查看: 892|回复: 4
模具专业英语
发表于 2010-3-30 00:37:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
入水: gate 进入位: gate location 水口形式: gate type 大水口: edge gate 细水口: pin-point gate 水口大小: gate size 转水口: switching runner/gate 唧嘴口径: sprue diameter 二、流道: runner 热流道: hot runner,hot manifold 热嘴冷流道: hot sprue/cold runner 唧嘴直流: direct sprue gate 圆形流道: round(full/half runner 流道电脑分析:mold flow analysis 流道平衡: runner balance 热嘴:  hot sprue 热流道板: hot manifold 发热管: cartridge heater 探针: thermocouples 插头:  connector plug 插座: connector socket 密封/封料: seal 三、运水:water line 喉塞: line lpug 喉管: tube 塑胶管: plastic tube 快速接头:jiffy quick connector plug/socker 四、模具零件: mold components 三板模: 3-plate mold 二板模: 2-plate mold 边钉/导边:l eader pin/guide pin 边司/导套: bushing/guide bushing 中托司: shoulder guide bushing 中托边L: guide pin 顶针板: ejector retainner plate 托板:  support plate 螺丝: screw 管钉: dowel pin 开模槽: ply bar scot 内模管位: core/cavity inter-lock 顶针:  ejector pin 司筒: ejector sleeve 司筒针: ejector pin 推板: stripper plate 缩呵: movable core,return core core puller 扣机(尼龙拉勾): nylon latch lock 斜顶: lifter 模胚(架): mold base 上内模: cavity insert 下内模: core insert 行位(滑块): slide 镶件: insert 压座/斜鸡: wedge 耐磨板/油板: wedge wear plate 压条: plate 撑头: support pillar 唧嘴: sprue bushing 挡板: stop plate 定位圈: locating ring 锁扣: latch 扣鸡: parting lock set 推杆: push bar 栓打螺丝: S.H.S.B 顶板: eracuretun 活动臂: lever arm 分流锥: spure sperader 水口司: bush 垃圾钉: stop pin 隔片: buffle 弹弓柱: spring rod 弹弓: die spring 中托司: ejector guide bush 中托边: ejector guide pin 镶针: pin 销子: dowel pin 波子弹弓: ball catch ?? 模具成形不良用语英汉对照 aberration 色差 atomization ? 化 bank mark ? 料纹 bite 咬入 blacking hole 涂料孔(铸疵) blacking scab 涂料疤 blister 起泡 blooming 起霜 low hole 破孔 blushing 泛白 body wrinkle 侧壁皱纹 breaking-in 冒口带肉 bubble 膜泡 burn mark 糊斑 burr 毛边 camber 翘曲 cell 气泡 center buckle 表面中部波皱 check 细裂痕 checking 龟裂 chipping 修整表面缺陷 clamp-off 铸件凹痕 collapse 塌陷 color mottle 色斑 corrosion 腐蚀 crack 裂痕 crazing 碎裂 crazing 龟裂 deformation 变形 edge 切边碎片 edge crack 裂边 fading 退色 filler speak 填充料斑 fissure 裂纹 flange wrinkle 凸缘起皱 flaw 刮伤 flow mark 流痕 galling 毛边 glazing 光滑 gloss 光泽 grease pits 污斑 grinding defect 磨痕 haircrack 发裂 haze 雾度 incrustation 水锈 indentation 压痕 internal porosity 内部气孔 mismatch 偏模 mottle 斑点 necking 缩颈 nick 割痕 orange peel 橘皮状表面缺陷 overflow 溢流 peeling 剥离 pit 坑 pitting corrosion 点状腐蚀 plate mark 模板印痕 pock 麻点 pock mark 痘斑 resin streak 树脂流纹 resin wear 树脂脱落 riding 凹陷 sagging 松垂 saponification 皂化 scar 疤痕 scrap 废料 scrap jam 废料阻塞 scratch 刮伤/划痕 scuffing 深冲表面划伤 seam 裂痕 shock line 模口挤痕 short shot 充填不足 shrinkage pool 凹孔 sink mark 凹痕 skin inclusion 