查看: 2013|回复: 12
那里有外贸箱包类英语学习?跪求!!!!!!
发表于 2010-8-2 22:24:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
兄弟姐妹们,那里有外贸箱包类英语学习或心得?跪求!!!!!!
发表于 2010-8-2 23:00:06 | 只看该作者
拉杆不够滑畅
No smooth enough of trolley system
车轮松动
Bad quality of wheel
轮子不转动
No working of wheel
LOGO牌不洁
Logo no clean
LOGO牌刮花
Scratched logo
包装胶袋小
No big enough of polybag/polybag too small
漏放天地盖
Missing cover board(up & down)
漏放防潮珠
Missing silica gel
吊牌吊错
Wrong hangtag / no the correct hangtag (red/black)
针距太长
Bad stitching / distance of stitching is too long
吊袋毛边
Bad making of hanging pocket
吊袋包边倒针不牢
End/bad stitching of hanging pocket
条码错误
Wrong barcode
手把不牢固
Bad making of handle
车线不直
Bad stitching
包装不好
No good packing
清洁不好(油污、线头)
Dirt on material(oil and thread)
外箱尺寸不够高
No enough height of export carton
外箱印刷字体不清楚
No clear print of export caton
箱唛上漏填箱号
Missed carton No.
外箱打包带用铁片接口
Security band w / metal / clip
前袋盖魔术帖的位置与袋口不对称
Wrong position of velcro at front panel
拉练尾绳烧烫不好
No good end-marking of puller string
手挽织带车
前后扶车钱不重叠
Bad stitching of bandle P.P w/ body material
袋口包边反折不平
Bad end binding
布料色差
Color different of material
线头没剪干净
Drop tear uncutted thread
不干胶贴歪
Wrong sticker position at export carton
不干胶盖住箱唛
Sticker covered shipping Mark
箱唛上印错英文字母
Wrong printing of shipping Mark
发表于 2010-8-2 23:00:53 | 只看该作者
丝印颜色不对
Wrong screen print color
丝印不好
Bad quality of screen print
拉练尾塑胶脱落
Easy to pull down the puller stopper
侧周与前后幅色差
Color different of body material & gusset material
车工不好
Bad workmenship
铆钉开花不良
Bad pouch of nail
肩带尺寸不够长
The length of shoulder belt is too short,it should be__cm
脚钉松动
No tight enough of nail
塑胶配件材质不良
Easy break of plastic Acc
外箱上正唛贴纸贴在右下角,正确应在箱唛中间
Sticker should be center of export carton No the right corner of bottom
活动底板PVC胶皮电压口和周边不平齐
Bad end-making of PVC Board
边织袋身接头太多(绳纸带)
Bad end making of straw
看:See
朝前地:Frontward
以上:Above
意见:Comment
箱子歪角
No good standing of trolley / of pilot case
袋子手挽有长短
No the same drop length of handle
编织带有折痕
Folded P.P Webbing
手工不好
Bad workmenship
吊牌没有过胶
Hangtag without coating
前袋拉链车得不直
Bad making of zip(too rude) no straigtht enough
压扣太松
Easy to move of nail
包装入胶时袋子不可折叠,要平放
Wrong packing, its flat-packed, not folded-packed
外箱颜色填错,应为单色
Wrong print of shipping mark”asscorted color”,should be “solid color”
外贸担保出货
Supplier ship this order w /L/G
下次不可有此问题产生
No more happen from next order
从后来订单开始更正
To fix the problems from next order
外箱的填写部位为手写体
Shipping mark with hand writing
发表于 2010-8-2 23:01:20 | 只看该作者
翻工后才可出货
Can ship the order after
repairing
纸箱材质差
Bad quality of carton (too soft)
按钮锁开关不良
No good guality of lock
内里色差
Color difference of lining
袋子整理不平
Rude packing
前袋拉链车得不直
Bad making of zip (too rude)
袋身编织接口太多
Bad end-making of straw
外箱没印箱唛
Missing shipping mark
电压
Hot-seal
LOGO电压不清楚
No clear print of logo
LOGO(塑胶)车线不好
Bad stitch of logo
前袋包边破
Broken binding (front pocket)
前袋内文件破
Broken binding (organizer) :lol
发表于 2010-8-2 23:02:42 | 只看该作者
箱包验货步骤
1.  确认成品包的尺寸是否正确。如:后片29“*20”*11“+3”
2.
