查看: 5303|回复: 21
usually 11 sentence in inspcet report(报告中常用的11个句子)
发表于 2010-10-31 15:27:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1.
1.      1.Please confirm the color fo product housing /enclosure is “white(which should be “red ”stated on product specification) ” instead of “red ”mention on product specification .
2.      2.Please confirm that over(exceed) the tolerance of±10% or ±3cm requirement by client
3.      3.Please confirm that position of rating lable was different between the inspected and golden sample ,the rating lable stuck of bottom of product which can not match the rear position of golden sample.
4.      4.Please confirm that purchase order number as “ABC” on carton and “ABC+1” on rating lable instead of “AB+C1” stated on Job Cover Sheet .
5.      5.Please confirm the torque test (E14 2.0Nm) for lampholder (2pcs out of 5pcs) was failed based on AQL s-1.
6.      6.Please confirm that product status was 50% production and 30% packaging provided by manufactory ,however continue the inspection confirmed by client.
7.      7.Please confirm that product state was 50% production and 50% packaging product by manufactory the before we issued the missing report confirmed by customer.
8.      8.Please confirm allow to 2pcs product for internal check only ,Which should be 13pcs based on AQL s-3 requirement by client.
9.      9.Please confirm the factory allow to do 1pc endurance and loading during inspection ,Which should be 5pcs based on AQL s-3 requirement by client .
10.  10.Please confirm the manufactory of Plug was “***” instead of “**”stated on critical component list of SGS report ,However factory can provided the component “VDE” certificate.
11.  11Please confirm that inspection result was failed (critical defect was found during internal check the inspection) due to the number of Major defect was over the AQL limit .
12.
推荐
 楼主| 发表于 2010-10-31 22:46:15 | 只看该作者
中英文结合的---报告中常用的11个句子
已经马上翻译出来,请班主审阅,给各位同行供参考,主要是用在小家电或灯鉓方面,谢谢大家赏面,争取我的工作也和论坛发的贴子一样,可看性和可讨论性越来越实际。
handwite report1.doc
27 KB, 下载次数: 93, 下载积分: 金币 -1
发表于 2010-10-31 17:12:05 | 只看该作者
楼主/。/
建议你翻译下
有新人是需要你的翻译的哦
谢谢
发表于 2010-10-31 18:40:04 | 只看该作者
多谢楼主分享!!
发表于 2010-10-31 21:58:57 | 只看该作者
THKS FOR UE SHARING
发表于 2010-11-1 14:09:44 | 只看该作者
来顶LZ一下
发表于 2010-11-4 15:00:07 | 只看该作者
太好的东西了·谢谢分享
发表于 2010-11-6 09:07:54 | 只看该作者
谢谢楼主分享 好东西啊
发表于 2010-11-12 23:18:26 | 只看该作者
还不错对策呀a
发表于 2010-11-19 17:18:13 | 只看该作者
为什么回帖不给分啊?
GMT+8, 2026-11-30 12:32 , Processed in 0.030632 second(s), 21 queries , Gzip On.
