查看: 895|回复: 4
模具专业英語
发表于 2010-12-11 14:38:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
模具专业英语
入水:gate        进入位: gate location        水口形式:gate type       大水口:edge gate
细水口: pin-point gate       水口大小:gate size     转水口: switching runner/gate
唧嘴口径: sprue diameter
二、流道: runner
??热流道: hot runner,hot manifold        热嘴冷流道: hot sprue/cold runner
??唧嘴直流: direct sprue gate                   圆形流道:round(full/half runner
??流道电脑分析:mold flow analysis           流道平衡:runner balance
??热嘴: hot sprue                                  热流道板:hot manifold
??发热管:cartridge heater                        探针: thermocouples
??插头: connector plug                          插座: connector socket
??密封/封料: seal
三、运水:water line                            喉塞:line lpug
喉管:tube
      塑胶管:plastic tube                      快速接头:jiffy quick connector
plug/socker
四、模具零件: mold components
??三板模:3-plate mold                            二板模:2-plate mold
??边钉/导边:leader pin/guide pin            边司/导套:bushing/guide bushing
??中托司:shoulder guide bushing           中托边L:guide pin
??顶针板:ejector retainner plate            托板: support plate
??螺丝: screw                                        管钉:dowel pin
??开模槽:ply bar scot                             内模管位:core/cavity inter-lock
??顶针: ejector pin                               司筒:ejector sleeve
??司筒针:ejector pin                               推板:stripper plate
??缩呵:movable core,return core core puller
??扣机(尼龙拉勾):nylon latch lock         斜顶:lifter
??模胚(架): mold base                       上内模:cavity insert
??下内模:core insert                              行位(滑块): slide
??镶件:insert                                        压座/斜鸡:wedge
??耐磨板/油板:wedge wear plate          压条:plate
??撑头: support pillar                             唧嘴: sprue bushing
??挡板:stop plate                                 定位圈:locating ring
??锁扣:latch                                          扣鸡:parting lock set
??推杆:push bar                                   栓打螺丝:S.H.S.B
??顶板:eracuretun                                活动臂:lever arm
??分流锥:spure sperader                      水口司:bush
??垃圾钉:stop pin                                 隔片:buffle
??弹弓柱:spring rod                             弹弓:die spring
??中托司:ejector guide bush               中托边:ejector guide pin
??镶针:pin                                           销子:dowel pin
??波子弹弓:ball catch
模具成形不良用语英汉对照
aberration 色差 atomization ?化                   bank mark ?料纹 bite 咬入
blacking hole 涂料孔(铸疵)                             blacking scab 涂料疤
blister 起泡           blooming 起霜          low hole 破孔            blushing 泛白
body wrinkle 侧壁皱纹                                   breaking-in 冒口带肉
bubble 膜泡          burn mark 糊斑        burr 毛边                   camber 翘曲
cell 气泡               center buckle 表面中部波皱          check 细裂痕
checking 龟裂
chipping 修整表面缺陷                                   clamp-off 铸件凹痕
collapse 塌陷 color mottle 色斑
corrosion 腐蚀 crack 裂痕
crazing 碎裂 crazing 龟裂
deformation 变形 edge 切边碎片
edge crack 裂边 fading 退色
filler speak 填充料斑 fissure 裂纹
flange wrinkle 凸缘起皱 flaw 刮伤
flow mark 流痕 galling 毛边
glazing 光滑 gloss 光泽
grease pits 污斑 grinding defect 磨痕
haircrack 发裂 haze 雾度
incrustation 水锈 indentation 压痕
internal porosity 内部气孔 mismatch 偏模
mottle 斑点 necking 缩颈
nick 割痕 orange peel 橘皮状表面缺陷
overflow 溢流 peeling 剥离
pit 坑 pitting corrosion 点状腐蚀
plate mark 模板印痕 pock 麻点
pock mark 痘斑 resin streak 树脂流纹
resin wear 树脂脱落 riding 凹陷
sagging 松垂 saponification 皂化
scar 疤痕 scrap 废料
scrap jam 废料阻塞 scratch 刮伤/划痕
scuffing 深冲表面划伤 seam 裂痕
shock line 模口挤痕 short shot 充填不足
shrinkage pool 凹孔 sink mark 凹痕
skin inclusion 表皮折叠 straightening 矫直
streak 条状痕 surface check 表面裂痕
surface roughening 橘皮状表皮皱折 surging 波动
sweat out 冒汗 torsion 扭曲
warpage 翘曲 waviness 波痕
webbing 熔塌 weld mark 焊痕
whitening 白化 wrinkle 皱纹
发表于 2010-12-11 15:43:59 | 只看该作者
好样的。。。。。。。。。
发表于 2010-12-12 09:00:42 | 只看该作者
不错,支持,,
发表于 2010-12-14 13:21:35 | 只看该作者
嗯,值得顶一下。。。
发表于 2010-12-18 21:57:14 | 只看该作者
脱模怎么说
呵呵。。。。。。。。。
GMT+8, 2026-11-30 14:35 , Processed in 0.055832 second(s), 18 queries , Gzip On.
