查看: 2371|回复: 11
新人写报告之常用中英文缺陷描述--转归纳
发表于 2010-5-11 13:06:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
A
upc sticker / label /litho
1
Incorrect format
与标准版样不符
2
Incorrect content
内容不正确
3
Incorrect material
材质(粘性)不正确
4
Incorrect size
尺寸不正确
5.1
Un-clear Printing but read abailable
印刷不清晰,可读
5.2
Un-clear Printing and hard to be identified
印刷不清晰,很难读
5.3
Un-clear Printing and can not be Read
印刷不清晰,不可读
6.1
Poor Adhere - flapping edge
翘边
6.2
Poor Adhere - slight out of the designated position or twist
与指定位置有明显偏差
6.3
Poor Adhere - upside down
粘贴方向颠倒
6.4
Poor Adhere - not in the right position
粘贴位置不正确
7
permanence stickiness or not not meet
是否永久粘性不正确
8
UL/special client labels request don't from designated supplier
特殊标签不是从指定供应商采购, UL
B
upc extension
1
Scan Degree less than B
扫描低于B
2
Un-read
不可读
3.1 Broken or tear to the bar cord area but can be read 条形码区域破损但仍可读
3.2 Broken or tear damage the bar cord area and occur the un-reading.条形码区域破损导致不可读
3.3 Broken or tear but don't danage to the bar cord area
破损但不影响条形码区域
4
scaned code# isn't same as printed code#
扫描读数与印刷读数不符
C
litho extension
1
Light mis-pattern
印刷不良, 輕微脫版
2
Serious mis-pattern
印刷不良, 嚴重脫版
3
Light Color Deviation less than 3 degree
輕微色差, 三級以內
4
Serious Color Deviation excess 3 degree
嚴重色差, 超過三級
D
color box extention
1
Incorrect structure
紙箱結構不符要求
2.1 Light mis-pattern
印刷不良, 輕微脫版
2.2 Serious mis-pattern 印刷不良, 嚴重脫版
3.1 Light Color Deviation less than 3 degree 輕微色差, 三級以內
3.2 Serious Color Deviation excess 3 degree 嚴重色差, 超過三級
E
PE bag / Shrinking Wrap
1 Incorrect structure & Dimension 結構或尺寸錯誤
2 Incorrect Warning or printing 警語或印刷錯誤
3 Missing the vent hole as request 未按要求打透氣孔
4 Bad smell
異味
5.1 Light Broken and split 輕微破損或撕裂
5.2 Serious Broken and split 嚴重破損或撕裂
6 Transparencey not meet the requirement 透明度不符要求
7 Burn 燒焦
8 Poor melting seal
封口不良
9 incorrect material used on PE bag
PE
袋材质不正确
F
others
1 foam incorrect packed泡沫塑料, 海绵
2 styrofoam incorrect packed
3 strap incorrect packed 带子,编织袋
4 honeycomb board incorrect packed 蜂巢纸
5 inner wrinkle sheet/brown paper
incorrect packed
皱纹纸,牛皮纸
G
general packing
1 Missing components 包裝零件丟失
2 Incorrect packing method 包裝方式錯誤
3.1 Light deforming of packing but dont damage the products 輕微包裝變形但不會造成產品損傷
3.2 Serious deforming of packing but dont damage the products 嚴重包裝變形但不會造成產品損傷
3.3 Serious deforming or damage of packing but don't damage the product 嚴重包裝變形或损坏且不造成產品損傷
3.4 Serious deforming or damage of packing and damage the product 嚴重包裝變形或损坏且造成產品損傷
4.1 Seam missing 紙箱未封口
4.2 Poor taping / gluing and the opening on the cover panel 封箱不良, 箱蓋開口
5 Miss UPC 條碼標未貼
6 Miss Sticker or warning 要求之貼紙或警告標語未貼
7.1 Container loading - No container inspection 没执行货柜检查
7.2 Container loading - Dirt of Conatiner 货柜脏
7.3 Container loading - Incorrect loading way 装柜方式不正确
