
M36.17.6
M3.59.611.9
M414.117.7
M532.235.7
M65460
M792102
M8133147
M10263292
M12458509
 楼主| 发表于 2011-2-9 12:37:04 | 只看该作者
NECCT screw torque listNECCT
(K,MASUDA)
The standard torque of the screw of NECCT(GSS-32008)
1. Case of steel screw to metal.
 Torque(kgfcm)
 standardMaxMin
M 1.61.001.200.70
M 21.451.840.79
M 2.63.524.461.76
M 36.007.903.20
M 414.5018.407.30
#6-329.2010.358.05
 楼主| 发表于 2011-2-9 12:38:49 | 只看该作者
2. Case of steel screw to nonmetal(Aluminum) and tapping screw to plastic.
 Torque(kgfcm)
 standardMaxMin
M 20.500.650.42
M 2.61.401.701.10
M 34.505.403.00
M 46.007.204.00
3.Unit
UnitscrewTorque
combo/cdM 34.50
1/2"FDDM 2.63.50
3.5"HDD#6-329.00
MBM 36.00
 HEX-NUT3.50PARALLEL PORT
RISER/B
M 36.00
POWERM 36.00
 楼主| 发表于 2011-2-9 13:03:45 | 只看该作者
Torque frame in MiTAC for reference.
Unit: Kgf.cm
Screw/Standofffor Mechanism Parts (Bracket, Plastic Part,etc)for Key Parts (MB,HDD,FDD,CD ROM,PSU,etc)for Fan (Base on shockproof request)for Top Cover(Base on possible disassembly and assembly department)
M2Common 1.5 ± 0.51.5 ± 0.5
NYLOK
M2.6Common4.0 ± 0.52.0 ± 0.5
FDD:3.5kgfcm
3.5 ± 0.5
NYLOK4.5 ± 0.52.5 ± 0.53.5 ± 0.5
M3Common5.5 ± 0.54.5 ± 0.5CD:4.5kgfcm4.0 ± 0.54.0 ± 0.5
NYLOK5.5 ± 0.54.5 ± 0.54.0 ± 0.54.0 ± 0.5
M4Common5.5 ± 0.54.5 ± 0.54.0 ± 0.54.0 ± 0.5
#6-32Common5.5 ± 0.54.5 ± 0.5
OTHER:6.0kgfcm
HDD:9.0kgfcm
4.0 ± 0.54.0 ± 0.5
NUTfor Mechanism Parts (Bracket, Plastic Part,etc)for Key Parts (MB,HDD,FDD,CD OM,PSU,etc)for Fan (Base on shockproof request)for Top Cover(Base on possible disassembly and assembly department)
M36.0 ± 0.5 4.0 ± 0.5
OTHER:6.0kgfcm
HDD:9.0kgfcm
发表于 2011-2-9 16:46:30 | 只看该作者
支持。。。。。。
GMT+8, 2026-10-18 12:39 , Processed in 0.035268 second(s), 18 queries , Gzip On.
