查看: 1685|回复: 13
中英文的品质缺陷说法
发表于 2010-7-5 11:47:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
哪位大侠能给一份完整的关于产品缺陷的中英文大全供参考啊
发表于 2010-7-5 12:54:46 | 只看该作者
兄弟,
论坛很多这样的帖子啊。。。。。。。。。。
你可以找找
发表于 2010-7-5 13:27:10 | 只看该作者
杂货缺陷判定及中英对照
Defect Classification for Sundries
Defect description in English  Defect description in Chinese  Defect Classification
A. MATERIAL
1.Wood part
splinter             木刺          Critical
broken              断开          Major
crack               破裂          Major
rough surface        粗造表面      Major or minor
worm hole           虫眼          Major
black/dead knot       死结          Major or minor
chip                崩掉          Major or minor
2.Plastic part
air bubble            气泡         Major or minor
burn mark           烧焦          Major or minor
flow mark           流水痕        Major or minor
flow line            流水纹        Major or minor
stress mark          顶白          Major or minor
silver mark          银丝纹        Major or minor
whire mark          发白          Major or minor
pits                凹坑          Major or minor
short shot           走料不足      Major or minor
shrinkage           缩水          Major or minor
gate remnant        水口未清       Minor
excessive flash       披锋          Minor
mold in dirt         胶件里脏       Major or minor
wavy surface        震纹           Major or minor
crack              破裂           Major
broken             断开           Major
clamp mark         钳痕           Major or minor
pear skin           沙梨皮(琅胶)    Major or minor
too soft            太软           Major or minor
too hard            太硬           Major or minor
uneven wall thickness      摇模胶件厚度不平均    Major or minor
eject mark               顶针痕                Minor
impure plastic            塑料不纯              Major or minor
plastic reminder          胶粪未清              Minor
plastic residue            胶丝胶                Minor
weld line                夹水纹                Minor
part line misalignment     夹模线移位             Major or minor
3.Metal part
rust                生锈           Major
oxidation           氧化           Major or minor
deformed           变形           Major
bend               弯             Major or minor
crack              破裂           Major
broken             断开           Major
burr               金属披锋       Critical
pin hole            毛孔           Minor
poor polishing       抛光不良       Major or minor
polishing compound  抛光余渣       Minor
void               穿孔           Major
4.Paper
printing out of register    印刷套位不正     Major or minor
whit dot                白点             Major or minor
colour shade            色暗             Major or minor
smeared printing         印刷油污         Major or minor
discoloration            裉色             Major
incorrect paper type      错纸张类型        Minor
creased                皱                Minor
torn                   烂
5.Fabrics,Plush
incorrect pile depth          错毛料长度        Major
broken yarn                断纱              Major
coarse yarn of fabric         织物粗纱          Major
missed yarn                织物漏纱          Major
hole at fabric               织物洞眼          Major
fabric torn                 织物料烂          Major
permanent fold lines in fabric  织物永久摺纹      Major
crease line in fabric             织物皱纹         Minor
untrimmed thread end           线头没剪         Minor
long loose thread               长线头           Minor
6.Ceramic
deform                  变形         Major
a swelling               瘤状物        Major
blister on body           坯身空心泡    Major or minor
body refuse              泥渣/落渣     Major or minor
breaching of body         缺泥          Major
glaze bubble             釉泡          Major or minor
glaze craze              炸釉          Major
crack under the glaze      阴裂          Major
crack on body            坏裂          Major
fusion hole              熔洞          Major or minor
chip                    崩            Major
iron spots               斑点          Major or minor
stuck scar               粘疤          Major or minor
flashing                 火刺          Major
orange -peel glaze         桔釉          Major
thread -like surface flaws   泥釉缕        Major or minor
thin glaze               釉薄           Major
decoration defect         画面缺陷       Major or minor
smoked                烟熏           Major
yellowing of glaze        阴黄          Major
purple gold             蓝金           Major or minor
ripple glaze             波浪纹         Major or minor
7.Rattan/bamboo/willow
mould                              发霉             Critical
worm hole                           虫眼             Major
wet on material                       材料湿           Major
