查看: 1894|回复: 5
验货常用英语
发表于 2010-9-3 16:31:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1:Since the warchouse does not have weighing scale,the weight of goods or export cartons could
not be checked during inspection.<br />
由于仓库没有秤,商品和外箱和重量不能在检查期间秤出。<br /><br />Each pc packed per blister,the packed with 3 instruction sheet packed per giftbox with a printed barcode and shrink wrapped.<br /><br />poor plating on matel metal 金属部分电镀不良<br /><br />poor printing on wooden
木头印刷不完整<br /><br />scratched mark on surface of wooden 木头表面有刮花的痕迹<br /><br />the leather of wooden was raise up
木头脱皮<br /><br />dirt mark at sucface of pocket
口袋表面有脏痕<br /><br />glue mark at surface 表面有胶水 <br /><br />crack mark at base 破裂在底座<br /><br />damaged at edge 边缘有损坏<br /><br />oil mark 油痕
<br /><br />RUST MARK
生锈<br /><br />FOLD MARK 折痕<br /><br />POOR FIXING 安装不良<br /><br />MISSING SCREW AT BASE 底坐没有螺丝钉 <br /><br />POOR STITCHING AT POCKET
口袋车的不良<br /><br />LOOSE SEAM 缺针<br /><br />POOR ADHESION
粘的不合(用上鞋子)<br /><br />INSERT 插入
deformed product
变形
dirty
脏
hole on wheel 轮胎上有个洞
excessively trim on edge
边缘批伤
参与人数 1金币 +2 威望 +2 收起 理由
fxy104fxy1 + 2 + 2 你很热情
发表于 2010-9-3 17:08:04 | 只看该作者
太简单拉。。。。。。。。。
郁闷
发表于 2010-9-3 17:21:22 | 只看该作者
A. MATERIAL
1.Wood part
splinter             木刺          Critical
broken              断开          Major
crack               破裂          Major
rough surface        粗造表面      Major or minor
worm hole           虫眼          Major
black/dead knot       死结          Major or minor
chip                崩掉          Major or minor
2.Plastic part
air bubble            气泡         Major or minor
burn mark           烧焦          Major or minor
flow mark           流水痕        Major or minor
flow line            流水纹        Major or minor
stress mark          顶白          Major or minor
silver mark          银丝纹        Major or minor
whire mark          发白          Major or minor
pits                凹坑          Major or minor
short shot           走料不足      Major or minor
shrinkage           缩水          Major or minor
gate remnant        水口未清       Minor
excessive flash       披锋          Minor
mold in dirt         胶件里脏       Major or minor
wavy surface        震纹           Major or minor
crack              破裂           Major
broken             断开           Major
clamp mark         钳痕           Major or minor
pear skin           沙梨皮(琅胶)    Major or minor
too soft            太软           Major or minor
too hard            太硬           Major or minor
uneven wall thickness      摇模胶件厚度不平均    Major or minor
eject mark               顶针痕                Minor
impure plastic            塑料不纯              Major or minor
plastic reminder          胶粪未清              Minor
plastic residue            胶丝胶                Minor
weld line                夹水纹                Minor
part line misalignment     夹模线移位             Major or minor
3.Metal part
rust                生锈           Major
oxidation           氧化           Major or minor
deformed           变形           Major
bend               弯             Major or minor
crack              破裂           Major
broken             断开           Major
burr               金属披锋       Critical
pin hole            毛孔           Minor
poor polishing       抛光不良       Major or minor
polishing compound  抛光余渣       Minor
void               穿孔           Major
4.Paper
printing out of register    印刷套位不正     Major or minor
whit dot                白点             Major or minor
colour shade            色暗             Major or minor
smeared printing         印刷油污         Major or minor
discoloration            裉色             Major
incorrect paper type      错纸张类型        Minor
creased                皱                Minor
torn                   烂
5.Fabrics,Plush
incorrect pile depth          错毛料长度        Major
broken yarn                断纱              Major
coarse yarn of fabric         织物粗纱          Major
missed yarn                织物漏纱          Major
hole at fabric               织物洞眼          Major
fabric torn                 织物料烂          Major
permanent fold lines in fabric  织物永久摺纹      Major
crease line in fabric             织物皱纹         Minor
untrimmed thread end           线头没剪         Minor
long loose thread               长线头           Minor
6.Ceramic
deform                  变形         Major
a swelling               瘤状物        Major
blister on body           坯身空心泡    Major or minor
body refuse              泥渣/落渣     Major or minor
breaching of body         缺泥          Major
glaze bubble             釉泡          Major or minor
glaze craze              炸釉          Major
crack under the glaze      阴裂          Major
crack on body            坏裂          Major
fusion hole              熔洞          Major or minor
chip                    崩            Major
iron spots               斑点          Major or minor
stuck scar               粘疤          Major or minor
flashing                 火刺          Major
orange -peel glaze         桔釉          Major
thread -like surface flaws   泥釉缕        Major or minor
thin glaze               釉薄           Major
decoration defect         画面缺陷       Major or minor
smoked                烟熏           Major
yellowing of glaze        阴黄          Major
purple gold             蓝金           Major or minor
ripple glaze             波浪纹         Major or minor
7.Rattan/bamboo/willow
mould                              发霉             Critical
worm hole                           虫眼             Major
wet on material                       材料湿           Major
coating wet                          湿油             Major
broken                              断裂             Major
low dense weaving                    编织疏           Major or minor
willow/rattan/fern end exposed too long    藤条头暴露太长   Minor
insufficient lacquer                    喷漆不足         Major or minor
lacquer dripping                       聚油            Major or minor
8.Glass
air bubble inside glass            气泡在波璃内     Major or minor
rough and sharp edge of glass      玻璃粗造利边     Critical
chip at glass                    玻璃崩口         Major
uneven thickness of glass         玻璃厚薄不均匀    Major
waviness of glass               玻璃波浪纹        Major
glass not very clear              玻璃不够透明      Major or minor
poor grinding around rim of glass  玻璃边研磨不良    Major or minor
glass fragemets attcvhed          粘附玻璃碎片     Critical
9.wax
air bubble in wax    汽泡在蜡内        Major or minor
broken on body     蜡烛中间有断层    Major
poor shape         形状不良          Major or minor
dirt in wax         蜡内污浊          Minor
B.ASSEMBLY WORKMANSHIP
1.Cleanliness
dirt stain          污渍         Minor
glue stain         胶水渍       Minor
colour stain       色渍          Minor
colour shade       色暗         Minor
wet              湿           Major
decay            腐烂         Minor
solvent mark       溶剂渍       Minor
oil stain           油渍         Minor
ball pen mark      圆珠笔渍      Minor
 楼主| 发表于 2010-9-4 14:01:00 | 只看该作者
3楼的同行朋友,有好的学习资料请分享一下给我哟。谢谢了!我的邮箱: fxy104@163.com
发表于 2010-9-6 15:16:02 | 只看该作者
过来骗积分的
 楼主| 发表于 2010-9-6 15:30:25 | 只看该作者
那你跑到这里来,还不是。。。。
GMT+8, 2026-11-30 14:36 , Processed in 0.037878 second(s), 19 queries , Gzip On.
