查看: 1361|回复: 3
BS6001 (MIL - STD - 105D) Single Sample Plan
发表于 2007-6-1 18:03:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Acceptable Quality Level (AQL) sample inspection methods have been proven to be accurate in the long run. However, the quality of merchandise at destination is generally lower then the pre-shipment results. This can be due to transport, handling, change in environment and/or reliability problems. This will be taken into consideration when deciding the AQL level.
Switching Rules will be applied to products, as and when applicable
Switching Rules shall be applied for normal, reduced and tightened inspection
The Inspection Report will detail the Switching Rule applied for the Lot inspected
Control of the Switching Rules, by part number and factory, is the responsibility of the Assistant Technical Managers in the local China offices
BS6001.xls
26.5 KB, 下载次数: 73, 下载积分: 金币 -1
发表于 2007-11-24 22:21:09 | 只看该作者
TKS for good share!
发表于 2009-5-6 17:25:45 | 只看该作者
谢谢楼主分享,好资料,不过好象不全
发表于 2009-7-17 13:15:18 | 只看该作者
thanks guy.....................
GMT+8, 2026-10-18 09:44 , Processed in 0.043262 second(s), 21 queries , Gzip On.