表皮折叠 straightening 矫直 streak 条状痕 surface check 表面裂痕 surface roughening 橘皮状表皮皱折 surging 波动 sweat out 冒汗 torsion 扭曲 warpage 翘曲 waviness 波痕 webbing 熔塌 weld mark 焊痕 whitening 白化 wrinkle 皱纹 模具工程常用词汇英汉对照——2 stock age analysis sheet 库存货龄分析表 on-hand inventory 现有库存 available material 良品可使用 obsolete material 良品已呆滞 to be inspected or reworked 待验或重工 total 合计 cause description 原因说明 part number/ P/N 料号 type 形态 item/group/class 类别 quality 品质 prepared by 制表 notes 说明 physical inventory 盘点数量 year-end physical inventory difference analysis sheet 年终盘点差异分析表 physical count quantity 帐面数量 difference quantity 差异量 cause analysis 原因分析 raw materials 原料 materials 物料 finished product 成品 semi-finished product 半成品 packing materials包材 disposed goods 处理品 warehouse/hub 仓库 on way location 在途仓 oversea location 海外仓 spare parts physical inventory list 备品盘点清单 spare molds location 模具备品仓 skid/pallet 栈板 tox machine 自铆机 wire EDM 线割 EDM放电机 coil stock 卷料 sheet stock 片料 tolerance 工差 score=groove 压线 cam block 滑块 pilot 导正筒 trim 剪外边 pierce 剪内边 drag form 压锻差 pocket for the punch head 挂钩槽 slug hole 废料孔 feature die 公母模 expansion dwg 展开图 radius 半径 shim(wedge) 楔子 torch-flame cut 火焰切割 set screw 止付螺丝 form block 折刀 stop pin 定位销 round pierce punch=die button 圆冲子 shape punch=die insert 异形子 stock locater block 定位块 under cut=scrap chopper 清角 active plate 活动板 baffle plate 挡块 cover plate 盖板 male die 公模 female die 母模 groove punch 压线冲子 air-cushion eject-rod 气垫顶杆 spring-box eject-plate 弹簧箱顶板 bushing block 衬套 insert 入块 club car 高尔夫球车 capability 能力 parameter r参数 factor 系数 phosphate 皮膜化成 viscosity 涂料粘度 alkalidipping 脱脂 main manifold 主集流脉 bezel 斜视规 blanking 穿落模 dejecting 顶固模 demagnetization 去磁;消磁模具钢材及零件英语 模具钢材 alloy tool steel 合金工具钢 aluminium alloy 铝合金钢 bearing alloy 轴承合金 blister steel 浸碳钢 bonderized steel sheet 邦德防蚀钢板 carbon tool steel 碳素工具钢 clad sheet 被覆板 clod work die steel 冷锻模用钢 emery 金钢砂 ferrostatic pressure 钢铁水静压力 forging die steel 锻造模用钢 galvanized steel sheet 镀锌铁板 hard alloy steel 超硬合金钢 high speed tool steel 高速度工具钢 hot work die steel 热锻模用钢 low alloy tool steel 特殊工具钢 low manganese casting steel 低锰铸钢 marging steel 马式体高强度热处理钢 martrix alloy 马特里斯合金 meehanite cast iron 米汉纳铸钢 meehanite metal 米汉纳铁 merchant iron 市售钢材 molybdenum high speed steel 钼系高速钢 molybdenum steel 钼钢 nickel chromium steel 镍铬钢 prehardened steel 顶硬钢 silicon steel sheet 硅钢板 stainless steel 不锈钢 tin plated steel sheet 镀锡铁板 tough pitch copper 韧铜 troostite 吐粒散铁 tungsten steel 钨钢 vinyl tapped steel sheet 塑料覆面钢板 塑件&模具相关英文 compre sion molding 压缩成型 flash mold 溢流式模具 plsitive mold 挤压式模具 split mold 分割式模具 