8 metal scissor/ knife pieces leave in box. 刀具
H
Master Carton / Color Box
1 Incorrect structure 紙箱結構不符要求
2.1 Incorrect seam method but no problem to pack the products and pass the test requirements of QR 紙箱和縫方式不正確但不影響包裝且通過QR測試
2.2 Incorrect seam method and the goods can not be well packed. 紙箱和縫方式不正確且影響包裝
3.1 Poor seam with the opening 紙箱和縫處不良並有開口
3.2 Poor seam with the opening and safety concern 紙箱和縫處不良並且有安全考量
4.1 Incorrect dimension but no problem to pack the products and pass the test requirements of QR 紙箱尺寸不正確但不影響包裝且通過QR測試
4.2 Incorrect dimension and the goods can not be well packed 尺寸不正确影响包装质量
5 Incorrect shipping mark 麥頭錯誤
6.1 Un-clear shipping mark but no problem to read 輕微印刷不清楚, 但仍可辨識
6.2 Un-clear shipping mark and can not read 印刷不清楚, 且無法辨識
7 Incorrect Graphic printing 圖案印刷錯誤
8.1 Serious tearing - less than 2cm length 嚴重撕裂小于2cm
長度
8.2 Serious tearing - 2~5cm length 嚴重撕裂2~5cm 長度
8.3 Serious tearing - over 5cm length or tearing two areas 嚴重撕裂超過5cm
長度或两处以上
9.1 Broken less than 2cm
破裂小于2cm
長度
9.2 Broken -- 2~5 cm length
破裂2~5 cm 長度
9.3 Broken over 5cm, product visible 破裂超過5cm
長度
10.1 Visual dirt mark, spot, water mark etc between 5 to 10 square cm and less than area 髒污點介於5 10 平方cm
10.2 Visual dirt mark, spot, water mark etc over 10 square cm
髒污點大於10 平方cm
11 UPC can not be read 條碼無法讀取
参与人数 1金币 +5 威望 +5 收起 理由
yyfbz + 5 + 5 你很热情
 楼主| 发表于 2010-5-11 13:09:04 | 只看该作者
Abrasion磨损
Angle on insole中底发角
back height 后跟高度
Back strap too high(low,long,short)后拉带太高
bottom dirty大底不洁
Broken thread断线
Cement on heel鞋眼沾胶
Cementing comes off脱胶
Cementing no good接着力不佳
chip碎屑
Cleanness not enough清洁度不佳
Color not matching色差
Color variation色差
Crooked back stay 后套歪斜
Crooked upper鞋面弯曲
Crooked屈曲,不平顺
Damaged upper鞋面破损
dirty 脏的
Flatten变平
gaping 缝隙
get mildew发霉
Gore too weak松紧带弹性不佳
hairy 起毛
Heel not straight后套不正
Lasting off center攀歪
Loose thread脱线
Not in pair不配双
Outsole not smooth大底不平
over cemented溢胶
Pinch in 缩进去
Rough粗糙
Shank not straight铁心不正
Shank too loose铁心太松
smeary污染
sole adhesion大底欠胶
Sole come off底脱胶
Sole laying not proper(centered)贴底不正确
Stitching not even车不平均
Stitching not on the mark不照记号齿车
Toe broken down鞋头凹陷
Tricot shows up特丽可得露出来
Trun yellow变黄
Turn dark变黑
Vamp length鞋头大小
Vamp open up鞋面掀开
Vamp split off 鞋面爆开
Vamp wrinking鞋面皱纹
Wrapping not even攀帮不均匀
Wrapping not tight攀帮不紧
Wrong colour颜色错误
Wrong cutting裁断错误
Wrong last 楦头错误
发表于 2010-5-16 13:43:11 | 只看该作者
整理一个文档不是很好啊
发表于 2010-5-20 11:35:12 | 只看该作者
正是我要拿来学习和研究的,谢谢了楼主,楼主真厚道, .
发表于 2010-5-20 12:57:36 | 只看该作者
谢谢楼主分享,顶一下。
发表于 2010-5-23 08:34:35 | 只看该作者
This is very useful for my daily job,thanks for share.
发表于 2010-5-23 10:52:40 | 只看该作者
谢谢分享,帮顶下。
发表于 2010-5-24 07:36:52 | 只看该作者
很实用的资料,谢谢分享
发表于 2011-9-26 17:53:04 | 只看该作者
我爱死你了,斑竹,解燃眉之急
发表于 2013-8-17 12:05:43 | 只看该作者
不错
GMT+8, 2026-9-16 16:33 , Processed in 0.036612 second(s), 19 queries , Gzip On.
