查看: 1260|回复: 4
share some useful setences
发表于 2011-1-10 21:20:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1.
They played the hoses on the burning building.
他们用水管对着燃烧的建筑物喷水。
2.
Check all hoses and lubrication lines for cracking.
检查所有软管和润滑管路是否破裂。
3.
Close test cock No. 1 and test cock No. 2. Remove hoses.
关闭测试旋塞1号和测试旋塞2号。拆卸软管。
4.
The firemen played their hoses on the burning build ing.
消防队员用水龙喷射燃烧着的建筑物。
5.
Remove all hoses and restore valve to original working condition.
拆卸所有软管,并将阀门恢复到原先的工作状态。
6.
I've seen his henchmen beat women in the fields with rubber hoses.
我亲眼看见他的心腹在田园里用橡皮管痛打女工。
7.
We want to buy Machinery, Hoses, Paper and Pulp, Soap / Detergents, Cotton Buds.
我们要采购机器,水管,纸和果肉,肥皂/清洁剂,棉花。
8.
Note: After test, all valves must be open and hoses removed to prevent damage to test kit.
注意:检测后,所有阀门都必须开启,并拆卸所有软管,防止检测组件受到破坏。
9.
The defense officials said the U. S. ship used its water hoses to warn off the Chinese vessels.
美国国防官员说,美国监测船利用高压喷水警告让那两艘中国船支离开。
10.
Dredge hoses demand reliability and safety which will withstand even the most extreme working conditions.
疏浚软管要求可靠性和安全性可以耐受最恶劣的工作环境。
11.
For example, it makes percussion instruments out of general household items like pots, pans, and plastic hoses.
举例来说,他们将盆子、锅子及塑胶水管等一般家庭用品当成打击乐器。
12.
Test kit contains: gauge, test valves, hoses, adaptors, securing strap, instruction guide and lightweight case.
检测组件包括:仪表,测试阀,软管,适配器,安全带,说明书和轻便箱盒。
13.
Work places should be always kept clean and tidy. Hoses, ropes and extension cords must be rolled up after use. 工作场所应始终保持干净和整洁。软管、绳索和电线等必须在使用后卷起。
14.
Enough fire extinguishers and/or hydrants(with hoses) for the size of the factory and in accordance with local laws.
相对于工厂规模足够的灭火器和/或消防栓(带水管)且符合当地法律规定。
15.
But you can also see the fire hoses twenty-two hours after the first explosion still spraying water on the buildings.
但你也能看到在第一次爆炸二十二小时后很多灭火水龙头带还在向建筑物喷水。
16.
Our use of high technology synthetic compounds enables our hoses to withstand the most demanding abrasive environments.
我们使用高科技的配方胶料使胶管可以经受住高磨损环境的要求。
17.
She told me that I would have to work my own way between the construction equipment, but to avoid any hoses on the road.
她告诉我,我将我自己的工作方式之间的建筑设备,但为了避免任何软管的道路上。
18.
All Goodyear hoses are manufactured to the highest production standards and meet required US and European safety and quality standards.
所有固特异的胶管都是依据最高的生产质量标准生产,以达到欧美市场的安全质量标准。
19.
ANDEROL synthetic hydrocarbon based lubricants are similar to mineral oils in their compatibility with paints, seals, gaskets and hoses.
在于油漆,密封件,垫圈和软管的相容性上,ANDEROL合成烃基础油润滑油与矿物油相似。
20.
In the article, it is analyzed that the work characteristic of the machinery, and introduced that the hydraulic double hoses used in the machinery.
笔者分析和研究了该类车辆的作业特性,推荐在升降机构的液压系统中采用液压双路安全阀的技术。
21.
A water-cooling system consists of the engine water jacket, thermostat, water pump, radiator, radiator cap, fan, fan drive belt and necessary hoses.
一个完整的水冷系统包括机体水套,节温器,水泵,散热器,散热器罩,风扇,风扇驱动皮带和必需的水管。
22.
Triangle valve normally connecting pipes and hoses for water faucets, Toilet water use, but also to connect water pipes and hoses for water heaters. 三角阀一般连接管道和进水软管用于水嘴、坐便器供水用,也有连接管道和进水软管用于热水器供水的。
23.
The hoses all looked great from the outside, but one failed even though I had driven only a few miles and the engine had barely reached operating temperature.
所有热水管从外观上看来是良好的,但是有一条热水管爆开时我才开了几英里的路程,引擎还没有达到工作温度。
24.
They used tear gas and fire hoses to disperse the crowd. I saw fire trucks, ambulances, armed personnel carriers and what looked like tanks. I heard random gun shots.
他们使用催泪瓦斯和消防龙头,驱散人群。我看到了消防车、救护车、军车和看起来象坦克的东西。我听到了零星的枪声。
25.
She was there for the buses in Montgomery, the hoses in Birmingham, a bridge in Selma anda preacher from Atlanta who told a people that "We Shall Overcome. "Yes, we can.
她看到了蒙哥马利通了公共汽车、伯明翰接上了水管、塞尔马建了桥。来自亚特兰大的一位传教士告诉人们:我们能!。是的,我们能.
26.
We want to buy Water Pumps, Motors, Generators, Hoses, Rubber Belts, Pullies, Bearings, Aluminum Products, Chandliers, Lamps and Electrical Fittings Lamps and Lampshades.
我们要采购加水给泵,马达,产生器,水管,橡皮腰带,轴承,铝产品,灯和电的配件灯和灯罩。
27.
Introductions include mold characteristics and design of some kinds of corrugated rubber hoses and comparing their advantages and disadvantages so that selecting the suitable structure.
介绍几种橡胶波纹管模具的特点及其设计,并对其优缺点进行了对比,以便更好地选用适宜的结构形式。
28.
Contains spray heads, pipes, hoses, valves, and a backflow controller for diagrams of irrigation systems, garden and lawn in-ground sprinklers, water lines, and automatic watering systems.
包括灌溉系统图的喷头、管道、水龙带、阀门和回流控制器、花园和草坪的地下洒水装置、水道以及自动水利系统.
29.
发表于 2011-1-10 22:13:30 | 只看该作者
跟楼主一样
为了点积分
发表于 2011-1-10 23:44:38 | 只看该作者
哈哈哈。。。。。。。。。。。。。。
发表于 2011-1-11 01:12:05 | 只看该作者
thanks for sharing .
发表于 2011-1-16 11:22:31 | 只看该作者
thanks for sharing
GMT+8, 2026-11-30 14:53 , Processed in 0.031576 second(s), 18 queries , Gzip On.