coating wet                          湿油             Major
broken                              断裂             Major
low dense weaving                    编织疏           Major or minor
willow/rattan/fern end exposed too long    藤条头暴露太长   Minor
insufficient lacquer                    喷漆不足         Major or minor
lacquer dripping                       聚油            Major or minor
8.Glass
air bubble inside glass            气泡在波璃内     Major or minor
rough and sharp edge of glass      玻璃粗造利边     Critical
chip at glass                    玻璃崩口         Major
uneven thickness of glass         玻璃厚薄不均匀    Major
waviness of glass               玻璃波浪纹        Major
glass not very clear              玻璃不够透明      Major or minor
poor grinding around rim of glass  玻璃边研磨不良    Major or minor
glass fragemets attcvhed          粘附玻璃碎片     Critical
9.wax
air bubble in wax    汽泡在蜡内        Major or minor
broken on body     蜡烛中间有断层    Major
poor shape         形状不良          Major or minor
dirt in wax         蜡内污浊          Minor
B.ASSEMBLY WORKMANSHIP
1.Cleanliness
dirt stain          污渍         Minor
glue stain         胶水渍       Minor
colour stain       色渍          Minor
colour shade       色暗         Minor
wet              湿           Major
decay            腐烂         Minor
solvent mark       溶剂渍       Minor
oil stain           油渍         Minor
ball pen mark      圆珠笔渍      Minor
ink mark          墨水渍       Minor
dead insect        死昆虫       Critical
alive insect        活昆虫       Critical
finger print        手指模印      Minor
water stain        水痕          Minor
2.painting
over spraying       喷油过多        Major or minor
under spraying      喷油不足        Major or minor
paint scratch off     涂油刮花        Major or minor
paint peel off             涂油起皮        Major or minor
paint smear               油污           Major or minor
poor insufficient coverage   喷油盖底不足    Major or minor
uneven painting           涂油不均匀      Major or minor
paint accumulation         聚油            Major or minor
paint stain                涂油渍          Major or minor
poor touch up             手感不良        Major or minor
dull colour               色沉            Major or minor
painting off position        涂油移位        Major or minor
bubble paint              油漆起泡        Minor
orange peel               橙皮油         Major or minor
3.Lacquer coating
incomplete lacquer coverage     叻架盖底不足    Major or minor
lacquer accumulation           叻架聚          Major or minor
uneven lacquer coating          叻架涂不均匀    Major or minor
lacquer staing                 叻架渍          Major or minor
bubbles in -lacquer             叻架起泡        Minor
lacquer coating too thin         叻架涂层太薄     Major or minor
lacquer coating too thick        叻架涂层太厚     Major or minor
lacquet cracked                叻架裂           Major or minor
4.Silk screen priting
incomplete silk screen printing         丝印盖底不足       Major or minor
silk screen printing off position        丝印移位           Major or minor
silk screen printing on wrong position   丝印位置错误       Major
smeared silk screen printing           丝印油污           Major or minor
5.Tempo printing
incomplete tempo printing         移印盖度不足    Major or minor
tempo printing off position         移印移位        Major or minor
smeared tempo printing           移印油污        Major or minor
tempo printing on wrong position   移印位置错误    Major
6.Decal
decal off position            贴花移位        Major or minor
incomplete decal            贴花不全        Major or minor
decal printing out of register   贴花套位不正    Major or minor
clour off tone               色不协调        Major or minor
torn decal            贴花烂       Major or minor
decal printing smeared  贴花油污     Major or minor
7.Sticker
sticker peel off        贴纸翘起      Major or minor
torn sticker           贴纸烂        Major or minor
printing out of register  贴纸套位不正  Major or minor
printing semeared      油污          Major or minor
8.Electro-plating
yellowish             电镀变黄         Major or minor
black mark            电镀发黑         Major or minor
abrasion              电镀擦花         Major or minor
peel off               电镀脱落        Major or minor
elector-plating shadow   电镀阴阳色      Major or minor
elector-plating rainbow   电镀成彩虹印    Major or minor
over plating            电镀过多        Major or minor
under plating           电镀不足        Major or min
发表于 2010-7-5 14:14:40 | 只看该作者
路过,学习了
发表于 2010-7-5 14:42:40 | 只看该作者
学习了~,谢谢
发表于 2010-7-5 16:08:46 | 只看该作者
3楼,很强大~~~~
发表于 2010-7-5 16:18:12 | 只看该作者
3楼很详细,学习了
发表于 2010-7-6 13:41:47 | 只看该作者
3楼很辛苦啊,多谢了!本人要好好学习了
发表于 2010-7-7 10:12:04 | 只看该作者
先顶了再看。。。。
发表于 2010-7-8 17:46:56 | 只看该作者
学习中,谢谢
GMT+8, 2026-10-18 11:25 , Processed in 0.060238 second(s), 18 queries , Gzip On.
