查看: 1157|回复: 4
Wal-Mart requirement
发表于 2010-5-13 20:56:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Wal-Mart的要求
Vendors’ responsibility - due to Wal-Mart strict requirements there will be monetary penalty if not compliance. Quality assurances; such as fabric testing for shrinkage, crocking (wet and dry), colorfastness, torque, correct labeling of fiber content, and care instruction for the product.
因为Wal-Mart的要求比较严格,像面料缩率,面料干湿摩擦色牢度,成衣扭力,面料成分,面料的纱支,面料的克重,面料的正确的洗涤方法等等,都要达到Walmart相应的标准,如果达不到要求就要被扣款。
We will not accept your submittal if the below are not follow: (NO ACCEPTION)
如果不按照客人的要求来提交样品的话,客人将不会给意见,所以一定要按照下面的要求提交样品:
  • Fabric quality (10 yards required), fabric spec sheet must be accompany along with fabric。
    Need MTL report of fabric testing to t
    hread count, Gauge, and fabric weight. Please send via e-mail to US
面料的品质样:需要提交10码品质面料给客人确认,一定要连同附件的面料spec sheet一起提交给客人,同时需要提交上海MTL所做的面料纱支/克重/密度的报告。
  • Lab dip – 4x4 swatch (4sets)
素色小样:要用正确的品质来提交所有的色样,色卡要做成4”x4”大小,一式6套。
  • Strike off - 6x6 swatch if all over-print (6sets), border print/repeat print- a swatch of full repeat must be submitted (6 sets)
面料印花样:要用正确的品质来提交所有的印花底色样,6“X6”大小,
一式6套,大的印花,印花样一定要有一个完整循环4套。
  • Shade band – 6x6 swatch (4 sets)
缸差样:大货面料出来后,需要提交所有的缸差样,每块6”x6”大小,一式6套
  • Once shade band is approved, 30 yards require from one of the dye lot or dye lot indicated by us.
缸差样确认后,客人会要求指定的缸差,需要寄30码样布的给客人做样衣,此面料一定要保证面料的各项性能测试是合格的(包括面料的缩水率/扭曲率/干湿摩擦色牢度/日晒色牢度等),因为客人会用此面料去做产前样/测试样/大货样,去CTL做测试。所有的测试一定要CTL测试通过以后,才可以出货。
  • Trims: lace, draw cording, etc….7 inches is require (4 sets)
辅料(蕾丝/抽绳/1/4“象根等等):要求至少一份长7”,
一式4套
  • Screen- must be printed on correct ground color or if ground fabric is not available, you may print on white color pellon.
    (6 sets per color combo)
印花一定要印在正确颜色的底布上,如果没有正确颜色的底布,可以印在白色的面料上,一式6套。
  • Two
    complete size run in any 1 color,and 3 pieces in size medium we require pp sample to be given to us in correct trim, screen (if applicable) for approval. (3 pieces require)
PP样(产前样/尺寸样):一但客人给我们M码纸扳,我们要尽快安排提交尺寸样/产前样给客人确认,要求任意一个颜色齐码2套,其他颜色混色1套,要有正确面辅料。
  • TOP sample for CTL is require in each color and each size (5 pieces )
TOP样(大货样):要做CTL测试,齐色齐码各5件,尺寸要保证在允许的误差范围内,另外TOP样的各项面料的测试要达到标准,因为客人会拿衣服到CTL测试的。
  • Time and Action Calendar must be submitted in 10 days upon receipt of PO. (If not, there is a 2% charge from total purchase order amount.)
辅料以及大货生产的各个环节需要的确认时间表一定要在收到合同 10天内提交,如果提交不了,扣除合同总额的2%。
发表于 2010-5-13 22:53:22 | 只看该作者
haha, 很好的东西
发表于 2010-5-14 10:13:20 | 只看该作者
好帖!直接把内容显示出来,节约了一个金币,谢谢啊。
发表于 2010-5-16 13:10:52 | 只看该作者
学习了
发表于 2010-5-26 15:27:14 | 只看该作者
learning more !!!!!!!!!!!!!!!!
GMT+8, 2026-11-5 07:03 , Processed in 0.157506 second(s), 20 queries , Gzip On.
