查看: 812|回复: 0
FCC 三语标识
发表于 2010-10-25 23:04:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Warning!
This
device
complies with
Part
15
of the FCC
Rules.
Operation
is subject to the following two
conditions:
(1)
This
device
may
not cause
harmful
interference.
(2)
This
device
must
accept any
interference received,
including
interference that
may
cause
undesired
operation.
CAUTION:
Changes
or modifications
not expressly
approved
by
the party responsible
for
compliance could void
the user's authority to operate
the equipment.
NOTE:
This
equipment has
been
tested and
found to comply with
the limits
for
a
class
B
digital
device,
pursuant to part
15
of the FCC
Rules.
These
limits
are
designed
to provide
reasonable
protection
against
harmful
interference in a
residential installation. This
equipment generates,
uses
and
can radiate radio
frequency
energy
and, if
not installed and
used
in accordance
with
the instructions,
may
cause
harmful
interference to radio
communications.
However,
there is no
guarantee
that
interference will
not occur in a
particular
installation. If this
equipment does
cause
harmful
or television
reception,
which
can be
determined by
turning
the equipment off
and
on, the user
is encouraged
to try to correct
the interference by
one
or more of the following
measures:
Reorient
or
relocate
the receiving
antenna.
Increase
the separation
between
the
equipment
and receiver.
Connect
the
equipment
into
an outlet
on
a circuit
different
from
that
to
which
the receiver
is
connected.
Consult
the dealer
or
an experienced
radio/
T
V
technician
for
help.
FCC 三语标识.doc
137.5 KB, 下载次数: 16, 下载积分: 金币 -1
GMT+8, 2026-10-18 12:26 , Processed in 0.029066 second(s), 21 queries , Gzip On.