cavity 型控 母模 core 模心 公模 taper 锥拔 leather cloak 仿皮革 shiver 饰纹 flow mark 流痕 welding mark 溶合痕 post screw insert 螺纹套筒埋值 self tapping screw 自攻螺丝 striper plate 脱料板 piston 活塞 cylinder 汽缸套 chip 细碎物 handle mold 手持式模具 移转成型用模具 encapsulation molding低压封装成型 射出成型用模具two plate两极式(模具) well type 蓄料井 insulated runner 绝缘浇道方式 hot runner 热浇道 runner plat 浇道模块 valve gate 阀门浇口 band heater 环带状的电热器 spindle 阀针 spear head 刨尖头 slag well 冷料井 cold slag 冷料渣 air vent 排气道 h=0.02~0.05mm w=3.2mm L=3~5mm welding line 熔合痕 eject pin 顶出针 knock pin 顶出销 return pin 回位销反顶针 sleave 套筒 stripper plate 脱料板 insert core 放置入子 runner stripper plate 浇道脱料板 guide pin 导销 eject rod (bar) (成型机)顶业捧 subzero 深冷处理 three plate 三极式模具 runner system 浇道系统 stress crack 应力电裂 orientation 定向 sprue gate 射料浇口,直浇口 nozzle 射嘴 slag well 冷料井 side gate 侧浇口 edge gate 侧缘浇口 tab gate 搭接浇口 film gate 薄膜浇口 flash gate 闸门浇口 slit gate 缝隙浇口 fan gate 扇形浇口 dish gate 因盘形浇口 H=F=1/2t~1/5t T=2.5~3.5mm diaphragm gate 隔膜浇口 ring gate 环形浇口 subarine gate 潜入式浇口 tunnel gate 隧道式浇口 pin gate 针点浇口 Φ0.8~1.0mm Runner less 无浇道 (sprue less) 无射料管方式 long nozzle 延长喷嘴方式 Sprue 浇口;溶渣 sprue lock pin 料头钩销(拉料杆) 塑件模具相关英文——2 eject pin 顶出针 knock pin 顶出销 return pin 回位销反顶针 sleave 套筒 stripper plate 脱料板 insert core 放置入子 runner stripper plate 浇道脱料板 guide pin 导销 eject rod (bar) (成型机)顶业捧 subzero 深冷处理 three plate 三极式模具 runner system 浇道系统 stress crack 应力电裂 orientation 定向 sprue gate 射料浇口,直浇口 nozzle 射嘴 sprue lock pin 料头钩销(拉料杆) slag well 冷料井 塑件模具相关英文——1 compre sion molding 压缩成型 flash mold 溢流式模具 plsitive mold 挤压式模具 split mold 分割式模具 cavity 型控 母模 core 模心 公模 taper 锥拔 leather cloak 仿皮革 shiver 饰纹 flow mark 流痕 welding mark 溶合痕 post screw insert 螺纹套筒埋值 self tapping screw 自攻螺丝 striper plate 脱料板 piston 活塞 cylinder 汽缸套 chip 细碎物 handle mold 手持式模具 encapsulation molding 低压封装成型、射出成型用模具 hot runner 热浇道 runner plat 浇道模块 band heater 环带状的电热器 spindle 阀针 spear head 刨尖头 cold slag 冷料渣 模具相关英语——7 Embosss 凸点 dome 凸圆 semi-shearing 半剪 stamp mark 冲记号 deburr or coin 压毛边 punch riveting 冲压铆合 side stretch 侧冲压平 reel stretch 卷圆压平 groove 压线 blanking 下料 stamp letter 冲字(料号) shearing 剪断 tick-mark nearside 正面压印 tick-mark farside 反面压印 模具工程类 plain die 简易模 pierce die 冲孔模 forming die 成型模 progressive die 连续模 gang dies 复合模 shearing die 剪边模 riveting die 铆合模 pierce 冲孔 forming 成型(抽凸,冲凸) draw hole 抽孔 bending 折弯 trim 切边
发表于 2010-3-30 08:07:33 | 只看该作者
感谢分享!
发表于 2010-3-30 09:05:27 | 只看该作者
COPY来发表很好,但应该整理一下,一团乱!
发表于 2010-4-4 17:39:20 | 只看该作者
good,for free
发表于 2010-4-4 23:58:12 | 只看该作者
不错,我喜欢直接贴上来的
GMT+8, 2026-11-30 15:28 , Processed in 0.026950 second(s), 18 queries , Gzip On.
