查看: 693|回复: 1
基础知识描述--适合初学者看
发表于 2010-9-7 13:10:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
The out-come / appearance of the frills of sealing sample is not ccceptable, it looks very flat / dead, must be more balanced / natural look as standard sample DD 28.8.02.
前中荷叶边太死太平,不够生动,请以2002年8月28日的办做标准。
Sort out the major material defects.
挑出严重布疵。
Take care for trimming + cleaning.
留意剪线和清洁。
Stringholes from plastic string ( for washing ) at pocket flap visible, must be removed.
袋盖上有洗水时打的枪针洞,请消除。
Front horizontal seam not leveled.
前幅横骨不对称。
Handfeel slightly softer than approved sample.
手感比批办稍软。
Armhole pipping ( inside) 2mm more than sealing sample.
夹圈滚条宽度比原办大了2mm。
Pls. add one more button for bigger sizes.
请在大码的衣服上加多一颗钮扣。
Make sure inner facing is long enough in order to avoid pulling at placket bottom.
确保襟贴足够长以避免前襟起吊。
Pay attn. the workmanship of ironing, don’t press the seam too much and avoid the seam allowance see through by heavy pressing.
注意烫工,骨位不要烫太重,避免缝骨止口起痕。
Center front collar not overlap but also not spray.
领子前中不要重叠但也不要张开。
Bust dart seam allowance must be ironed upward.
胸折止口要烫向上面。
Uneven width of top-stitches at closure edge.
前襟边面线宽度不均匀。
Pls. add one more button for all sizes as the distance from hem is too big.
请在所有尺码的衣服上加多一颗钮扣,因为离衫脚的距离太大。
Pls. fix pocket with movable stitches as sealing sample.
请跟原办在口袋上车上(可拆去的)假缝线。
The collar band must not visible at back when wear.
衣服穿着时下级领不能外露。
Pls. make sure the collar are balanced on both sides.
请确保领子两边对称。
Found 3 colors shade within 10 pcs!!
十件衣服中有三种色差!!
3 different color lots in color beige compare to the approved swatch: 3/10 pcs darker, 4/10 pcs lighter, 3/10 as swatch.
Beige色和色办相比有3种不同色差,其中3件偏深,4件偏浅,3件同色办。
Pay attention on the color, which within one garment must be in same color shade.
注意颜色,一件衣服里不能有色差。
Due to the price reason, we accept this order with cutting both ways either in direction or against hair– but you have to make sure the fabric direction must be always same with one garment.
因为价钱问题,我们接受这个订单的可以顺毛裁和逆毛裁,但一定要确保一件衣服内的所有裁片是同一毛向。(灯心绒衣服)Pls. cut all jackets against hair.所有夹克要逆毛裁。
Pls. close the pocket with several movable stitches ( must be not closed all, pls. leave 1cm at each side unstitching).
