查看: 1150|回复: 4
我现在需要电磁炉成品检验标准,谁有啊,各位大佬!!
发表于 2010-3-18 16:47:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我现在需要电磁或电陶炉炉成品检验标准,谁有啊,各位大佬!!
发表于 2010-3-19 08:38:39 | 只看该作者
我也没有,但也希望有
发表于 2010-3-19 09:15:11 | 只看该作者
电磁炉验货标准1(英文版)
0.
Scope
This document covers the specific quality requirements and defect classification for the above model.
1.
General information
If a defect is located which is not specified herein, the Technical Manager, or in his absence the Quality Assurance Manager, of Markpeak Limited shall determine in which defect classification it is to be placed.
The inspection procedure and defect classification is an endeavour to assure product quality and will be reviewed as necessary.
2.
Sampling plan
The sampling plan to be used is
MIL-STD-105E single sampling plan for normal inspection using the following AQL’s for
acceptance / rejection criteria:
A.
Critical defect
0.00%
B.
Major defect
0.65%
C.
Minor defect
1.50%
3.
Definition of defects and faults
Defects and faults are classified in 3 categories:
Critical:
i)
Defect which could endanger a person’s safety whilst operating or maintaining the product.
ii)
A defect which contravenes basic safety requirements as below:
a)
Low Voltage Electrical Equipment (Safety) Regulation .
b)
EMC/EMF Certification
Major:
A defect that interferes with the proper operation of the product and prevents it from fulfilling its function. Any missing components, accessories and packaging items.
Any appearance defects which would prevent sale to any customers.
Minor:
A defect that does not substantially affect function of the product but results in the product not meeting set standards and requirements.
Some minor appearance defects which should not result in outright rejection by customer at point-of-sale.
Note:
If a defect is not previously determined and classified, the above definitions are generally referred to for classification.
Prior to the first shipment of any product, the supplier must provide documentation to the inspectors showing up to date certification to current standards from a Test House accredited by CNCA in the China or similar European or international bodies less such as the EA, ILAC or IAF.
Marking Data
Model No WKICHE211
Rating information
Date Code should be printed on body below rating details
Date Code: YYWW
Colour Scheme
Unit
Black
Branding –
Print on the plate
Rating information –print
ed on the rating label
Light
--- Red
Audit of
1.
Packaging
A.
Master Carton
1.
Condition – undamaged
Minor
2.
Printing correct.
Minor
3.
Clean
Minor
4.
Date coded. (YYWW format)
Minor
5.
ITF barcode scanable – (See PO in details)
Major
6.
Quantity per master = 2
Major
B.
Individual Carton
1.
Minor
2.
Printing correct.
Minor
3.
Proper packaging with inserts
Major
4.
EAN Barcode scanable – (See PO in details)
Major
5.
Ease of removal from carton
Minor
6.
Correct closure of carton
Minor
C.
Check contents to include
1.
Instruction book
Major
2.
Guarantee card
Major
Note:
a.
All plastic bags must have hole and suffocating warning printed.
Critical
D.
Units must pass packaging test standards
Major
(reference ISTA Test Procedure 2A).
Test to be repeated
every 3 months or, in the case of materials, packaging or
component changes, test to be performed at time of change(s).
2.
Product
A.
Date Code, Product Identification, Rating Information
Critical
And Cautionary Information Included
B.
1.
Appliance and all accessories to be clean, free of burrs
Major/Minor
proper colo
ur and be capable of
assembly as per instructions
2.
All parts must fit and be secured
Major/Minor
C.
Appliance Main Body (Critical components see appendix.)
Black Crystal plate on top with touch panel.
in 3 languages warning and settings.
Major
1.
Line Cord recognized and identified
Critical
Length within the range of 1.5m with plug attachment.
Note: all listed critical components have to
comply with
the components table of the CCC or CE report provided.
Critical
发表于 2010-3-19 09:21:19 | 只看该作者
后面的不知道怎么回事,发不了。
说什么包含“不良信息”不给发了。
不好意思
 楼主| 发表于 2010-3-19 09:36:18 | 只看该作者
啊!不是吧,老大啊
GMT+8, 2026-10-27 08:31 , Processed in 0.203857 second(s), 18 queries , Gzip On.