检查原物料是否符合公司要求。
A
.面料、里布(纱粗细度、颜色、密度、厚度、色牢度是否达到标准,背胶PVC不可发白及柔软度,纱洁、亮点、抽纱程度)
B
.网布(网孔形状、每米的克重量、颜色)
C
.人造革要达到订单要求的厚度,背胶要够密度,不可易撕裂。
D
.尼龙拉链(根据订单要求,主拉、附袋拉、内里拉的大小、规格、颜色、色牢度是否正确,拉齿不可有噪音,需顺畅,
不可有卡住或太紧的情况,拉链布边的密度、宽度须达到具体订单要求)。
E
.拉头+拉片(拉头的大小规格、有无锁孔、拉头鼻不可断裂,拉片字母、颜色、大小是否正确。)
F
.织带、包边带、松紧带(颜色、纹路、克重、厚度、色牢度、松紧度)
G
.管条、护角条(颜色、色牢度、材质、尺寸规格是否正确)
H
.塑胶配件(手把、插扣、勾扣、D形扣等塑胶产品都要进行破坏性试验,插扣、勾扣、D形扣、名片框等扣具尺寸、颜色、形状等是否符合订单要求。)
I
.五金配件(颜色、防酸处理、尺寸、线径,特别钢钉的防锈处理)
J
.钢线、铁框、蜂巢框(钢线的线径、铁框、蜂巢框成型后的宽度)
K
.拉杆、轮子(拉杆拉起来要滑顺,不能有杂声和平重晃动,按指式的拉杆要按了才能拉起或放下,三节和二节的每节都要能卡住)
L
.商标(字母、尺寸、颜色等是否正确)。布标是否正确。
M
包装类(吊卡、吊线、纸箱,品质及印刷内容是否正确)
3.
成品包检查:前片
后片
中围
内里
A
.前片是否平整,转角处不可起皱。
B
.拼接片直线要直,假线不可外漏。
C
.前后片的管条护角要左右对称。
D
.中筋织带的位置是伸缩拉链打开后位置当中。
E
.侧钉打完后,不能有抽丝和破损,上手把要放平,且平放时四方圈与握推平把手与琵琶头不能有空隙,把手车线是双线。
F
.后片名片袋不可车歪,要左右对称。后片角落不可起皱。
G
.角轮与管条间不可有空隙,角轮组装时与底部要平行,不可有内外八字。
H
.前脚座必须打在围条双线的第二条车线处。
I
.所有里布,包边带,拉链,网布不可有色差。
J.拉杆箱合包包边接头要在下1/4处。(特别注意)。
K
.车线的针距为1英寸5.5-6针,把手4.5针,合包5.5针,电脑车7针。
L
.软包的肩带的长度50″
M
.打钉时,钢钉须开花良好。
N
.包装前,成品包必须清洁,无线头。按照我公司具体订单的要求进行包装。
发表于 2010-8-3 10:28:45 | 只看该作者
很好很强大 谢谢
发表于 2010-8-3 13:48:56 | 只看该作者
又学到好东西了
发表于 2010-8-24 20:29:33 | 只看该作者
学习外语最重要的就是语言环境,经常系统地有意识地和拥有纯正口语的人交流多了,你掌握的单词就多了,再学习其他的语法知识效果就好多了,我之前找了许多家都是由于各种原因没学好,后来自己上网找了几个比较了一下,就是在家跟老外交流,学习英语,是小班授课,一个班4-8个人,小班课程开口机会很多,挺不错的,叫乐知英语。他们有很多课程挂在网上免费试听,你可以去旁听课程学习语法锻炼听力都很不错http://www.hiknow.com/sessionhall.html
发表于 2010-8-25 12:38:41 | 只看该作者
谢谢了,朋友
发表于 2012-7-27 19:24:21 | 只看该作者
It sounds great!. 听起来很不错。
GMT+8, 2026-9-19 07:44 , Processed in 0.042378 second(s), 18 queries , Gzip On.