请用在口袋上缝一段可拆除的假线(一定不能全部缝合,两边要各留1cm不缝合
一、规格不符
序号 缺陷 产生原因 1、规格超差——样板不准;裁剪下刀不准;绗棉时缝位超差。
二、缝制不良
2、针距超差——缝制时没有按工艺要求严格调整针距。
3、跳针——由于机械故障,间断性出现。
4、脱线——起、落针时没打回针;或严重浮线造成。
5、漏针——因疏忽大意漏缝;贴缝时下坎。
6、毛泄——拷边机出故障或漏拷;折光毛边时不严密,挖袋技术不过关,袋角毛泄。
7、浮面线——梭皮罗丝太松,或压线板太紧。
8、浮底线——压线板太松,或梭皮罗丝紧。
9、止口反吐——缝制技术差,没有按照工艺要求吐止口。
10、反翘——面子过紧;或缝制时面子放在上面造成。
11、起皱——没有按照缝件的厚薄调换针线;或缝合件有长短。
12、起绺纽——由于技术不过关缝纽了;缝合件不吻合。
13、双轨——缉单明线,断线后,接缝线时不在原线迹上;缝制贴件下坎后,补线时造成两条线迹。
14、双线不平行——由于技术不过关;或操作马虎造成双线宽窄不匀。
15、不顺直——缝位吃得多少不匀造成止口不顺直;技术差缉明线弯曲。
16、不平服——面里缝件没有理顺摸平;缝件不吻合;上下片松紧不一。
17、不方正——袋角、袋底、摆角、方领没有按90度缝制。
18、不圆顺——圆领、圆袋角、圆袖头、西服圆摆,由于缝制技术不过关出现细小楞角。
19、不对称——由于技术差或操作马虎,必须对称的部位有长短、高低、肥瘦、宽窄等误差。
20、吃势不匀——绱袖时在袖山部位由于吃势不均匀,造成袖山圆胖,或有细褶。
21、绱位歪斜——绱袖、绱领、定位点少于三个或定位不准。
22、对条、对格不准——裁剪时没有留清楚剪口位;或排料时没有严格对准条格;缝制时马虎,没有对准条格。
23、上坎、下坎——缝纫技术低或操作马虎,没有做到缉线始终在缝口一边。
24、针孔外露——裁剪时没有清除布边针孔;返工时没有掩盖拆孔。
25、领角起豆——缝制技术低;领角缝位清剪不合要求;折翻工艺不合要求;没有经过领角定型机压形。
26、零配件位置不准——缝制时没有按样衣或工艺单缝钉零配件。
27、唛牌错位——主唛、洗水唛没有按样衣或工艺单要求缝钉
三、污迹
28、笔迹——违反规定使用钢笔、圆珠笔编裁片号、工号、检验号。
29、油渍——缝制时机器漏油;在车间吃油食物。
30、粉迹——裁剪时没有清除划粉痕迹;缝制时用划粉定位造成。
31、印迹——裁剪时没有剪除布头印迹。
32、脏迹——生产环境不洁净,缝件堆放在地上;缝件转移时沾染;操作工上岗前没有洗手。
33、水印——色布缝件沾水裉色斑迹。
34、锈迹——金属钮扣,拉链,搭扣质量差生锈后沾在缝件上。
四、整烫
35、烫焦变色——烫斗温度太高,使织物烫焦变色(特别是化纤织物)
36、极光——没有使用蒸气熨烫,用电熨斗没有垫水布造成局部发亮。
37、死迹——烫面没有摸平,烫出不可回复的折迹。
38、漏烫——工作马虎,大面积没有过烫。
五、线头
39、死线头——后整理修剪不净。
40、活线头——修剪后的线头粘在成衣上,没有清除。
六、其它
41、倒顺毛——裁剪排料差错;缝制小件与大件毛向不一致。
42、做反布面——缝纫工不会识别正反面,使布面做反。
43、裁片同向——对称的裁片,由于裁剪排料差错,裁成一种方向。
44、疵点超差——面料疵点多,排料时没有剔除,造成重要部位有疵点,次要部位的疵点超过允许数量。
45、扣位不准——扣位板出现高低或扣档不匀等差错。
46、扣眼歪斜——锁眼工操作马虎,没有摆正衣片,造成扣眼横不平,坚不直。
47、色差——面料质量差,裁剪时搭包,编号出差错,缝制时对错编号,有质量色差没有换片。
48、破损——剪修线头,返工拆线和洗水时不慎造成。
49、脱胶——粘合衬质量不好;粘合时温度不够或压力不够,时间不够。
50、起泡——粘合衬质量不好;烫板不平或没有垫烫毯。
51、渗胶——粘合衬质量不好;粘胶有黄色,烫斗温度过高,使面料泛黄。
52、套结不准——套结工没有按工艺要求摆正位置。
53、钉扣不牢——钉扣机出现故障造成。
54、四合扣松紧不宜——四合扣质量造成。
55、折衣不合格——没有按工艺要求(或客户要求)折衣。
56、衣、袋规格不符——包装工操作马虎,将成衣装错包装塑料袋。
57、丢工缺件——缝纫工工作疏忽,忘记安装各种装饰绊,装饰纽或者漏缝某一部位,包装工忘了挂吊牌和备用扣等。
58、装箱搭配差错——包装工工作马虎,没有严格按装箱单搭配装箱。
59、箱内数量不足——打下的次品过多,没有合格品补足造成尾箱缺数。
60、外箱唛头印错——外贸部门提供的唛头有错;生产厂家辨别英语出错
 楼主| 发表于 2010-9-7 15:09:57 | 只看该作者
随便顶下。。。。。。。。。。。。。。。。。。
GMT+8, 2026-10-18 12:12 , Processed in 0.043188 second(s), 19 queries , Gzip On.
